Old 10-17-2018, 09:51 AM   #1
2019 22' Sport
Quartzsite , Arizona
Basic RV'ing Books?
Howdy,
While AF is invaluable it is a bit more cumbersome to search and weed through topics for answers.
As a first timer getting ready for an extended road trip I still have tons of questions and am looking for a bit better than "we do this" but perhaps some of the reasons why.
For instance; black water management. Using which additives and how much, when to empty. Pros and cons of disposal systems.
How a refrigerator works; battery/propane/shore power etc.
Battery management...
And on and on.
I know most information should be universal to RV's and not specific to my AS.
Many of the books I see on Amazon are motorhome centric so most likely deal with issues that don't concern my rig....
Is there a "bible" of RV'ing that could answer my questions so I don't clog up AF with basic questions?
Rounder44
Rounder44 is offline   Reply With Quote
Old 10-17-2018, 10:27 AM   #2
Lynnsr
lynnsr's Avatar
2018 20' Flying Cloud
Colorado Springs , Colorado
Basic RVing
Basic RVing
Cumbersome, it maybe, however your best source:
Airforums
RV.net
Browse the YouTube channels
It may take some time, however, it is enjoyable, educational, and you will garner some of the latest thoughts.:wally
Lynnsr
lynnsr is offline   Reply With Quote
Old 10-17-2018, 10:40 AM   #3
2013 20' Flying Cloud
Westerly , Rhode Island
Newbies Guide to Airstreaming. As far as technical "how to questions go there is really almost nothing in it that is not covered in your manual, just a lot more concise and to the point.
smithcreek is offline   Reply With Quote
Old 10-17-2018, 10:47 AM   #4
MWBishop's Avatar
Huntsville , Alabama
And don't forget the newbies-guide follow-on book:
Airstream Life's (Nearly) Complete Guide to Airstream Maintenance
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 10-17-2018, 11:41 AM   #5
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Explore More just did some great videos on their YouTube channel about basic systems.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 10-17-2018, 11:43 AM   #6
2019 22' Sport
Thanks!
I have the books mentioned but they don't address the finer points.
I started to research black water "additives" and an hour later thought I had some good advice but little of it explained "why".
Mostly anecdotal and "worked for me" explanations.
Even the ins and outs of travel; best practices of fueling, checking propane, weigh stations, rv parks etc.....
I see some "idiots" guides on Amazon but 3-4 star reviews mostly....
AF is fantastic but I'd love an hard copy reference. When I'm at the AS I only have small iPhone and it's difficult to access information that way!
R44
Old 10-17-2018, 12:01 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by Rounder44 View Post
Howdy,
And on and on.
Rounder44
Hi
Ok:
Black water - dump it when it's full, flush the tank when dumping, put in an additive of your choice after the dump. Why? If it's full you can't put any more in. Flush to get everything out. Additive simply to make it smell a bit better.
Fridge: A normal RV fridge works by boiling and re-condensing an ammonia solution. There is a boiler and a condenser involved. The system needs to be reasonably level or the tubing will block with bubbles or fluid (depending on which side). Since it's heat driven, you need to get rid of the excess heat off of he condenser. On shore power the boiler runs off of 120V. On the road the boiler heats off of propane. If it's a three way (many are not) it can boil the fluid off of 12V battery power. In all cases the control board runs off of 12V power.
Battery management:
Assume it will take 8 hours of charging to get the battery "full". It may not, but this is a good starting point. Once charged, with nothing going on (no shore power / no loads / 2 hours of settling / at 70F) the battery should read about 12.6V. Why? Voltage drops in wiring will throw off readings. Batteries take time to chemically settle after use or charging. Battery voltages are temperature dependent. Each of those points could be expanded into at least a dozen books.
Battery capacity for lead acid batteries is a "100% discharge" number. You *can* discharge to this point. They will not live very long if you do. Best advice is to stop using them around 50% discharge. That is roughly 12.0 to 12.1V at 70F. The stop using point will be a higher voltage when it's cold and a lower voltage when it's hot. Just how much higher or lower is very much a "that depends" sort of thing. A half volt higher at freezing is not uncommon.
Flooded cells should be checked for water level from time to time. In hot dry climates that may be monthly. In the cold and damp that may be a lot less often. AGM batteries don't have this issue. Why? AGM's are sealed. Flooded cells turn the water in them into gas which then floats off into the atmosphere.
Batteries in an AS should be charged about once every week or two. There are parasitic loads the will flatten them if you don't. How fast they go down is very dependent on your exact trailer and it's configuration.
That's more than you likely will see in any book on RV use on any of those questions. It does not get into advertising specific products. Unlike the authors of some of those books, I have not been paid to sell you less than ideal products.
Are the points above complete? Nope, a full discussion of some of them will get into 4 years of college level training. Are they open to debate? You bet they are !!! Tune into any thread here and there will be debate.
Any more questions?
Old 10-17-2018, 01:02 PM   #8
2018 23' International
Minneapolis , Minnesota
I know this isn't exactly what you're looking for, but "Travels with Charley" by John Steinbeck is an awesome RV book!
Gopher John is offline   Reply With Quote
Old 10-23-2018, 06:41 PM   #9
2018 30' Classic
Jacksonville , Florida
I don't know it they speak to what you want but I'm sure they would be entertaining...………….
https://www.amazon.com/Long-Honeymoo...70_&dpSrc=srch
Overstreet is offline   Reply With Quote
Old 10-23-2018, 06:43 PM   #10
2018 30' Classic
John Steinbeck didn't explain why things did what they did the way the OP wants, but I agree it was a good book.
Old 10-23-2018, 06:52 PM   #11
ITSNO60's Avatar
Tucson , AZ
I love those two and I am going to have my wife watch their videos to help her get over some of the fear she has of RVing.
Brian
ITSNO60 is offline   Reply With Quote
Old 10-23-2018, 08:18 PM   #12
1971 27' Overlander
2004 25' Safari
Jourdanton , Texas
“Trailer Life’s RV Repair and Maintenance Manual” by Bob Livingston is good reference on how things work. It is 2002 publication, This is a dated publication on the basics of systems. New systems have more bells and whistles, but the basics remain. I bought a copy for my son this summer because I didn’t want to pass mine along. Used copies available at Amazon.
Prickly Pear is offline   Reply With Quote
Old 10-24-2018, 08:25 AM   #13
Half a Rivet Short
Hi
One of the big things that a book really can't give you is the "this system on that year of this model has this issue ..." sort of thing. At least in my case, that stuff has been incredibly valuable (like it probably saved some big money ...). The same forum research that keeps you up on that stuff also educates you on the various systems.
Old 10-25-2018, 11:31 AM   #14
2019 22' Sport
Thanks!
I ordered a copy of the Woodall's RV Guide.
While I get it about model specific issues I'm looking for a more general approach to figuring out the whole idea of RV'ing.
I'll mostly have my iPhone for referencing online info and that's far from ideal especially if out of signal range.
While we're at it is there a good road atlas geared toward RV's? Focus on camping and fuel stops etc...
R44
Guns, Pistols, RV'ing and ?? Felony oxblood On The Road... 56 08-01-2007 03:01 PM
Per-PEX-ing Question soldiermedic Fresh Water Systems 19 11-07-2006 09:13 AM
Monte'ing up fireflyinva General Interior Topics 6 04-28-2005 10:31 AM
ID'ing a Model by the Belt Line styling jaco Airstream Trailer Forums 5 02-25-2004 02:06 PM
Brakes 'thunk'ing? Stefrobrts Brakes & Brake Controllers 12 05-11-2003 11:15 AM
