Old 02-19-2010, 07:38 AM   #29
AZ-JH's Avatar
Peoria , Arizona
We leave home with a full fresh tank plus carry bottled drinking water to avoid drinking from unknown sources. We want the convenience of having the water we need for comfort on the road. The added weight doesn't seem to make any difference on our gas mileage.
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
AZ-JH is offline   Reply With Quote
Old 02-19-2010, 07:40 AM   #30
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have a new fresh tank so I will drink the water. Our old one had a layer on the inside of something..... You still get that plastic taste if the water is in there for a day or so..... We bring drinks and a four gallon water jug for drinking mostly. I sanitized my tank last fall, but you can't get every drop out!!!!! Nice thing is my tank is under the couch so I can see it...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-19-2010, 07:42 AM   #31
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by THEPILL View Post
Going out this weekend and the water at the S.P is not drinkable. A SALINITY issue. Who takes along their own water.......and weight?
Just wondering.
Shane
I always leave home with a full tank. You never know where your journey will lead you and water is the basis for survival. In my case she tows better since the water tank is over the axles.
Michelle TAC MT-0
Sarah, Snowball
Old 02-19-2010, 07:43 AM   #32
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Gen Disarray View Post
I run straight 'city' water. There is no reason to add bleach to treated water. If you can smell anything over the slightest amount of bleach you have way to much in the water. In fact, if the water is properly treated you should not be able to detect the bleach at all. The amount I described is to 'shock' the system.
I want to say something like 8 drops per gallon is sufficient to make untreated (clear) water safe to drink ( thats from memory so check that). BUT that is untreated water not already treated water. Big difference there. If you use bleach to treat water it MUST set for a half hour minimum before use.
It's difficult to be exact because it depends on the temperature, pH, and clarity of the water and the strength of the bleach. Bleach loses its strength over time in typical plastic jugs.
If you can fill from a city water system that's already treated with chlorine, that's probably best. They measure the residual chlorine in the water constantly which is really the only way to get it right.
Old 02-19-2010, 08:00 AM   #33
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Steve & Susan View Post
We bring our own drinking water (3 gallon jug and some bottled water) and we use that for making coffee too. We use park water for everything else. We do sanitize the system every year so park water is probably safe to drink, but we still bring drinking water from home. Nothing is worse when Streaming than the effects of bad water!
I will note that coffee or tea is ordinarily safe to drink even if the water used to make it is of doubtful microbiological purity.
Old 02-19-2010, 08:02 AM   #34
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
All this talk of water purity
Anyone here remember the use of iodine...both drops right from the bottle or special water purification pills?.....This was before your time for many .
Along those lines...how about putting the iodine in a "Lister Bag" I guess it would work in an Airstream water tank.
Old 02-19-2010, 08:17 AM   #35
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
my how a thread can wander
Used that for years backpacking and canoeing the backcountry. It leaves an awful taste to be sure. As is with using chlorine, time is very important to get good result. And the colder the water, the longer the time required to get desired results.It is also important to remember to flush out the lines with clean water- the treated water has to get everywhere in the system.
I doubt many find need to purify water on the road (although I sometimes do due to my boondocking proclivities). When I find myself needing to extend my fresh water while boondocking with a water source nearby, I tend to use the untreated water for dishes, showers (I have a portable propane camp shower), and some cooking if I know the cooking will be sufficient to sanitize the water. Doing this easily extends my fresh water supply to a week and a half to two weeks. I also carry a couple 7 gallon jugs and it is rare that a chance to fill these up somewhere over the course of a week doesn't occur.
OTOH, if the idea is to periodically sanitize your fresh water tank, the method outlined previously should give good results in terms of maintaining your tank free of colonies of icky things.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-19-2010, 08:27 AM   #36
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I have been camping in RVs since I was 14 (52 years) . It has never occurred to me that I couldn't drink the water from the water tank, and I'm still alive.. When I fill it at home, I am putting already chlorinated treated water into it. If I fill it at a campground, I fill it through a high quality in line filter. When we stop at a campground with water hook ups, (which is 90% of the time) I always have the same type of high quality in line filter. Unless there are dead bodies laying around the campground, I have no problem with drinking the campground water through my filter. Of course I don't camp in swamps or in Bangladesh, where I think some of you must have been going.
I have never heard this concern come up before I joined this forum, although maybe I haven't listened in the right places. Perhaps this is an off shoot of the recent affinity our culture has developed for small bottles of water everywhere. I always assume that they are just water out of someone else's tap. After all the recent bottled water exposees, I am more concerned about them than my tap water.
For those who say you see dirt when you flush your tank, I wouldn't even wash with that water.
If I didn't trust the water from my tank after thoroughly cleaning it, I would replace the tank.
Regards,
Ken
Old 02-19-2010, 08:35 AM   #37
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our Java is a needed fluid in the total enjoyment of our Dock'n experience, as such, the careful monitoring of the conceiving process is paramount.
Perfectly potable not withstanding... odiferous & taste free water is my reason for not using the more than adequate storage ability of the Airstream.
Plain speak...it stinks after a few warm daze....and my noze reaches the cup first.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-19-2010, 08:59 AM   #38
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Regards,
Ken
Thats pretty much my position too Ken.
Rodney
and the
My Blog
Old 02-19-2010, 09:05 AM   #39
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The water we get in one gallon jugs is distilled, so there should be nothing in it but hydrogen and oxygen. The gallon jugs with "drinking water" in them—who knows where that comes from?
We sanitize in the spring. The proportions of bleach to water are listed in our owner's manual. Chlorine loses it's effectiveness rapidly, so mix and use immediately. We put the solution in the tank and then run it through the lines until it comes out each faucet. First I'll run fresh water through the system to wash out the antifreeze. I don't know how antifreeze and chlorine react, but I don't want to find out. So the regimen is flush with fresh water, fill with chlorine treated water and let stand for several hours, then flush over and over with fresh water until there's no chlorine smell. That final series of flushes is usually three.
We sanitize again in mid summer. Maybe we're overdoing it, especially since there's a water filter under the sink (though bathroom is used for brushing teeth without filter), but waterborne diseases are no fun. We have been to places where the water is suspect. I remember a motel in Nova Scotia where the water was salty meaning ocean water was getting into the well and yellowish water in Newfoundland. We know people who got sick somewhere along the Alaska Hwy because the CG water came directly out of stream—something they discovered too late.
Boiling water for coffee and tea helps if you boil it long enough—I think the standard is 5 minutes.
Most city water in the US in Canada is fine, but mistakes are made, inspections are infrequent. A lot of CG's use well water and that water in many places is never tested.
Gene
Old 02-19-2010, 09:16 AM   #40
Ag&Au's Avatar
I guess my nose is not that refined. But, maybe it is a blessing.
I spent the first 50 years of my life in the Seattle area. Some claim it to be the coffee capitol of the world. It is the home of Starbucks. Until I finally quit a few years ago, I used to drink a lot of coffee, but wasn't very fussy about quality. But in my case I think it was more of a drug than a pleasure.
Regards,
Ken
Old 02-19-2010, 09:26 AM   #41
Ag&Au's Avatar
Did you know Gene, that as soon as you open it, it starts to absorb carbon dioxide from the atmosphere and forms carbonic acid?
That sounds scary to me.
Regards,
Ken
Old 02-19-2010, 09:38 AM   #42
Regards,
Ken
Drug & Pleasure?...one of the few left to us here on the right coast.
PFC
"Tahawus"
RLC
John Prine
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 02:18 PM
