06-19-2017, 12:44 PM
Sweeney153
1988 33' Argosy
Summit
, New York
Wanted Propane tanks
I need two 30# horizontal tanks. A PO must have removed them at some point. I would rather get old ones and have them recertified instead of buying new ones and modifying them.
Any one have ones the want to sell or a lead on where to buy them?
06-19-2017, 02:03 PM
2021 16' Bambi
2021 22' Bambi
North Port
If you ever make it to Florida I have a set of horizontal tanks removed from a 95' Limited. I'd have to double check the size though as they might be 40 #'s
Don't believe you can ship those though?
06-19-2017, 02:54 PM
1988 Argosy 32
Lomita
Replaced the 30's with 40 Lb fork lift alum tanks, Had to remove stop plates to fit them.
found them used at fill station.
06-19-2017, 05:19 PM
Airstream - Other
Bosque Farms
, New Mexico
Be VERY careful doing this. The forklift tanks that i have dealt with are designed to feed LIQUID propane rather than VAPOROUS propane to the system. (RVs are NOT designed to handle LIQUID propane.)
Here's some info:
http://www.propane101.com/propanecylinderusage.htm
Lynn
06-19-2017, 07:06 PM
Sweeney153
1988 33' Argosy
Summit
, New York
I will be going to FL in the fall. I don't know if 40 would fit.
07-06-2021, 09:20 PM
Woodstock
, NY
I have a pair of aluminum horizontal tanks from a 1989 33' Squarestream in Woodstock, NY. Best offer? I realize this thread is several years old.
05-12-2023, 01:05 AM
1988 35' Argosy 5th Wheel
Lakeside
The size tanks that fit are not going to work because that size is now required to have the OPD VALVE. which as far as I understands does not allow a tank to be operated on its side.
05-12-2023, 07:45 AM
Airstream - Other
Bosque Farms
, New Mexico
Horizontal cylinders have a means by which "up" is determined (usually by having feet welded onto the side of the tank). By having an up-side (no pun intended), an OPD can be fitted.
Lynn
ACI Big Red Number 21043
05-13-2023, 05:36 AM
Woodstock
, NY
Squarestream propane tanks available
I previously posted horizontal propane tanks from a 1989 33' Squarestream, now in Hillsdale NY (near Great Barrington MA). I am in the process of renovating it as an all-electric trailer.
05-14-2023, 07:19 AM
1989 29' Land Yacht
St. Catharines
, Ontario
I changed over to vertical tanks, so mine are up for grabs.
05-15-2023, 09:03 AM
Lakeside
Awesome. Did not know that. See I'm learning all this stuff as I go that's why I like this place. !
06-09-2023, 01:15 PM
1989 29' Land Yacht
Mesa
I have a set from my 1989 Squarestream in California can bring to Arizona on next trip,if anyone once them PM me
Live every day as if it is your last one and one day your going to be right.
