Old 03-27-2014, 11:23 PM   #29
2014 22' FB Sport
Atlanta , Georgia
Well, we're home again, jiggidy jig. Backing this thing into the driveway was nearly a total Charlie Foxtrot. The only thing that kept it from being a complete CF was that nobody was killed (though my copilot came closer than she knows) and there are (as far as I can tell) no scratches on my new trailer.
None of the strategies here worked completely. And none of the strategies I've learned over 20 years of towing and backing boats, trailers, and a pop up worked completely either. On the other hand, I guess I have to say that together, maybe little bits here and there all worked, because my new 22 is now sitting in my driveway, more or less unscathed. And if I can go to bed before I open my mouth, my marriage will probably also survive.
It's 1:20 AM, and we just did an 8 hour drive, so I'm in no mental condition to figure out what we could have done differently. But, anyway, all's well that ... ENDS. Thank you all for your suggestions. I sincerely appreciate them all. In days to come I'll be reprocessing them and trying to figure out what to do right next time.
Belbein is offline   Reply With Quote
Old 03-28-2014, 04:23 AM   #30
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Now that you are home and can relax, here's an idea. Go to a toy store or hobby shop and get a remote control truck set-up. It will give you some practice without any damage to your rig or marriage. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-28-2014, 04:31 AM   #31
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Wild guess here, but try this again without the 8 hour drive at 1:20 a.m. and I'm guessing this procedure will be much easier...
Old 03-28-2014, 05:35 AM   #32
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Daylight and rest will definitely make it go smoother.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-28-2014, 05:45 AM   #33
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Get right back in saddle tomorrow, drive out of driveway, then back her in again. Again and again til u get feel for where to be. Backing up really just makes dumping an easy walk in the park!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-28-2014, 08:04 AM   #34
eliset123's Avatar
Newport , Rhode Island
I have also found that it is much harder to back in after a long drive. It's worth it once you kick back and enjoy life in the Airstream.
eliset123 is offline   Reply With Quote
Old 03-28-2014, 08:23 AM   #35
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Make sure you have rear-view mirror extensions if your rig doesn't have ones that slide out. Most important, make sure your back-up-partner shares the same directions as you. Walkie talkies are the best way for this but sometimes you will rely on hand signals. Make sure you both know what they mean. Ask me how I know. Main thing is practice, practice, practice. Depending on your TV, you can also add a front bumper with a hitch, then you can drive your AS into your driveway and maneuver very easily. Many folks with large boats do it that way, they unhook from the back and hook up to the front and then they can be more accurate in parking.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 03-28-2014, 08:29 AM   #36
m.hony's Avatar
2013 30' Classic
I have a rear view camera on the back of the trailer.
Overkill- yes, but anything helps.
It is entirely possible to back without the rear view camera- I backed for years without it.
A "guide line" helps- edge of the driveway, expansion joint in the concrete, fence, house, etc.
TAC #MS-10
Airforums #70955
Old 03-28-2014, 08:51 AM   #37
1976 31' Sovereign
Oswego , Illinois
As to 1 of my prev. replys to backing up, do as pro. truckers do, if you have power mirrors rotate them as you back up either blind side or drivers side. you can see very well, learn to use mirrors, not look over shoulder, it takes practise how to learn do this way, watch a pro. trk. driver how they back into tight spots left or rt. side with ease. Not a trk. driver but ret. rr conductor. Bill
Old 03-28-2014, 09:12 AM   #38
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
You were tired and it was dark. Would have been wise to overnight (and enjoy your first night in the trailer) if there was time. It will be *much* easier next time.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 03-28-2014, 09:44 AM   #39
Cambridge , Ontario
I would go past your driveway about 10' and keep out from the opposite curb a little bit more than with the previous trailer. Then start a more gradual angle on your backing. The new trailer will turn on its own then and will start up the driveway (if you have pulled the proper distance past the driveway (10'?), and you will have room for your front wheels of the TV because the trailer will have started to turn as you back up. I think the main thing is to take is gradually rather than try to do a sharp turn getting in. Also have some one watching the driver's side back corner to make sure that it is not hitting anything as you reverse. Good luck on getting in. Remember, it will go in, its just a matter of finding the sweet spot.
jamesa403 is offline   Reply With Quote
Old 03-29-2014, 08:13 PM   #40
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Exactly. I am inconsistent with my backing. Sometimes I am quick and smooth like a pro, other times I am awful. I am convinced that it is the approach setup.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-29-2014, 10:31 PM   #41
2012 22' FB Sport
Lake Forest , California
After reading all this it reminds me of the classic movie "The Long Long Trailer" with Lucille Ball and Desi Arnaz. If you haven't watched it you need to. After viewing this movie, nothing you do will make you feel any less then a pro. Relax, take your time and practice will make perfect. By the way. I can't back worth a damn, but the hubby's pretty good at it.
HrLola is offline   Reply With Quote
Back a 22' into a driveway? Belbein Towing, Tow Vehicles & Hitches 31 02-11-2014 08:33 PM
HELP getting 19' Bambi into steep driveway kimd8888 Towing, Tow Vehicles & Hitches 36 09-05-2012 08:01 PM
Out of the pasture and into the driveway!!! Alliesargosy All Argosy Trailers 16 03-23-2011 08:55 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
My Storage Strategy this Summer uwe On The Road... 2 04-18-2003 08:40 PM
