Old 01-20-2015, 02:19 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
30 amp question
Newbie question. My new FC 28 will have two AC units with 50 amp service. If I'm camping with only 30 amp service, will I still be able to run one AC unit? Am I correct that I'll need a 30 to 50 amp connector? Help me understand what I'll need.
DeltaRon is offline   Reply With Quote
Old 01-20-2015, 02:24 PM   #2
dznf0g's Avatar
Oswego , Illinois
yes on both questions. But you'll need to learn that cumbersome thermostat to command one zone or the other.
-Rich-
Old 01-20-2015, 02:46 PM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Yes to both questions, however, in addition when operating with 30 AMPS it is advisable to not run the micro wave and the A/C etc. Try to refrain from overloading, when the A/C kicks on is when it draws the most and if the Micro is on or someone is using a hair drying you will trip the circuit breaker - they are in a box under the refrigerator or near it, at least in mine that is where they are.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-20-2015, 02:59 PM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
For the cable connection, you will want something like this:
http://www.amazon.com/Camco-55185-Po...50+amp+adapter
These are also available at just about any RV store.
Bob Martel
WBCCI# 5766
Old 01-20-2015, 03:34 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes, you will still be able to run one AC unit. Yes, you will need a 30 to 50 amp connector, or better still, a 30 amp cord, like this:
Marinco Park Power 50-Amp Locking Adapter with 25' 30-Amp Cord - Marinco 124ARV-25 - Electrical Adapters - Camping World
That way you will not need to pull out the heavy and expensive 50a cord except when you intend to run air conditioning, and have 50a service available.
He has the new thermostat, which is supposed to be better.
What paiceman is trying to say is that you can't use more than 30 amps if 30 amps is all you have available. I put in a meter to measure the amps being used (a search will turn up a thread with photos and part numbers). The big loads are the air conditioners, microwave, and water heater, and any appliances you plug in that produce heat. You can run one of those, sometimes two.
We have at times been able to run both air conditioners on 30a service if we run the fridge on gas and shut off everything else, including the converter.
Old 01-22-2015, 11:53 AM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Or you could save major $$ and use this $20 adapter Power Grip Adapter - 30A Male to 50A Female - Camco 55185 - Electrical Adapters - Camping World
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Samsung tv goes on & off & on & etc jump Electronics & Connectivity 22 03-03-2015 06:01 PM
50 amp to 30 amp pigtail question Rawn77 Electrical - Systems, Generators, Batteries & Solar 14 07-10-2014 03:55 PM
20 Amp or 30 Amp, that's the question Jim & Susan Electrical - Systems, Generators, Batteries & Solar 60 05-28-2010 01:37 PM
