01-02-2015, 09:14 AM
#21
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
A 100' length of ⅜" yellow propalene rope can be laid out on the ground as a tracking tool for the inboard wheels the first few parking exercises.
01-02-2015, 09:26 AM
#22
Biloxi
, Mississippi
Three of years of trailer ownership and I am still a source of entertainment when attempting to back into a tight spot. I am not too proud to except quality assistance. I say quality assistance because some helpfull neighbors seem to have less skill than I do.
MICHAEL
01-02-2015, 09:37 AM
#23
Vintage Kin
Fort Worth
I don't worry over it. If it takes me numerous tries then so be it. On some days I get in the first time. On others, not so.
Backing is the main source of damage to a truck trailer combination in that industry. For us I'd say that great mirrors, clean glass and not being tired from a long day are all priorities.
Walk it off beforehand.
from the AIRphone
01-02-2015, 10:34 AM
#24
1993 34' Excella
York
, South Carolina
No doubt about it.....backing an Airstream into a site anywhere other than at a rally brings out all the lookers. They expect a perfect show. After all, we are the elite fleet
Even on your best day, at an ideal site, things can go heywire.
As Slowmover said, don't sweat it. Take your time, as much as you need.
Soon you will kicked back, 3 clicks in your reclining chair, sipping a cool one, admiring your pretty work.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
01-02-2015, 10:45 AM
#25
2015 25' International
Fidalgo Island
Wow. I'm taking a lot of comfort in this thread. It's good to know that I'm not alone (and when I'm backing in I usually am).
Had a backup camera installed this week, hoping that relieves some of the anxiety.
01-02-2015, 12:07 PM
#26
2013 25' Flying Cloud
ARTHUR
When you "jack-knife" your rig, you have to learn to anticipate a little ahead of time on when to begin correcting. Otherwise you'll lock up and haffta pull forward. I'd guess don't go further than about 45 ( ____/ ) degrees before starting to correct. (Yeah, I know that's more than 45*, but I'm limited to what I have to work with here)
01-02-2015, 01:49 PM
#27
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Backing into a spot
Oh, and if there are two of you: We have found we're the most successful at parking when my spouse is the driver and I am the walker-arounder / signaller. Even so, at some points in the process it works best when she climbs out and we walk it together before she hops back in the cab. Until you experiment, you won't know which arrangement of people works the best for you, and the results may surprise you.
01-02-2015, 01:57 PM
#28
2014 30' FB FC Bunk
Hoover
, Alabama
An admission:
I watched all of the yoloho videos before picking up our AS 11/2013 and I was aware of "the scoop"...but my own experience so far with my 30 foot trailer at most campgrounds so far is that it does not benefit me.
The roads around campgrounds in state parks are often very narrow, so there is no where really to scoop in the first place, but even if there was, I doubt it would be all that much help when the sites are situated at 45 (ish) degree angles to the road?
In their youtube video they depict the maneuver when backing into a spot 90 degrees to your plane of travel like in a walmart parking lot (or like most anyway) - in that case the swoop sets you up with a better starting angle it seems?
I had backed my bass boat for years before the 30 foot AS, and somehow that AS backing has just been far far more predictable and easy, albeit a tad more intimidating.
I think knowing when to correct the "jack-knife" take a while, I messed that up with my boat many times before I got the feel...now with my 30 foot AS, even if I miss the timing a bit, it did not move much when I go to correct it, so its great...but with my boat if you missed it, you had to pull up every time.
The thing I am still trying to learn about tricky backing in the AS that I never really learned or had to learn with the smaller trailer is what my brother some months back was showing me and it had to do with making corrections when pulling forward...it seems very counter intuitive to me, but I am starting to get it...if you are at an angle between TV and AS, and want to make a correction and you have little room, he started to show me how at times depending on the scenario, you often benefit from pulling up just a bit and turning the other way that is not intuitive and you use the tail end of the truck to swing the trailer in the direction you want it to start off as you back up again....hmm...not sure that made sense...surely there is a youtube video about this, as when I saw it in action I was impressed..I may be saying it all wrong and someone can explain it better...alls I know is that I have used it 5-6 times now and it helped.
01-02-2015, 03:41 PM
#29
2011 28' International
Chatham
, Ontario
Originally Posted by PharmGeek
An admission:
Other than my early attempts, I've not had too much trouble backing up. As I said in an earlier post, that scoop thing will only really work when your access road has a bit of width and, as you say Pharm, that's a luxury you don't always have. The pulling forward and getting the rear of the TV at the right angle for the next rearward move is something you get with a bit of practice. I don't think anyone showed me, but watching what happened to the rear of the trailer as I made steering inputs kind of sorted things out for me. It's a bit like the practice of turning the front wheels of your car the in the opposite direction over the last couple of feet of a solo back-up move; you're just getting ready for the next part of the process and giving yourself a few extra feet in the forward turn.
01-02-2015, 05:03 PM
#30
2012 27' Flying Cloud
W
, New England
Scoop yes.
Weird thing for me - I STILL confuse myself backing in but I went camping with a friend and was his spotter on a cell phone standing behind his trailer talking him in to the site. I was 100% correct with my instructions (turn the wheel hard left, straighten out, etc). 100%!! I thought to myself - what do I have to remember in my truck when I'm doing this....I still get confused :-(
Taking my time is crucial. I'm lucky sometimes. Other times the neighbors have a blast watching me futz with it. I've been known to take a bow once in a while :-)
01-02-2015, 05:37 PM
#31
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
That's the way. If you're going to mess up at all, make it memorable! Effortless perfection is a goal to shoot for, but it's boring as the Dickens to watch. Impressive and enviable, but boring.
