Old 05-12-2011, 09:03 PM   #1
2009 23' International
Boulder , Colorado
Air pressure 23 ft 09 international
In a pinch don't have the manual.
Anyone know how much air to put in my trailer tires?
Thanks! Tom
tmarquis is offline   Reply With Quote
Old 05-12-2011, 09:11 PM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
If you look by the serial number on the street side of your Airstream you should have a plate that tells you what tire pressure Airstream recommends.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 05-13-2011, 08:08 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Check the info on the tire sidewall. Tire inflation may vary with tire type, construction and manufacturer so to be sure you should check the tire.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-13-2011, 08:38 AM   #4
wilkeytn's Avatar
2008 23' International CCD
Nashville , Tennessee
50psi in the 14 inch tires
wilkeytn is offline   Reply With Quote
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
Does NADA have any bearing on reality? International 23D smeghead Trailer Values 20 04-13-2011 01:18 AM
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
