Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Squarestream > All Squarestream Trailers
Old 07-02-2008, 02:34 PM   #41
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Squarestream
Hi Bob
Have fun at Bozeman.FYI I got a s/n of a trailer made after yours .I do not have info with me but will post it soon.I have been out camping since 4 May.I am working my way to ABQ for the 4CU balloon rally in Oct.
Originally Posted by Squairstream View Post
Anyone here at Bozeman? If there are, drop by Purple 2-8 and see my 1992 26 foot Land Yacht.
Live every day as if it is your last one and one day your going to be right.
jimmini is offline   Reply With Quote
Old 05-23-2009, 11:10 PM   #42
Squairstream's Avatar
1992 26' Land Yacht
Wickes , Arkansas
Check this out on eBay!!
1989 Airstream Land Yacht
1989 AirStream Land Yacht 33 ft 4 Season Travel TrailerItem number: 180358770090
Hi Jimini
There is a nice looking 88 33' two door Land Yacht on ebay now. The serial number is 45zgyjt25kj201060.
Bob & Dorothy
1992 Land Yacht TT
WBCCI # 4550
Arkansas Razorback Airstream Club
Squairstream is offline   Reply With Quote
Old 06-01-2009, 09:17 PM   #43
1989 35' Argosy 5th Wheel
1979 rgosy 27
Danville , Vermont
I own a 1989 argosy fifth wheel. Bonded Al is the answer! It is referred to as a tension bonded aerospace technology. The aluminum is actually heavier than the standad riveted kind by a very small amount.
fordfarmer is offline   Reply With Quote
Old 06-29-2009, 08:35 AM   #44
1989 29' Land Yacht
Sandusky , Ohio
Smile SquareStream Exterior
I'm new to these forums, but their is one thing for certain, Airstream Land Yacht, or Square Stream is made of aluminum. I just replaced the water inlet and my Father in Law and I spent quite of bit of time looking at the construction of it and were amazed the more we looked, the Agrosy were made with fiberglass. SquareStreams were made completely from Aluminum. Now that we own a SquareStream, would not own anything else. (Just my 2 cents)
Jeep Johnson is offline   Reply With Quote
Old 06-30-2009, 01:30 PM   #45
1979 rgosy 27
Danville , Vermont
Correction, the Argosy was also aluminum. The difference is in the paint color. both actually have some fiberglass inserts. The lower corner pieces are fiberglass as are the upper fore and aft intersection. (Where the clearance lights are mounted.) My rear window fram is also fiberglass molded where it indents. The later (mid 90's) fifth wheels were fiberglass. I am resurecting my rare argosy 1989 fifth wheel, Land yacht when painted silver. I am also impressed with the construction, but have found alot of moisture damage. Keep all roof and trim sealed. I inherited/purchased quite a job of interior overhaul, but I am learning alot. The floor system is the weakest part.
Old 06-30-2009, 02:18 PM   #46
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Does Fiberglass Oxidize? Yes
Originally Posted by acwdgw View Post
Does fiberglass oxidize?
Yes.
I don't know if Squarestreams are made of aluminum, fiberglass or some combination of the two. Sounds like it depends on the year. Also sounds like some people are confusing the old style Squarestream with the more recent motor homes that have squared off body lines.
Regardless, fiberglass does oxidize. Almost everything oxidizes in some manner. Some materials oxidize slowly, some oxidize more quickly. Some oxidation can cause severe degredation of the material (steel rusting for instance) and some oxidation in not as serious. Many household cleaners promote oxidization - that's how they clean - by oxidizing unwanted material (dirt) and flushing it away.
Lucius
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-30-2009, 04:56 PM   #47
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
SQUARESTREAMs
[quote=nvestysly;716107]Yes.
Lucius[/quote
The 1986 Argosy thru the 1990 Airstream Squarestream trailers are made of bonded aluminum sidewall skins,a special alloy,tension leveled for smoothness.The skin was then permanently bonded with a proven space age adhesive to the structural cage.It was then painted Beige for Argosy or Silvers for Airstreams.
The 1991/92 model Squarestream underwent change when the aluminum was changed to new high-gloss fiberglass.They where a silver gray color.
Please see thread Squarestream history for more info.
