09-16-2018, 01:40 PM
2014 23' Flying Cloud
Fair Oaks
Adequate tires for tow vehicle?
On a recent trip, we had a puncture from a sharp rock. While the mechanic was repairing the tire, he mentioned to me that I shouldn't even be using those tires on my F250 diesel pickup. The tires were Bridgestone P275/65R18, installed at a Firestone store at the recommendation of the salesman there, because I asked for tires that would be good for towing long distances. I'll admit they gave me a comfortable, quiet ride, but were almost bald after only 27,000 miles, and according to the tire repairman, I was lucky because the greatest risk was of a blowout because of inadequate sidewall protection. He said the P designation meant passenger car, but what I wanted was LT, which means light truck.
Since they were almost bald anyway, and we were a thousand miles from home, I didn't want to worry about it all the way home, so I replaced them with Michelin LT275/65R18, which the Michelin guy told me were wonderful for towing and would last me a lot longer than 27,000 miles.
As you can tell, I don't know much about tires, just what people tell me. But now I know enough to ask for LT's instead of P's, and I wonder why the Firestone guy sold me P's to start with?
09-17-2018, 07:01 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I don’t think it is quite that simple. My 2008 Tundra came with Michelin LTX M/S2-P255/70R18 112T (51 psi). I put about 50,000 miles on the Tundra. When it was time to get new tires I considered going to a heavier truck tire (80 psi) but a knowledgeable tire person on this forum told me that was not necessary. He basically said that the engineers had selected this tire for the Tundra and he saw no reason to change to a heavier duty tire. I replaced the tires with the same original Michelin tires. I just recently replaced them again at 95,000 miles. I could have waited at least 5,000 more miles, but I wanted to improve my wet weather tire performance so I replaced them early. I am now using the quarter test rather than the penny test.
Dan
09-17-2018, 07:06 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Never being a Firestone fan... Im on my third set of Firestone Transforce AT tires.
I got 137000 miles out of my last set, and seeing a shade less than 90000 on these and only 50%. I inflate hard, and rotate like a madman. Really enjoy towing with these tires.
09-17-2018, 07:13 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Take a look at what type of tires Ford put on your 250 / puts on new 250's. I don't think you will find that they set them up with passenger tires.
Why did the Firestone guy sell you P series tires?
1) He didn't have LT's in stock
--or--
2) He got a better commission on the P's
--or--
3) The shop had a *lot* of the P's in inventory for a *long* time ....
--or--
4) He is a member of a secret sect that is out to kill you
Take your pick ....
09-17-2018, 07:30 PM
Dazed and Confused
Hillsburgh
, Ontario
The very same reason you should never use P series tires on a trailer; ST series tires with a stiffer sidewall are used for trailers. The difference can be epic.
A P series tire on a 3/4 truck is trouble rolling down the road; especially towing anything.
Cheers
Sidekick Tony
09-17-2018, 07:36 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
THESE?
Yes..
You made a very good choice. 👍
09-18-2018, 02:14 AM
Fair Oaks
Yes, those, with the E load rating.
09-18-2018, 07:15 AM
2018 30' Classic
Jacksonville
"....but were almost bald ...."
Doesn't much matter the type, rating, number of plus, color, etc. Once tread depth is gone it is unsuitable for any trip, towing or not.
09-18-2018, 07:31 AM
CapriRacer
I'm in the
, US
First, check your vehicle tire placard to see what Ford specified for your vehicle. The placard will be on the driver's door frame - in yellow!
You didn't say what year your F250 was but if I assume it is relatively recent, some F-250's did indeed come with LT275/65R18 LR E's inflated to 70/75 - which makes what happened at the F/S store even more incomprehensible.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
09-18-2018, 07:47 AM
Fair Oaks
You are correct, of course. The treads were still above minimum legal depth, which is why the tire repairman was willing to repair the puncture. However, they were beginning to look a little bald, and I probably wouldn't have gotten a puncture from a sharp rock if the treads had been a little higher. It's just that I had a hard time believing they were almost worn out after 27,000 miles.
09-18-2018, 07:56 AM
Fair Oaks
The F250 is a 2015, and did in fact come with the LT275/65R18’s, as you describe. I know that because that is what the spare tire is, which is the same as the original 4 that were mounted. At the time I bought the replacement tires, I didn't know the difference between LT and P. I just assumed that if I went to a reputable dealer like Firestone, they would set me up with what I needed for towing. I have nothing against Firestone tires, and have used them many times for many vehicles over my life. The main reason I’m writing this is so other people who don't know the difference between LT and P won't make the same mistake I did.
01-14-2020, 08:26 PM
2019 27' Globetrotter
McHenry
AtomicNo13, I found your post while searching on TV tires and yours caught my eye.
I've got a 2019 RAM 2500 with 20" Firestone Transforce AT's as well. Mine are terrible in wet or snowy conditions - spin on 1/2" of snow or pulling away from a stop sign on wet pavement. Living in Colorado I assume you had plenty of in-climate weather.
I've only got 5600 miles on these but am seriously considering a set of Michelin Defenders or Continental TERRAINCONTACT H/T's
What was your experience driving in those conditions with the Transforce AT's?
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
01-15-2020, 06:24 AM
CapriRacer
I'm in the
, US
Jeffmc306,
The tires on your truck will be different than what AtomicNo13 has on his truck even though they have the exact same name on the sidewall - and I don't mean just size. That's because vehicle manufacturers write specs for the tires that go on their vehicles, and the tire manufacturers modify their tires to meet those specs - and those spec are different than what tires at the tire dealer are built to.
So his experience will have no bearing on what you might experience.
I go into more detail here: Barry's Tire Tech - OE Tires
CapriRacer
01-15-2020, 11:08 AM
2014 19' International
Port Townsend
In all due respect I think "his experience will have no bearing..." is a bit strong. There are certainly some, many would say a lot, of correlation if the manufacturer and the model are the same. That said each person's driving capabilities, specific weather conditions, varying loads etc all make for inexact comparisons but all in all I would value the input of someone with a similar tire.
01-15-2020, 03:41 PM
McHenry
CapriRacer, thanks for sharing the link with reference to OEM tires. I do understand manufacturers will write specs that are different than aftermarket tires.
I meant no disrespect to AtomicNo13's experience with his Transforce AT's. However, he did have an OEM set before replacing them. I was curious because the ones on my 2019 are just awful.
I did check TireRack's reviews of others and they had similar comments. The tire finished 6th out of 6 on TireRack's ratings. The frustrating part is RAM could spec a better tire but perhaps due to contractual commitment with Firestone (amortized cost over time), they keep using these. They still cost over $300 per tire new.
My dilemma is do I roll the dice and keep them until they wear out and hope I don't need to stop quickly/take defensive maneuver on wet pavement or bite the bullet and get the Michelin Defenders or equivalent?
*I just read some new posts on TireRack's reviews - one had the same experience as mine (lives one town away) and another said he has no complaints. Go figure!
2018 FC23FB
WBCCI# 10258
RETIRED!
