Old 02-21-2005, 08:37 PM   #43
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Originally Posted by jcanavera
Gus, since you have one tire unblown it may be worth the effort to get this to a Goodyear dealer and have them check this out. You might be able to recoup some $$. You also might also consider contacting Goodyear Corprate and see if they can deal with this. Here is a link to someone who may give you some help.
http://www.goodyear.com/cgi-bin/mail...il/mailto.html
Regards,
Jack
Jack -
There's some really good stuff there. Thanks for the link.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 02-21-2005, 08:47 PM   #44
campcollector's Avatar
2003 19' Bambi
Lincoln City , Oregon
Images: 21
Altitude
After my potato chip bag exploded on a trip from the coast to Utah mountains. I check the tire pressures more frequently when going to higher altitudes. I found my pressure increased from 65 to 72 PSI.
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
Old 02-22-2005, 12:05 AM   #45
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
Originally Posted by gklott
Doran pressure pro sounds like a great deal after this experience. $529 seems to be the price for an 8-wheel sensor and control unit. Bit pricy, but after what we experienced...
After Gus and Tin's stories, I ordered Doran Pressure pro. If I get a flat at least I'll know about it now. That makes me feel better.
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 04-27-2005, 01:02 AM   #46
1992 34' Limited
Falls Church , Virginia
In summary, if I may?
It seems that everyone agrees that the tires, both C and D, should have pressurized air within them.
However, the 'clucking chicks' scatter off in every cincievable direction over the questions of 1) When to measure 2) Which pressure to us 3) How to adjust while hot 4) Nitrogen, or not to nitrogen 5) monitors and gadgets - just name a few.
Ah, What FUN! Discussion is always better than silence. If there is silence, especially a "heated" one, then you better get ready for new dishes and glasses because you will be needing them shortly!
Enjoying the sport that comes with some of these threads.
Makes for a great read!
Axel
SilverToy is offline   Reply With Quote
Old 04-27-2005, 08:43 AM   #47
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
After having a couple Goodyear Marathons blow out on my trailer, I went looking for alternative tires. The RV dealers I talked to said not to trust Goodyear Marathons after they are 30 months old. The tread holds up, but the cases disintegrate. I replaced mine with a "house brand" after having the second one blow outside Provo, Ut. So far the "house brand" is doing great. Just say no to Goodyear!
So Long!
Bob Thompson is offline   Reply With Quote
Old 04-27-2005, 09:39 AM   #48
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
what is the "house brand", if I may ask? are they ST22575R15's? ballpark price?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-27-2005, 09:49 AM   #49
Images: 67
The "house brand" is SUPERSTONE and they are ST225/75/15 load range D, 65 psi, trailer use only tires. They were about $90 per tire mounted and balanced.
So Long!
Old 04-27-2005, 11:19 AM   #50
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Bob,
I think we need to understand that there was once a problem with the Marathons and I believe that that issue has been resolved. There are many threads on this forum that have talked about this.
Personally I have no interest in Goodyear, but if you look at the number of new trailers being produced including Airstream, the Marathons have a high market share. In the law of averages when you are equipping the majority of new trailers on the market, the universe of potential problems is larger. That's a statistical fact. The question is when a tire fails, do we really know the whole story? Is it UV related failure, inflation issues, road damage, were the tires the proper weight rating (yes Airstream has had some screw ups in this vein), or were they operating at end of their useful life?
In your case Bob, I don't know the age or when your tires failed. If it has been recently, then based on the age of your trailer and assuming that those Marathons were on your '97, those tires probably should have been replaced in 2001 or 2002. If I'm not wrong the '97 year may have also been around the time that the bad Marathons were out there.
The part that scares me is when a tire or RV dealer knocks another manufacturer's tire, is he biased towards his own product that he stocks? Do these dealer's give the RV manufacturer any feed back? While I don't rely on the government for everything, there is a fairly good reporting system available that tracks this kind of failure, and if the Marathons have a bad record, I think the RV manufacturers and the general public would know about this and you would soon see them disappear. I think most of us know that Airstream cares enough about their brand, that they are not going to knowingly put tires that have a short product life on their products.
Personally this is my third trailer that has had Marathons and none have failed. I do my part. I limit UV exposure, I don't use petroleum based agents to blacken the sidewalls, I'm careful not to tow with an underinflated tire and when I detect a tire that has reached its limits (either physical limits or time), I replace it. I don't try to coax another season out of it.
