Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 08-26-2016, 01:36 PM   #101
Boxite's Avatar
2008 22' Safari
Originally Posted by BirdDog View Post
Another opportunity to learn presented itself. I had modified the plastic 5-gallon can by drilling a 1/2" hole near the handle and pulled a tubeless tire valve stem through the hole so the diesel would flow better. You remove the valve and screw the cap back onto the stem. The diesel fuel caused the rubber valve stem to deteriorate. The valve stem came off leaving a 1/2" hole with a full can of diesel. Fuel can was inside a black truck box. Diesel went everywhere. Another lesson learned. I am currently in Parrsboro,NS and was able to find a yellow fuel can with an air vent.
These user-installable vents are the way to go. Use a 1/2" spade-type wood bit, drill a hole near the top-rear of the gas
can, and use a mallet to install.
Great get-around the modern gas cans that have no vents!
https://www.amazon.com/YELLOW-Shippi.../dp/B00MNC6L24
Name:	gas can vent.jpg
Old 08-26-2016, 03:10 PM   #102
BirdDog's Avatar
2015 25' FB Flying Cloud
Carriere , Mississippi
Those look a lot better than the rubber valve stems that I installed and failed. I don't know if pressure can build up in the tank while installed in a black truck box.
I was able to find a 20L diesel can in Parrsboro, NS with a built-in vent. I didn't see any signs of leaking after I got home. I couldn't find it on Amazon. I also put an aluminum cooking pan under the tank with paper towels. It was a mess to clean-up after the valve stem failed as diesel went everywhere.
BirdDog is offline   Reply With Quote
Boy I hope I didn't Make a mistake Jay Wheeler Sprinter and B-van Forum 18 02-07-2019 09:24 PM
Trip Journal--10 day trip to Yellowstone and GTNP in a Bambi 22 Piggy Bank 2005 and newer - Bambi all models 21 07-15-2016 05:42 PM
1st Big Trip, 1st Big Issues! trekerboy On The Road... 17 07-13-2016 07:07 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
The 2500 Mile Mistake. Safari Tim Our Community 15 05-01-2005 04:50 PM
