Old 08-27-2004, 11:12 AM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Battery/Multitester 101...
Hello.
I am going to pick an analog-type multi-tester from Home Depot. I plan on using it to check the battery levels when I boondock, so I know when to hook up the Honda 2000 that I am the proud owner of at this time. The 2000 is very quiet, and I think it will work out great for our needs. If we find that we just can't live with out the air conditioner, we will consider another 2000 to run in parallel.
Here is my question: I have two coach batteries in the 19' CCD. The batteries are wired to one another (I think this is called series, or is it parallel?) Anyway, when I take a reading from one of the two batteries, what readings should I be looking to get? Do I need to read each battery individually, which means I'd have to disconnect one bat. from the other.
At what voltage do I then start charging with the Honda? I think RKMoe said that going to 10.5V was commiting battery homicide, I don't want this to happen.
FYI, I also have a BatteryMinder that I will use during the winter months, when the batteries are in storage in my basement.
If you could not tell from the above, I am quite green about batteries, multi-meters, anything electric, and any info, like, say how to even use a multi-meter would be most appreciated.
Blushingly yours.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-27-2004, 11:31 AM   #2
1975 24' Argosy 24
Burlington , Ontario
Batteries
You have not said what voltage the batteries are.
Are they connected Plus to plus and negative to negative. if so it is a PARLLEL connection.
If the wires go from one battery through the other it is SERIES and the voltages would be number one plus number two.
You can measure the voltage across each battery seperately, and across both batteries together.
I would seriously suggest that you go to a dealer or a garage and have a person explain the system to you. There is sulfuric acid in the batteries and if you do the wrong thing you might incure dire results in an explosion.
DO NOT FOOL WITH WHAT YOU APPARANTLEY KNOW LITTLE IF ANYTHING ABOUT.
I chide you not be careful.
Rae
Electronics Service Lab Burlington Ontario.
raebaker06 is offline   Reply With Quote
Old 08-27-2004, 11:57 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Your batteries should be connected in parallel. 12.6 Volts is considered fully charged, although will probably get a reading higher than that. You should start to charge them around 12.0 volts. No need to disconnect them. I am assuming that you are using the Bambi's built in charging system.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-27-2004, 12:08 PM   #4
Johnathon, you will be a lot happier with a digital voltmeter, even though it may cost twice as much as an analogue meter. You will be checking for small differences in voltage, and this can be much more difficult to measure with an analogue meter. There are couple of good books on RV electrics. Harold Barre has written a good one, entitled "Managing 12volts" . A little reading will increase your confidence. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-27-2004, 12:56 PM   #5
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thank you all for your replies. I am about to return to Home Depot my analog $13.00 tester that I used to test on aa 9volt battery before it died.
Rae: I am not at my trailer, but I believe they are hooked up in series, plus to plus, minus to minus. Sorry I was not clear on that in my first post. I've done a bit of electrical stuff around the house so I'm not TOTALLY clueless. Just confused.
Nick: I will look into the digital meter for sure.
Pick: 1st ? For now let's call my batteries #1 and #2. If I have the black(-) probe from the meter on the minus (-) of battery #1 and the red (+) probe on the plus of the battery #1, will the reading be only from battery #1, or will it also reading power off Battery#2? I guess what I'm asking is if there is a way to find out if each battery is in good shape individually, without having to undo the leads that go from battery 1 to battery 2.
Let me put it another way. Say my reading is 12.6 volts with batteries 1 and 2 hooked up in series and the reading is done as written above. If I disconnect all the cables to each battery (again for sake of discussion), should the reading of both batteries individually still be 12.6 volts?
Thanks again.
Jonathan
Old 08-27-2004, 01:35 PM   #6
1975 24' Argosy 24
I still think that your batteries are 12VDC units and are in series. I have not seen most campers with 24 volts. Most are 12VDC units. Your vehicle charges 13.8 VDC, and would not charge a series circuit.
+ =======(+ B1 -)=(+ B2 -)======= - This is series
<--------- 12VDC-><12VDC>--------->
<----------------24VDC-------------->
<-----------12VDC---------->
+=====I==(+ B1 -)==I
I==(+ B2 -)==I===== - This is parallel
I still think you had best get some authorative advice.
My advice is good. Take it.
You could be sorry.
Rae
Old 08-27-2004, 01:46 PM   #7
LOST , Hawaii
Got filler caps on the batteries? If there are 6 they are 12 volts, 3 is 6 volts.
If both positives and both negatives are hooked together or to a common terminal they are in parallel. If the positive of one battery is hooked to the negative of another and the other positive and negative are hooked to the charger/load they are in series.
John
74Argosy24MH is offline   Reply With Quote
Old 08-27-2004, 01:53 PM   #8
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Are the batteries deep cycle? You can draw them down farther.
