Old 03-05-2006, 09:07 AM   #1
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Autoride...
GMC/Chevy Autoride Does anyone have a Yukon XL/Suburban with Autoride? I am considering a new Yukon XL and wondering what changes if I get it with the auto-leveling Autoride feature.
Im not exactly sure what one gets with this feature other than maybe just a little less pressure on the load-leveling hitch. Is the system designed to eliminate the need for the load-leveling hitch?
Thank you in advance for the knowledge share!
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 03-05-2006, 11:54 AM   #2
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
GMC/Chevy Autoride
I have an 05 Yukon XL with Autoride and also had an 01 Yukon with it. I think the system is designed to only bring the vehicle back to level after a trailer is attached or a heavy load has been put into the rear of the vehicle.
I believe it does not eliminate the need for a load leveling hitch.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 03-06-2006, 06:09 AM   #3
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
autoride
We have autoride on our 2001 Yukon. I like the option and it works very well. It's function is to level the vehicle with any type of a load in it. As the vehicle gets older, I hear the compressor come on more frequently.
The option is not intended to take the place for load equalizing hitches especially with a 31 foot trailer.
Good luck.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 03-06-2006, 10:14 AM   #4
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
2500/vs 1500
Mark and Kimber,
I think that the "Autoride" feature is different depending if you have a 1500 1/2 ton or the 2500 3/4 ton.
I do have the "Autoride" option on our 2500 Suburban and it does not effect the level. It does change the shock damping settings to adjust the ride quality.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