01-02-2015, 06:49 PM
#32
Francisco
, Indiana
We never make reservations or call ahead to a camp ground while on a trip, we just wing it.
Stopped a Lebanon Hills campground in Ohio this summer to try to get a site. They said they were full up except for one site they don't like to rent . I ask why and they said it was to hard to back into, on a hill and a curve. I said I would take it and see if I could manage to get in it.
One of the counter personnel said they would come down and help me. Drove to the site, a little apprehensive on the way, they made it sound pretty bad. Got to the site, looked at it from the truck, pulled up and back in the first try.
Got out to unhook and a fellow across the road said great job, I've some pretty bad things happen at that site. Guy from the office showed up and said who helped you do that, I said nobody just experience.
Wonderful campground, close to what we wanted to see and friendly people to boot.
Lots of experience from being raised on a farm and still farming today.
Practice makes perfect. That's not the only time we have gotten a site because it was a difficult site to get into.
Hickory
05-22-2015, 04:37 PM
#33
houston
I'm nervous as can be to back up my airstream.
For me, with some experience backing up my bass boat, starting position is something I still don't quite grasp, especially with the long wheel base of the truck.
We've learned to chase it pretty good, but sometimes we still overshoot the ball so that the front end begins to careen to the side that is beyond straight.
Where I park my boat is a slip with walls that are, literally, like 6 inches wider than the boat trailer on each side, PLUS there is a fence opposite the door. There is no way to start straight AND there is a corner of a fence that the nose of the truck has to get past before you can crank it.
I've found that the only way to do it is to back at roughly a 45 degree angle to the door, start to turn it as the back of the trailer enters super tight on the right, and once the trailer is absolutely straight on the storage, and about 1/4 to 1/2 of the way in when that occurs.... the only thing I can do is unhook the truck, and wiggle it in the space between the boat and the fence ahead and re-attached to finish pushing straight in.
This ever happen to anyone? Thing is not matter what, by the time the boat is straight on the unit, the truck is not straight and any more reversing would simply overshoot the front of the boat and ram the left side.
It seems to me that on a campsite, with no walls 1 inch off your trailer, you would have more wiggle room?
05-22-2015, 05:58 PM
#34
2013 31' Classic
billings
, Montana
That is fine, in the real world most old campsites were for 24 footers, narrow road, and you aren't susposed to be on the grass......
05-22-2015, 06:13 PM
#35
From All Over
Agreed. Campsites aren't boat ramps, and if you're lined up a little crooked no one will care. The main things to remember are: don't run over the service pedestal and sewer hookup (if there is one), and follow the advice of George of the Jungle: "Watch out for that tree!"
05-22-2015, 07:05 PM
#36
2014 30' FB FC Bunk
Hoover
, Alabama
I learned using a bass boat - in contrast my 30 foot airstream is much easier to get into campsites - much easier
05-22-2015, 07:58 PM
#37
Green Cove Springs
Good advice!
More ideas:
Maybe go to a big empty parking lot, put out some cones and practice parking in an imaginary spot until you get the feel of it.
Remember to look up for branches above the trailer that may be lower than expected.
A rear view camera on the back of the trailer is often helpful, though for us that by itself is not enough.
Experiment to see which of you is better suited to backing the trailer while the other advises from outside. We've found that for us the DW is the best person for parking the trailer while I, the DH, advise from the outside.
If a 3rd party offers to help coach, feel free to consider their advice but remember they have nothing at stake except a little embarrassment if they put you on a rock or in the ditch.
Go slowly. Don't give any thought to the show you're providing your new camping neighbors, just take your time and work your way into the spot.
Everyone will have great ideas for the best communication methods while parking. We do the following: roll down all the windows in the truck so the driver can hear immediately if the adviser starts yelling, and use good old fashioned radios so we don't have to shout while going through routine parking maneuvers. (For us, hand signals alone just aren't enough.) We've still got a lot to learn, but we improved significantly over the course of recent our x-country trip.
05-22-2015, 08:02 PM
#38
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
I painfully watched a guy try to back in his utility trailer tonight. I really wanted to go help him. I asked my husband what he thought ( my husband can not backup at all, I do all backing) . He said don't go.,i replied that back when i first started a few nice men helped me, and I thought I would return favor. At that point the poor guy was jack knifing and another man ran to help. I felt so bad for the guy. I did notknow if my being an old grey lady helping a younger guy would have been an issue.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
05-22-2015, 08:29 PM
#39
2014 30' FB FC Bunk
Hoover
, Alabama
I watched a couple at Henderson state park last month struggle - and those spots are as easy as they come
Wife was hollering at the husband driving
05-22-2015, 08:34 PM
#40
From All Over
And two more bits of advice if I may be so presumptuous…
1 - There's no shame in aborting the attempt, pulling back out, and starting over. If you start to get into trouble and you don't immediately know how to fix it, continuing what you're already doing is more likely to make it worse than it is to make it better.
2 - Even if you have someone giving directions, it's still a good idea to stop, get out, and look for yourself. There is no substitute for seeing the space with your own eyes.