Old 10-23-2009, 05:02 PM   #48
1979 rgosy 27
Danville , Vermont
I can't help myself. I am almost finished with a complete restoration of an argosy fifthwheel which is the same structure as the airstream trailers. I do not know about the argosy or landyacht motorhomes. I can assure you all, that the platform frame is steel, the shell frame is aluminum. the skin is aluminum bonded and stretched. the Insulation is sprayed foam in the walls and fiberglass batts in ceiling. The only exception to wall material is the fore and aft end caps from center up to top. They are molded fiberglass and joined with rivets to the aluminum. This is where my rear window is mounted and the fore and aft clearance lights. I think we can all claim victory because both aluminum and fiberglass was used. I will gladly show anyone my proof pictures if you are not convinced. I restrict my comments to the 1988 to 1991 squarestream trailers. I have read the the 95 vintage fivers were fiberglass. Have fun, John
Old 10-30-2009, 08:03 AM   #49
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
Argosy Squarestream's are aluminum - not fiberglass!
Brian,the proud (2nd) owner of aluminum 1986 '32 Airstream Argosy (Squarestream) #305 Rare? It's either the Hemi Cuda of all Airstream's,or their Edsel.
wanderer1 is offline   Reply With Quote
Old 10-31-2009, 10:38 PM   #50
1992 26' Land Yacht
Wickes , Arkansas
Square Atreams are Aluminun (and Fiberglass)
wanderer1 you are correct in saying that the Squairstream is an aluminum trailer. That was true until 1990, when they changed from aluminum to fiberglass, Mine is a 1992 26' Land Yacht and it is one of the last Land Yacht Trailers that was produced.
Bob & Dorothy
1992 Land Yacht TT
WBCCI # 4550
Old 03-21-2010, 04:58 PM   #51
Mainstream's Avatar
Louisburg , North Carolina
New Purchase Squarestream
Just purchased this 89 31Ft. ser# 45zgyjt29kj200977 Manf. date 9-88. It is Alum. Except for the front and back top end caps that are fiberglass.
Name:	Sq. Stream.jpg
ID:	98556   Click image for larger version
Name:	Sq Stream1.jpg
"Shiny Aluminum Bodies will always turn a REAL man on"
Don't Let the Grass Grow under your Rig!
2004 GMC2500 HD Duramax~ 1987 Avion 30 P
Mainstream is offline   Reply With Quote
Old 03-22-2010, 04:59 AM   #52
Mainstream's Avatar
It's a 33 footer not a 31.
Sorry, It's a 33 footer not a 31. It was sold to me as a 31 footer but I now have found out it is realy a 33 footer. Wondered why it looked so long.
Old 11-28-2017, 06:06 PM   #53
1987 33' Argosy
Elloree , South Carolina
87 Argosy 33 ft
I own an 87 Argosy 33 which is aluminum outer skin with a plywood inner skin. I am currently restoring and searching for replacement inner wood ceiling panels, or suggestions on how to replace ceiling panel around TV antenna damage from water
Stumphole is offline   Reply With Quote
Old 11-29-2017, 03:51 PM   #54
1989 29' Land Yacht
St. Catharines , Ontario
Good luck with that, I've been searching too! The panels have a 1/4" styrofoam backing glued to it.....I can't find it anywhere.
ktmkirby is offline   Reply With Quote
Old 10-27-2019, 06:10 PM   #55
1986 Argosy
Yerington , Nevada
my 1985 Argist 32'squarestream is bonded aluminum. There was a version in the latter years 1990 to 1991 where they were fiberglass exterior panited silver and labeled Airstream.
squareboat is offline   Reply With Quote
Old 10-28-2019, 07:52 AM   #56
1979 rgosy 27
Danville , Vermont
I own a 1989 squarestream fifth wheel. I will say with confidence, having done a complete restoration, that the exterior walls are bonded aluminum. There are two areas of molded fiberglass. The front face up to the the first seam on top and around the front corners to the first seam is fiberglass. Also, the rear molded end, with rear window. All sides, roof, cabin framing, etc. are ALUMINUM! Some have reported delamination but I have had none. The paint is Argosy and is in great shape. I do get slight oxidation that is easy to buff out. I must be one of the elusive owners, but I am not on the sight much. I am glad to share pictures of restoration on request. Mine is still registered for over the road. I understand that is pretty rare indeed.
