Old 02-06-2006, 05:36 PM   #1
1991 25' Excella
SF Bay Area , California
Question battery power
Does anyone know how long you can run on battery power? We have a 1991 25' Excella for which we just bought a new battery. How long should we expect to be able to run on battery, such as overnight when running the heat? Do any of you run two batteries at a time? This is probably a dumb question... do two batteries double the voltage or increase the running time available? How does that work? Thanks for the help.
aeriqua is offline   Reply With Quote
Old 02-06-2006, 05:41 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Two batteries in parallel will double the amperage, while maintaining thbe voltage. Two batteries in series will double the voltage, while maintaining the amperage. Parallel is connecting batteries + to+, and - to -. Series is connecting batteries + of the first to - on the second, then + on the second to the power feed on your coach. This can only work if you install two 6 volt batteries, as two 12 volts batteries will damage nearly everything in the electrical system of the coach.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 02-06-2006, 08:59 PM   #3
1975 29' Ambassador
Reno , Nevada
You should be able to run at least three days and two nights in mild to cool weather (occasional furnace use) on the batteries in your rig. There may be an adjustment process of either adding battery or adjusting lifestyle to meet this goal, though. Some, I think most, folks can go quite a bit longer, especially if not needing the furnace as much.
The energy capacity is mostly determined by weight and size of all of your batteries together. Parallel vs serial is a religious argument for some but the difference is in the noise as far as practical matters go (except for making sure the wiring is right).
Properly installed batteries need a ventilated cabinet that will contain spills in order to meet code. Even AGM's are supposed to have this (for code) but don't really need it.
Old 02-07-2006, 01:57 PM   #4
A discussion of this is at http://www.airforums.com/forum...ter-15625.html?
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 02-08-2006, 09:11 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
How large is your battery? Size 24 or 27?
Amp hours are the key and you want more of them. I discussed this issue at length in the current issue of Airstream Life (Winter 2006). Do you have a way to recharge your battery? (aside from your tow vehicle?)
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-08-2006, 10:12 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
With two batts, using the furnace at night, stereo, pump, lights and fantastic fans during the day, I got about 6 or 7 full days....I would think with similar use, you'd get half that with one battery.
Old 02-09-2006, 01:04 AM   #7
2002 25' Classic
Kalama , Washington
How long you can run infers full battery/ies, no recharge and use to complete discharge. Lots of factors influence the time. An important one to remember is that the healthy life of the battery is markedly reduced by very deep discharge events. As a guide recharge when 50% discharged. Say you begin with 80A or 105A, divide by 2, get your manual out and see what the appliances you're using draw (per hour). Except for phantom loads and the refer, the draw is intermittant so use likely fractions to multiply your amps for each. The stingier you are the longer it takes to use up 50% of your amps...or completely discharge and replace your battery/ies sooner
Brian
nwclassic is offline   Reply With Quote
Old 02-09-2006, 07:33 AM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Biggest load
How long you can go depends on where you are in the country, how cold and blowy is it and how good your batteries are. If you want maximum time, buy the deep cycle batteries. Be aware they usually come with a shorter warrentee period because they know people abuse them and they do not want to pay for your abuse. Even with deep cycles the previous poster was right in suggesting you never draw them down to less than 50%. Another approach is to abuse Walmart by buying automotive batteries and getting a free replacement before the full warrentee period expires. (They test them to make sure they are defective before they give you a new one so sometimes this does not work.) Up North the furnace fan is the biggest amp hour draw on the battery system and that is usually the controlling factor. Putting LED lighting will save you a bit but may not be worth it unless your bonedock alot.
Old 02-09-2006, 10:22 AM   #9
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
This web site should answer your basic questions about batteries.
Make sure to continue on to Part II.
The 12volt Side of Life
Maurice
Old 02-09-2006, 10:46 AM   #10
1991 25' Excella
Thank you all so much for the great responses and info. My "to do" list has just grown HUGE. I'm off to check into size 27 AGMs, see how many amps by battery has now, get a 2000 generator, and on.... Thanks for all the help. You all are a great resource.
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
