Old 02-07-2012, 04:04 PM   #1
rockford , Michigan
Wiring harness
I need to know what function cooresponds to the colored wires in the harness of my 1968 avion c-11 slide in camper..
I have to match the function of the camper wire to that of my harness on my 2003 silverado.
THIS IS WHAT I HAVE WRITTEN DOWN;
yellow-right turn
green-clearance/running lites
black-backup
red-left turn
white-neg
blue plus white wire dual-? positive?
does anyone know if these are correct or not? I can find this info anywhereand about at my wits end..
leonarnold is offline   Reply With Quote
Old 02-07-2012, 08:26 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can use a battery charger and test each circuit. Clip the black lead to a clean metal spot on the camper. Use the red lead to connect to each of the colored wires one at a time and see what lights up.
TG Twinkie is online now   Reply With Quote
Old 02-08-2012, 08:20 AM   #3
Avion C-11's Avatar
Columbia , South Carolina
There is also a wiring diagram in the manual. You can download it at the Silver Avion site.
AvionCamper.Wordpress.com
Avion C-11 is offline   Reply With Quote
Old 02-08-2012, 02:07 PM   #4
rockford , Michigan
wire harness
thanks for the tip using a charger..Cayo Avion in Watervliet, Mich told me to use a battery, but your suggestion sounds safer..if I happen to touch a positive wire will it short out my charger?
to the person who told me that there is a diagram in my manual..I couldnt find it...the only elec diagaram I could find was for the inverter..you would think that they would at least tell you what colored wire was for what function..also I went to the silver avion site and there were several to choose from to look for info I need...thanks also for that suggestion...wish me luck..if by any chance you know where to go to look it up directly, I would appreciate you doint so and then compare to what I find testing each wire individually....
Old 02-08-2012, 03:23 PM   #5
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
Thumbs up
Leon,
Check here you may be able to match it up.
Good trouble shooting guide also.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
ROBERT CROSS is online now   Reply With Quote
Old 02-10-2012, 02:46 PM   #6
rockford , Michigan
wiring harness
thanks to all who tried to assist me in my quest for info..
I used a battery to test the function of each colored wire and they all turned out according to my original layout...you were great to give me suggestions and am grateful.
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 11 11-06-2011 07:51 AM
Brake Controller Wiring Harness wlanford Brakes & Brake Controllers 3 08-01-2011 12:14 PM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
Coach wiring harness to batteries ? John H. Classic Motorhomes 16 03-28-2011 10:52 PM
