Old 05-20-2019, 03:09 PM   #1
2019 25' International
Washington , Washington, D.C.
Are these buttons in the OFF or ON position?
The off/on function of these 2 rocker switches for the hot water heater (either electric or propane) is not intuitive for me so I plan to label them. In attached photo, are they off or on? Looking at the off position of the Click image for larger version
ID:	341246the light switches throughout the trailer, I’m really hoping these are off.
BTW - I found the hot water switch plate in my owners manual but this specific question was not addressed.
Thanks so much.
PatLee is offline   Reply With Quote
Old 05-20-2019, 03:11 PM   #2
2007 22' International CCD
In my rig, both switches would be in the ‘off’ position
rmkrum is online now   Reply With Quote
Old 05-20-2019, 03:30 PM   #3
eagletoo's Avatar
2019 23' International
Long Island , New York
Your pic shows them in the “off” position.
Make sure you have water in your water heater and press the top of the right switch. You should hear the propane ignite. Then you will know which is which.
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi with factory towing package
Equal-i-zer Hitch
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 05-20-2019, 04:16 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
And if you’re not aware of this - it’s a little weird to me at first but when you turn on the water heater (either electric or propane) the red light in the middle flashes just for a fraction of a second to let you know it turned on. The light doesn’t stay on in normal operation. The light ONLY stays on if something goes wrong! Probably the #1 cause of that would be not having the HWH full of water before turning it on. The best way to be sure is to run water from the hot faucets in the sinks and shower until there is no air sputtering through the pipes. When you have a steady flow, you have water in the heater. Then you can turn it on from either power source.
Good luck!
Old 05-20-2019, 04:30 PM   #5
2019 27' Globetrotter
Salem , Oregon
In another thread a forum member modified these switches with led lights to indicate whether on or off at a glance. Try to search for it. Dave
NoResults is offline   Reply With Quote
Old 05-20-2019, 04:49 PM   #6
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Seems like a lot of work to fix something that isn't broken.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 05-20-2019, 04:49 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Good luck!
You must make sure the water heater is NOT in the bypass mode and full of water before lighting or turning on the electric heating element. Then light the WH in the gas mode.
Old 05-20-2019, 06:43 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
"Bypass Valve" Note:
In my 2002 Classic, the water heater bypass valve bypasses the water heater, isolating both the cold and hot water fittings from the trailer plumbing.
At some point Airstream, in their finite knowledge (pun intended), changed the design but left the name the same. In the OP's trailer, and others after some point in time, the valve's function changed from a true bypass to a cold water shutoff. Unlike the older bypass valve which is opened to winterize, the new valve is closed to winterize. Thus TGTwinkie's description using "bypass mode" instead of saying valve open or valve closed.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-21-2019, 08:12 AM   #9
Thanks everyone for all the responses. Here’s my low-tech fix:Click image for larger version
ID:	341297. (I have no idea if I managed to attach the photo but here goes.)
Old 05-21-2019, 09:29 AM   #10
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
That happens to be the On/Off positions for all switches of that type in the AS. The one on the right of the picture is in the On position for the bathroom ceiling light.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 05-21-2019, 09:31 AM   #11
2015 25' Flying Cloud
Blue Ridge , Georgia
I look at my light switch and and if its on it matches the hot water switch thats on.
Gleverett is offline   Reply With Quote
Old 05-21-2019, 09:39 AM   #12
Bettendorf , Iowa
That would depend on your definition of broken.
Rltports is offline   Reply With Quote
Old 05-21-2019, 10:22 AM   #13
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Originally Posted by PatLee View Post
Thanks everyone for all the responses. Here’s my low-tech fix:Attachment 341297. (I have no idea if I managed to attach the photo but here goes.)
That picture is correct.
I am planning to get these.
https://seeyoudowntheroad.com/pages/switch-aware
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 05-21-2019, 11:32 AM   #14
Mollysdad's Avatar
Off.
But I expected the light to light when "on" and it doesn't.
I learned the light alerts you it failed.
I used the low tech method. Flip switch, wait 15 minutes, feel for hot water. Worked!
Mollysdad is online now   Reply With Quote
Buttons on Baraldi range hood loberg General Repair Forum 5 09-10-2015 11:34 AM
Ceiling buttons badkat General Interior Topics 0 10-25-2014 04:48 PM
How are the upholstery buttons installed? m.hony Upholstery, Blinds, Walls & Interior Finishes 4 11-17-2012 06:45 AM
Where can I get these early 60's curtain buttons? RichardT Upholstery, Blinds, Walls & Interior Finishes 15 05-22-2006 10:20 PM
