Old 09-24-2014, 04:27 PM   #1
venice , Florida
Airstream on the way
We have purchased a 1997 limited 34' Norman Rockwell
It is our plan to park it at our home at least for now.
We have the room but there will be a little downslope side to side
Should I use leveling blocks or should I have it backed in where we want it and jack it up and place the blocks under it.
We don't have a tow vehicle so we will need to keep it where it sits until we get one.
Thanks Mark
markgillett is offline   Reply With Quote
Old 09-24-2014, 10:18 PM   #2
2014 27' Flying Cloud
Wenatchee , Washington
I'm pretty new here, although I bought my first travel trailer in 1990... and we bought our AS last May (and we've already dealt with a flat tire). I've (successfully) tried to avoid jacking up my trailers, I feel leveling blocks put less stress on the trailer. I realize our AS's are well built but why risk damaging your trailer (when leveling blocks are so easy to use).
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 09-25-2014, 07:32 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
In My Opinion. And it's worth about as much as you paid for it. You only need to worry about it being level if you plan to use it in that parking spot. In my northeast area I might also worry about water settling into a low spot and freezing but I don't think you have that problem. Putting some boards on the low side to bring it close to level is certainly easy and I might be so inclined ( pun intended) but I don't think you need to.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
2 way or 3 way Stefandmissy General Repair Forum 12 05-04-2014 07:59 PM
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 02:08 PM
2-way vs. 3-way Dometic loriday Refrigerators 12 08-15-2010 09:21 PM
2 way or 3 way Refrigerator? New or Old? prairieschooner Refrigerators 10 09-13-2006 09:45 AM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