Go digital DVOM. So much more easily read when you're eyes are going.
Tom Nugler is offline   Reply With Quote
Old 08-27-2004, 01:56 PM   #9
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Crazy, your batteries are connected in parallel. With that in mind you are reading the combined voltage of both batteries. The only way to read an individual battery is to disconnect the - (Ground or Black wire) of the other battery in parallel. I would not do this on a trip. Just be satisfied with the combined reading. Every 3 months or so, you may want to check an individual battery, if you suspect there is a problem, or when checking water level and see one battery's level different from the other.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-27-2004, 02:36 PM   #10
Parrallel 12 volt batts
Most everybody has 12 volt batteries. A few have opted for 6 volt golf cart batts that are true deep cycle-as noted they will have 3 cells (filler caps) on top.
When two batteries have been connected together for a while, the weaker battery WILL bring down the better one. So it is always best to have matched batts of the same age.
The biggest killer of batts is overcharging and boiling water off. Next is leaving a discharged batt set too long. Very inportant to check water level and add DISTILLED water only to the bottom of the caps.
Charging one will charge the other at the same time. That's OK.
Putting a timer on the Univolt is what I have done to keep from having to plug and unplug coach to 110volt. Set timer to come on 1 - 2 hours a day max.
Digital Multimeter is a must. Here is a great site: http://bart.ccis.com/home/mnemeth/12volt/12volt.htm
Keep asking questions...
Steve in Sav'h
Sav'h Steve is offline   Reply With Quote
Old 08-27-2004, 08:02 PM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
hey lev,
don't chuck the analog unit just yet. i actually prefer them to digital units.
what you are looking for is overall trends with your voltmeter battery relationship. even the best voltmeters can be inaccurate by large margins! i use a wavetech meterman meter at work every day at the power company, i'm on my third one since we switched to digital meters about 6 years ago. they are fragile, don't work especially well in cold weather, and go out of adjustment without notice.
i have my original simpson meter that was issued to me back in the 80's and it still works perfectly! and it was probably 20 years old when i got it!
we have this test at the power company for delicate instruments, we call it the "drop test" my simpson has survived a couple of them and lived. my prior two digital meters have failed this test!
keep in mind, what ever meter you get. take a reading when you first get it and write it down. weather it is 12.4 12.7 etc, it doesn not matter much. what you need to look for is a general trend in the condition of your batteries. steady is good, a general downward trend is bad.
your batterys are most certainly connected in parallel.
john
you call them ferrets, i call them weasels.
Old 08-28-2004, 07:59 AM   #12
1975 24' Argosy 24
John HD Gave you good advise. I too have a Simpson 260 analog meter. They are dependable and take a beating. Not so for digital meters. I have owned them as well.
Your Parallel connection needs to have one battery terminal removed to measure. When hooked together you are reading both batteries similtaniously.
Do not worry about very small differences. eg 12.6 or 12.5. Your meter lead resistance can make that difference.
Be sure to top up your battery cells with only distilled water. the chemicals in tap water will ruin you battery in time.
Batteries self discharge and need to be float charged to keep them working.
Starting batteries have the plates made of a lead paste and deep cycle have solid lead plates. and will last for years if you look after them.
Rae
Old 08-28-2004, 08:49 AM   #13
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thanks guys.
I bought the Ideal 360 digital meter from HD $60.00. My AS is a 2004 CCD, and the batteries are deep cycle. At this point I just wanted to keep an eye on the battery level when boondocking.
One of the things I learned is that in order to get an acurate reading, there should be no load on the battery for six hours.
Steve: great reading from the suggested site.
I'll be leaving Wednesday for a five night camp-out and will check to see how the batteries held up in storage for the past weeks. The only draw on the bat. should be the LP detector. The camp ground we are going to has hook-ups, so the 2000 won't get it's work out until October when we go to Sand Ridge State Forest in Ill.
Anyone else been there?
Jonathan
Old 08-28-2004, 09:33 AM   #14
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
jonathan,
i also have a simpson 260, but i rely on the old style tester...a hydrometer...its only about 5 bucks at the auto store, and specific gravity readings give you a good way to monitor battery level although not as convenient...
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Airstream 101 donreitz Our Community 8 09-08-2004 08:47 PM
Windows 101 ScrapIrony-2 Windows & Screens 23 06-15-2004 09:53 PM
101 In California? Hidalgo On The Road... 0 05-28-2004 09:33 AM
Brakes 101 - need all the help I can get! 66Sovereign Brakes & Brake Controllers 14 10-06-2003 06:53 AM
Need help with Airstreamforums 101 !!! John Our Community 9 12-07-2002 12:55 PM