There is a little part we all need to do to keep our tires safe.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-27-2005, 11:51 AM   #51
Images: 67
Jack, I fully understand that Goodyear had a problem with the Marathon and is supposed to have cured the problem. My issue is where does Goodyear get off making tires that are so on the edge that everything has to be nearly perfect or they will disintegrate. I can see where a tire at 65 psi on a cool morning might expand to 70 psi when it is towed thru the hot desert later in the afternoon. Goodyear takes this to mean they have no liability because the tire must have been overinflated. I say bull!
I buy tires I deam to have a built in safety factor, where everthing doesn't have to be perfect to provide safe service. When I replaced my Marathons, the RV dealer I inquired at said, "when the Marathons on the trailers we sell fail, and they do often, we always tell then not to put Marathons back on their trailer. We send them across the street to the tire store and have them install Superstones. We've never had a problem with them." That was 10 months ago.
I put Goodyear and Firestone (and their Ford Explorer tire debacle) in the same boat. They build products that are just barely capable of providing service. If conditions aren't near perfect, they dangerously self destruct.
They don't have my family's best interests in mind.
So Long!
Old 04-27-2005, 01:46 PM   #52
jcanavera's Avatar
Fenton , Missouri
Images: 143
I'm with you 100%. I expect that if I follow their "rules", that they will back their product. If they don't then there isn't any reason why the gloves shouldn't come off. The question still stands that when a tire fails, there is a reason. What's difficult is to attempt to prove that there was a manufacturing defect.
I met a couple at Jackson Center who had a tire fail on their new Airstream motor home. The front Michellin tire blew out even though the owner said that the inflation was at max pressure. It caused almost $1,400 damage to the side of their motor home. Upon bringing it to a Michellin dealer, the dealer stated it was a defect. Michellin claimed once the tire was received that it was under inflation. The motorhome owner was livid since he was a stickler for watching his tires. So bottom line, we all are pawns in this game.
Specifically, that maximum inflation stamp on the sidewall says "cold". If you follow that recommendation on a warm or hot day, those tires will exceed that max inflation stamp. The tires are engineered to accomodate those pressures. As a matter of fact, the standing rule is that you don't bleed air out of a hot tire as long as it was inflated to no more than the cold maximum pressures. If a tire manufacturer doesn't acknowledge that fact, they are attempting to pull a fast one on you and as you stated, doesn't warrant your continuing business.
I still question that dealer into whether they are reporting these failures to the manufacturer of the trailer. I also question as to whether they are providing proper instructions regarding tire care and maintenance to the new owners. I can tell you for a fact that many dealers do not, and many owners don't understand the differences and life cycle of a trailer tire compared to their auto tires.
Maybe in your dealer's case the recommended tires have a better track record in withstanding customer neglect. If so I guess that makes it a better tire for people towing in those conditions.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-27-2005, 03:49 PM   #53
Exeter , Rhode Island
If you are running 65 psi and your TT is 25' you are over inflating your tires.
Ben
Rob30044 is offline   Reply With Quote
Old 04-27-2005, 05:41 PM   #54
Images: 67
I run my tires at 45 psi because I am never anywhere near the GVW. I always dump the tanks before traveling and I never carry a full tank of fresh water. And, I've taken nearly 1000 pounds of weight out of my 25 ft. trailer. I do check the trailer to see that it travels level so the tires all seem to carry equivalent loads.
The plaque on the side of the trailer says to run 50 PSI in the tires.
For the record I have 3 tire guages, but none of them have been recalibrated and tested within the past six weeks, and I don't check the tire pressure at every fill-up. Sometimes I fill up 3 times in one day if I'm trying to get across Texas.
The point is, why buy tires that are so darn suspect. Ask around and determine which tires have proven to be reliable and buy those.
If Marathons are satisfactory, and changing them ever 30 months brings peace of mind, go for it.
So Long!
Old 04-27-2005, 05:50 PM   #55
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 68
We had 18 months (original equipment) and about 25k miles on them when we lost both. Both were at 65 psi cold the morning we left. That's the Goodyear maximum AND the specific pressure listed in Airstream's manual.
Probably 20k or more were on Interstate highways or the equiv. We had one alignment done, and the treads did not show unusual wear patterns.
What more can one do?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 04-27-2005, 06:21 PM   #56
I will have had my current set of Marathon tires 5 years next month. My TT's GVWR is 8300 lbs. I inflate my ST225/75R15D tires to 53 psi.
Ben
Low Tire Detector Pahaska Tires 31 12-19-2007 04:58 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
