Old 04-17-2008, 11:12 AM   #1
Mr. R
trogers713's Avatar
1984 34' Excella
Rogersville , Missouri
Question 31' AS vs 25' AS Vintage Models, late 70's
Does anyone know if there is much difference in pulling a 31' AS vs 25' AS? Would the milage be much difference? How about the handling.
Thanks...Tim
Tim Rogers
Rogersville, MO
"Where there is a will, there is a way"
Have a great day!!!
[IMG]images/smilies/wally.gif[/IMG]
trogers713 is offline   Reply With Quote
Old 04-17-2008, 11:16 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Fuel consumption would be about the same, acceleration would be better with the lighter trailer.
Old 04-17-2008, 01:22 PM   #3
dmreilly10000's Avatar
1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
I think that the 25 would be much easier to tow. I have owned a 34' and two 25' Airstreams and the 25' Airstreams were much, much easier to tow.
dmreilly10000 is offline   Reply With Quote
Old 04-17-2008, 02:10 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
It's really a weight issue and the length of the unit itself. I went from a 27' Safari to a 31' Classic slide out. Is one easier to tow than the other? Well there is a obvious weight issue which amounts to 2,000 lbs more weight. Yep the 31' trailer is longer so I have to take that into account. Neither of which in my case makes one more difficult than the other. The key is the tow vehicle and I can guarantee you that if I had been using my old half ton van, it would have been a much more noticeable situation and I'm sure ease of towing would be a much more clearly defined issue.
Both trailers were towed by the same 3/4 ton 6.0 liter 4.10 axeled GMC van. Difference in gas mileage? Maybe one mpg.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-17-2008, 04:25 PM   #5
Mr. R
trogers713's Avatar
1984 34' Excella
Thanks for the info. My wife would like to go down to a 25' but I hate to give up the room.
Tim
Tim Rogers
Rogersville, MO
Have a great day!!!
Old 04-17-2008, 04:33 PM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Tim
Tim,
I guess you didn't know that all 25 footers ever made are subject to sway and bursting into flames. This is caused by a design flaw in the reverse thrust manipulators.
For the sake of your families safty you'd better keep that 31 ftr. They are proven to be safe and there's really not a noticible difference in fuel mileage.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Quality of the '70s models wahoonc 1974 - 1979 Sovereign 28 12-10-2010 01:29 PM
Somebody with a 31' Late 70's Airstream wacnstac Cabinets, Counter Tops & Furnishings 4 08-21-2006 10:34 AM
How prevalent are leaks in late 70's era airstreams? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-03-2006 06:46 PM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 06:10 PM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 12:46 PM
