Old 08-31-2009, 01:36 PM   #1
brownseyes
2003 30' Classic
live oak , California
Rivet 30 amp enough for AC?
i just purchased a classic 2003 and was wondering if 30amp at a campsite will run the airconditioner?
brownseyes is offline   Reply With Quote
Old 08-31-2009, 03:45 PM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Runs them just fine. I would think you would have no issues with 30 amps of power in your Classic. Welcome to the group,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 08-31-2009, 04:03 PM   #3
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Yep.
Welcome!
Alwhisman is offline   Reply With Quote
Old 08-31-2009, 04:16 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
A 30 amp campground power outlet should be plenty to run your whole trailer, including the air conditioner or heat pump.
Brian
SuEllyn & Brian McCabe
Old 09-01-2009, 12:19 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Yes and maybe!
Hi, a 30 amp circuit should run everything that your trailer came with. Although, one time we had too many other appliances running at once and kicked the power off. Electric blanket, oil filled heater, coffee maker, toaster, and micro wave. [something like that, I don't remember exactly] I checked my trailer's circuit breakers and all was good. It was the camp ground circuit breaker that tripped.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-01-2009, 01:33 AM   #6
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Welcome to the club!
You might want to get a volt meter to put in one of your outlets. It will help you determine if the available amps are in the "safe zone". This way you can make sure you are not damaging your A/C compressor unit. We were at a site this summer and had 30 amp service, but because of the heat and everyone running their AC's the reading was under the safe green zone. 30 amps does not guarantee you'll have voltage in the safe zone. Luckily we were only there for one day. It is my understanding that prolonged voltage this low would significantly lessen the life of your AC unit.
Here's an example:
AC Voltage Meter - Item - Camping World
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 09-01-2009, 05:34 AM   #7
Kevin245's Avatar
30 amps will do fine. Just avoid using extensions cords on your power supply cable if at all possible when you're running the AC, electric WH (if applicable), or space heaters.
If you do use an extension from time to time, make sure that it is the same cable size (10/3 in my case) as the factory supplied cable, and keep the length as short as possible to minimize the affects of Voltage Drop.
Oh!!! And welcome to the group
Eleanor Roosevelt
70's era Metal Ceiling Specs and R & R (Remove & Replace) Facts Distantdrummer General Interior Topics 3 06-22-2008 03:04 PM
Magnetek Series 900 Model 950 50 Amp converter / charger Specs & Features? Driver1 Batteries, Univolts, Converters & Inverters 7 03-29-2008 12:55 PM
Car & Driver Jan 07, Airstream & Benz Karyn Airstream "In the News" 14 12-04-2006 10:26 PM
Preztels & Beer or Biscotti & Cappuccino? GreggH Community Polls 26 02-20-2006 06:08 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1965 Safari 2 07-28-2003 07:04 PM
