Old 07-13-2016, 10:43 AM   #1
Golden , Colorado
Advice on tow vehicle with best gas mileage
My husband and I are looking at purchasing a used/newer model 25-27’ Airstream and would appreciate any advice you could give on which type of tow vehicle gets the best gas mileage. We are considering a Ford F-250. Also wondering or seeing if anyone has suggestions on how to calculate how much we might be spending on gas? I know that's a difficult/loaded question but any insight would be helpful. We are in the very beginning of our research so our knowledge is limited. Thanks!
kekimball3 is offline   Reply With Quote
Old 07-13-2016, 10:57 AM   #2
2014 25' Flying Cloud
New Ashford , Massachusetts
With out factoring in the initial cost of the TV (gas vs diesel)
I have a 2009 Dodge 2500 Diesel and a 25ft flying cloud. MPG range towing 14.5 to 16.5. So many factors weight, terrain, traffic conditions, air temp, ect, come into play. But the reality is a 25-27 ft trailer and the power needed to tow it will prevent any real MPG fluctuations. Gas truck or SUV, Diesel truck or SUV I can't see anyone doing much better that 17MPG and maybe as bad a 10mpg.
Fuel cost is a necessary evil if you want to travel. The unpredictability of the cost per gallon of fuel will have a more profound effect on the cost than a few MPG here or there.
Joe D
Dexterpix is offline   Reply With Quote
Old 07-13-2016, 11:54 AM   #3
Alluminati's Avatar
St. Louis , Missouri
Diesel will give much better mileage than gas. Your driving style will be the next biggest factor.
Pete bragged to me that his 36' class A diesel towing a full size Chevy PU got 10 MPH because he never drove over 55 MPH. Rodney was getting 6 MPH with his 5th wheel going 75 MPH across the northern plains.
The Morgans
1989 Avion 34VB
Alluminati is offline   Reply With Quote
Old 07-13-2016, 12:27 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you are going to put 10s of thousands of mile per year towing it should not be a consideration. The difference per TV in a given generation will take way too long to amortize on fuel mileage.
Get what you will be happiest driving.
The maintenance costs of a diesel are much higher but if you are really traveling and intend to keep it for 5 years or more than diesel is the answer.
As President of my companies credit union I always had trouble talking members out of buying a new car just to save gas. The hundred or so dollars saved per year did not quite justify the cost of the new car. I lost more often than not.
2004 Excursion 4x4
Old 07-13-2016, 12:49 PM   #5
in the rising sun toaster
1956 26' Cruiser/Overlander
Wimberley , Texas
I consider form (e.g. mpg/cost) only after considering function (e.g. power/capabilities). Fuel mpg calculations and a knock-on "what TV to buy" decision, and, what the pump prices may be, and what total COO becomes just haven't been worth my time to pay attention to for a very long time now because towing, vs. not, invariably results in the lower end of mpg ranges w/ attendant higher fuel costs, and these no matter what TV is in question. At one time, I did pencil-whip claimed mpg's into cost-per-mile and etc. but these exercises proved, to me, that mpg a/o pump-price differences are just not *that* different, certainly not different enough to "drive" my TV buying decision, not different enough to continue the pencil-whipping exercises, and certainly not different enough to compromise on the important functions: the TV's real-world capabilities, or, will my TV meet/exceed the expected situations? and, will it *do* what I need it to do *when* I need it to do it? If we're going into mountains, or when doing a lot of Interstate miles, or especially for urban freeways, then it's the 8.1l Yukon XL 4x4 2500 that we'll tow with, hands down, due to its over-abundance of power and acceleration capabilities, which have allowed me many times to simply and quickly drive out-of/away-from problematic situations (e.g. mud/snow/steeps/sand/etc.), and away from "bad moves" made by other drivers on the road; otoh, if predominantly flats or country roads' lower speeds, then it's our trusty old 5.7l Suburban 1500 we'll take. Both tow just fine in any normal situations, but, for abnormal situations, or if I could have only one TV, then it would be the much more capable 8.1l Yukon XL 2500 4x4.
rsjmcg is offline   Reply With Quote
Old 07-13-2016, 01:20 PM   #6
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
For that size trailer you'll want a full size truck or large SUV. Gas will get about 10 to 13 MPG. Diesel a couple miles per gallon better. As others already mentioned, this is a secondary issue. If fuel consumption is a concern look to a popup trailer as air drag is a huge factor in determining fuel burn.
kscherzi is offline   Reply With Quote
Old 07-14-2016, 12:32 PM   #7
1978 31' Sovereign
Grimes , Iowa
We have a 2005 F250 super duty xl. pulling a 31' as we were getting about 8-10 mpg. We have the 5.4L gas engine.
