Originally Posted by Countryboy59
You're driving semis? Scary.
Compared to you, what I can do at the wheel is another realm.
But three days of “agony” as your left seat instructor would open your mind.
Don’t think yourself above average until you’ve put it to the test. When you have, it should make for some funny stories by all. Being “able” is t bragging when one can do it. One has to learn limitations, not assume them, when it’s life and livelihood. Not assume Divine intervention.
Leaving out for now the usual bad vehicle spec and tests for hitch rigging, you can start by practicing with gators. Truck tire treads.
When you can consistently place the steer tires AND the trailer tires within four inches of said gator at 68, we can put you in an eighteen wheeler on a day of high winds and have you do the same.
And then do it with no use of the mirrors. And always in traffic. Predicting how much lean that trailer has and how to put the right amount of English on it takes time. Skill is acquired. There will be a day it’s used.
Once you’re this intimate with the rig, harder tests begin.
Because some truck drivers are poor doesn’t mean a thing. There are men out here to whom you already owe an apology. Bad driving. A moments lapse. To them, it was just another day at the office, even as it saved your bacon.
This is a realization you should have had as a teenager.
If you can’t see the consistency of what I’ve advocated about vehicles, rigging, and driving — all of it from experience — then one is left to wonder at what has penetrated that thick skull (said with a smile).
Is my being at the wheel a scary thought? It should be.
Your clue to that past your opinion of me
should have been the information that truck drivers are held to a higher standard. Had it subsumed as knowledge after experience, it’s that I had been pulling these trailers of ours more than twenty years before climbing into a truck cab. Believe that it’s sobering as to one’s skill and you’re on the right track.
So call it perspective. And a big year of vacation travel for “you” (whomever) be it 5 or 15,000 miles is a just few weeks for me.
So, agree or disagree.
But test it. Then there’s something to talk about.
If what I see on the road was otherwise, you would t see me stick my neck out around here. The evidence
of having done a good job with the rig or in the driving isn’t present in aggregate.
So the topic of AS speed limit:
it’s traffic volume with spacing as the control. And that is after having tested for total braking distance. Reaction time plus time to stop.
Less than six seconds?
Prove it.
I get it that you don’t and won’t. Using a scale is like pulling teeth around here, simple as it is. So use the commercial standard. In aggregate they’re better than you. And for them it’s six seconds. Always strive for 700’ or better —
its the goal — and make it a rhythm. A waltz.
You can do that THEN you’re on vacation. Momma and the kids doze off after lunch when you’re into the gnarliest traffic of the day
And they’re undisturbed
You might be improving.
The test is in not ever varying. No outward excuses.
(Think you’ve got that? Well, there are tests to confirm that as well. You against you).
