Old 11-04-2014, 11:57 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Note that a 27FB Flying Cloud or International have a GVW of 7,600 pounds (average factory empty weight 5,846 pounds between the two trim lines) while the 2014 Classic 27FB has a GVW of 9,000 pounds (factory empty weight of 6,672 pounds). Part of that weight increase is the larger (54 gallon) fresh water tank, 800 pounds of hickory cabinets. larger capacity propane tanks and group 27 versus group 24 batteries.
Thus the gross combination towing weight must also be considered as well as the maximum trailer weight. Many tons are rated for a 7,500 pound trailer or less.
Inquire if your insurance carrier will cover a 7,500 pound trailer rated truck towing a 9,000 pound trailer in the event of an accident. They often look for a way to deny a claim....
From the Dodge build sheets, the standard cab 1500 Ram 5.7 liter gas series are rated for a 9,250 pound trailer with no accessories while the diesel engine models are rated 7,300 pounds. The payload with no accessories drops from a high of 1,635 pounds. Selecting a 4x4 option drops payload by 200 pounds.
While the quad cab models get an increase in trailer weight it comes with a significant decrease in payload capacity before options. A fully loaded 1500 diesel 4x2 Laramie Ltd is rated for a 8,600 pound trailer and has 1,115 pounds of payload while the 4x4 model is rated for a 8,400 pound trailer and only 881 pounds of payload.
There is more to the decision than starting forward motion.
Old 11-04-2014, 02:00 PM   #16
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by dkottum View Post
We use a ProPride hitch. Wouldn't recommend anything less for this truck.
Doug,
What is it about the RAM 1500 that makes ProPrides a necessity?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-04-2014, 02:21 PM   #17
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Trucks by design have worst handling and braking of any vehicle. Rollover prone. This hitch type is as much needed by TV as by TT
Old 11-04-2014, 02:38 PM   #18
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Originally Posted by interstateflyer View Post
What Hitch System (weight distribution/sway control) is everyone using with their RAM 1500?
Between our 2010 Ram with 4.7 and 2014 Ram Hemi we have over 10,000 miles using a Reese and have no problems with sway. Our normal speed is around 60 mph, maybe traveling faster would cause problems but what is the hurry.
Gary
Castaway is offline   Reply With Quote
Old 11-04-2014, 03:39 PM   #19
Gary....which Reese hitch do you use on your 1500?
Old 11-04-2014, 06:05 PM   #20
Castaway's Avatar
Celina , Ohio
Reese High Performance Trunion Weight Distribution Hitch with Trunion Bars
Reese PN 66021
Gary
Hemi-Powered Ram 1500 versus 30' Classic LittleRadio 2001 - 2005 Classic 34 10-19-2014 09:10 PM
2007 Ram 1500 with hemi - push and pull thomdial Tow Vehicles 8 10-12-2013 04:58 PM
2010 Ram 1500 5.7 Hemi? DesertDog Tow Vehicles 29 07-11-2011 02:24 PM
25-Footer with a Dodge Ram 1500 HEMI AirHeadRik Hitches, Couplers & Balls 33 02-22-2011 08:15 AM
Ram 1500 hemi Mifair Tow Vehicles 12 10-28-2010 09:41 PM
