Old 05-23-2016, 12:00 PM   #1
Surf City , New Jersey
AS tire pressure
Wanting to top off my AS tires during trips what is the best way others accomplish this. Not using air at gas stations etc. I have a bicycle style pump but after 55 or so lbs is really hard. Appreciate any ideas?
weber.roger is offline   Reply With Quote
Old 05-23-2016, 12:11 PM   #2
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
We just got one of these. Nice small size, and worked well to top off the tires.
We had to pump up the tires before hitchup so that the nose of the truck is facing the trailer tongue to get the cable to reach. You could buy a longer cable if you wanted to.
Very compact size to travel with...about the size of a standard toaster.
http://www.amazon.com/Viair-00088-88...=sr_1_1&sr=8-1
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 05-23-2016, 12:12 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
See above ^^
Most people use something along this line that can be powered off your AS or TV battery:
http://www.amazon.com/Viair-00088-88...ds=air+pump+88
SeaLevel is offline   Reply With Quote
Old 05-23-2016, 12:12 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A combination jump starter and air compressor is always a handy thing to have on the road. This is the one I carry on every road trip:
http://www.walmart.com/ip/Stanley-Fa...essor/38243753
It can be recharged from a 12v power outlet or from 120vAC, and the compressor can run off the jump starter's internal battery so it doesn't have to be plugged in just to air up a tire.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-23-2016, 01:28 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Never at a gas station unless it is lees than a 1/2 mile from home.
Tires are inflated cold.
2004 Excursion 4x4
Old 05-23-2016, 01:36 PM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
AS tire pressure
I do a reading in the morning. Write it down as to number and what is needed. Then top off at leisure, going over slightly. And correct downwards next morning.
Calls for sixty and it shows fifty eight. I add 3-5 psi. Adjusted next morning.
10% below rating is considered to be a flat. Then a replacement tire is needed.
Old 05-23-2016, 01:37 PM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We use this air compressor with the 23D and Mercedes. We have a special two pole twist-lok plug on the compressor and a #10 wire 25' two conductor extension cord that can plug into a dedicated outlet in the back of the refrigerator compartment so the unit can air both the trailer tires as well as the tow vehicle tires.
VIAIR 450P Automatic Function Portable Compressor
It is available on Amazon at a lower than list price.
Old 05-23-2016, 03:12 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I use my Sears compressor at home. If I need to top off on a trip I will use a filling station air supply. Do not see any reason not to use the filling station air. Since I got rid of the Marathons I have very seldom had to add air while on a trip. Maybe once or twice in 10 years time.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