We just purchased a 2016 Nissan Titan XD with 5.0L diesel. Will be curious to see what we get for fuel mileage....
tewfiks is offline   Reply With Quote
Old 07-14-2016, 12:35 PM   #8
2017 27' International
Box Elder , South Dakota
I just bought a brand new 2017 27 foot AS Serenity. New to RVing. I am not even buying a TV until I live in the AS for a while and understand what kind of hitch, etc I need. I'll have the AS towed around by professionals until then.
alphamale49 is offline   Reply With Quote
Old 07-14-2016, 12:40 PM   #9
FCStreamer's Avatar
2014 30' Flying Cloud
I like this advice. Focus on getting a vehicle you can drive daily. The difference in mileage in modern vehicles is not enough to be worrying about it that much. Towing will impact your mileage, of course, but unless you tow every day, who cares? I drive every day though, so my tow vehicle needs to be comfortable and easy to park.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 07-14-2016, 12:50 PM   #10
Lovin' the Mountains
2015 25' Flying Cloud
Pine , Colorado
I recently purchased a GMC Denali with a 6.2L engine to tow my 25' Flying Cloud. Incredibly, towing I get on average 12 mpg; not towing at highway speeds I average 24 mpg.
tomsos is offline   Reply With Quote
Old 07-14-2016, 12:55 PM   #11
palm beach gardens , Florida
I just did 8000 miles through the mountains out west and averaged 13.1 MPG with my 2500 GMC PU diesel towing a 25 Safari. I don't think there is a much better TV but it is a little big around town. However, I am use to it and it begs me to hook up to my AS and go!
m rafferty is offline   Reply With Quote
Old 07-14-2016, 01:14 PM   #12
1994 25' Excella
Saratoga , California
I think a Tesla X will give the best mileage.
Steve 6919 is offline   Reply With Quote
Old 07-14-2016, 01:20 PM   #13
belen , New Mexico
my 97 f250 PS Deisel 5 speed manual avg. 18 to 20 mpg towing a 77 ambassador
alantbird is offline   Reply With Quote
Old 07-14-2016, 01:44 PM   #14
1996 25' Excella
Tillsonburg , Ontario
Smile
Interestingly, The AS shape is better at air drag than even a smaller trailer with boxy shape. I routinely get 10.5-11 mpg with my 25 foot and I only get 10.5 puling an 8-foot U-haul on the same truck
JCW
JCWDCW is offline   Reply With Quote
Old 07-14-2016, 02:49 PM   #15
2012 30' International
Dallas , Texas
We pull our 30' International with an F250 with the 6.7 diesel, and we average about 15 mpg, with most of our miles out west, in Colorado and New Mexivo.
russingr is offline   Reply With Quote
Old 07-14-2016, 03:00 PM   #16
2010 27' FB Flying Cloud
Kansas , Topeka
We pull a 27FB FC with our 2012 F250 Diesel and average 13-14 MPG overall at 65 MPH day in day out on flatland, desert or high mountains. The most we ever seen diesel fuel sell for was Reno NV in 2012 at $4.44 a gallon, now it's $2.15 down the street. I never worry about MPG or cost as we made the commitment to travel and feel that a solid investment in the "front office" to get the "house" to where we want to go safely and with dispatch is the price we pay to chase our dreams. I do not use the 250 as a daily driver however so no real test on non-tow mileage.
BDowse is offline   Reply With Quote
Old 07-14-2016, 03:05 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our Ram 1500 Ecodiesel gets 16-17 pulling our Airstream 25 FC in normal conditions. Most of our driving is without the Airstream where it delvers 28-29 mpg on the highway. It is the 8-speed transmission that makes the complete power train here, and the 3.92 axle gears work well with a mid-size Airstream.
The are several SUV's with turbodiesel engines in the 3.0 liter range that deliver great economy and the owners are quite happy with them towing their Airstreams.
Doug and Cheryl
Old 07-14-2016, 03:30 PM   #18
Road Ruler's Avatar
Images: 38
Not much difference really. We got 19 MPG towing a 2,000lb Coleman pop up and 16MPG towing the 23' Airstream. Note imperial gals.
Old 07-14-2016, 03:44 PM   #19
2015 28' Flying Cloud
Newtown , Pennsylvania
These MPG threads are always so entertaining. I'm going to get my trip computer recalibrated. Then I'll be back.
Bruce
AstroBruce is offline   Reply With Quote
Old 07-14-2016, 09:29 PM   #20
Mark and Marilyn
Joshua , Texas
Tow Vehicle
I am going to step into this discussion and sing the praises of a Diesel. I have a Dodge Cummins with 150,000 miles on th clock. I pull a 34 foot Avion. I have pulled lighter trailers around 7000 lbs with V8 gas and they always seemed to be working hard with the load. Downshifting on small hills, no engine brake, high RPM. The Cummins is a 2012 800 foot lbs of torque at 1700 rpm, when pulling torque is king ask any truck driver. With the Avion the truck sits at 1700 RPM at 65 miles per hour and that's it no straining no shifting. Need to slow down the engine brake and the transmission work together to slow things down. I am not certain what the Avion weighs(My wife packs heavy) but likely over 10,000 lbs. on the road at 65 you can't here the engine run. We average 12.8 MPG., With the wind seen 14.5, against the wind under 11. Go out and look at a good used Diesel they are 300,000 mile setups easy, likely more. Purchase a Vehicle to tow and you won't regret it. And never wonder how your going to get the next home improvement project home from The building supply store.
Mpohly is offline   Reply With Quote
Tow Vehicle Advice 1500, 2500, diesel, gas??? Ed Brownfield Tow Vehicles 128 06-29-2015 03:52 PM
Duramax/Tow Haul/Gas Mileage xo1rider Tow Vehicles 28 02-13-2013 07:37 AM
Gas mileage in tow mode or not BessieB Tow Vehicles 13 05-31-2012 01:00 AM
Tow Vehicle gas mileage, towing & norm Denbear Member Introductions 10 04-16-2008 08:10 PM
Tow vehicle Gas Mileage ??????? searcher Tow Vehicles 79 04-02-2006 12:24 PM
