Old 02-19-2014, 08:30 AM   #1
redondo beach , California
What kind of hitch is this?
Hi Everyone, I was wondering if anyone can tell me what kind of hitch or trailer this came from. This hitch has been adapted to a Silver streak clipper. John Los Angeles, CA
PLVMB is offline   Reply With Quote
Old 02-19-2014, 08:31 AM   #2
Try this again
Old 02-19-2014, 08:45 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The coupler looks like an Atwood that someone has welded to a single tongue beam.
I would look under the trailer to see if the beam was an after thought because the original A frame may have failed.
2004 Excursion 4x4
Old 02-19-2014, 08:56 AM   #4
Was that an aftermarket hitch? I did look under the hitch and inspect the tube it is welded on solid with good welds.
Old 02-19-2014, 08:59 AM   #5
HowieE's Avatar
Images: 12
There is no hitch in the picture. What you are showing is a trailer tongue with a coupler welded to the end of it.
I think the whole thing is aftermarket and warrant replacement if the trailer is more than 1,000 lbs.
2004 Excursion 4x4
Old 02-19-2014, 11:34 AM   #6
These originally looked like this
Old 02-19-2014, 12:01 PM   #7
HowieE's Avatar
Images: 12
Your second picture looks to have an A frame forward of the trailer body. If everything is still there with respect to the frame the coupler has been changed to a more recent Atwood.
If you want to change the coupler there are several none A frame couplers that will weld directly to a beam
2004 Excursion 4x4
Old 02-19-2014, 12:09 PM   #8
which ones? Thanks for your response
Old 02-19-2014, 12:22 PM   #9
HowieE's Avatar
Images: 12
You can find several with specs here
Trailer Coupler | etrailer.com
2004 Excursion 4x4
Old 02-19-2014, 01:04 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The coupler itself likes like a Marvel, which is common on Airstreams.
Old 02-19-2014, 02:30 PM   #11
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
The image is poor, can't quite see, but whether it is Atwood or Marvel, it looks as if the lip/flange around the ball-cup has been ground away. If that is the case, its safety may be compromised.
It's not pretty.
A non A-frame coupler is a great suggestion.
ALUMINUMINUM is offline   Reply With Quote
Old 02-22-2014, 10:15 PM   #12
Glendale , California
If the coupler is sound and functional, you could stick with what you have and add a flat surface behind the coupler. Kind of fabricate a nice piece of metal to go under your propane tank if you're planning on putting one there.
chris hart is offline   Reply With Quote
Old 02-22-2014, 10:17 PM   #13
Looking at the handle, I think I have an identical one in my garage. Look at the side of the handle arm. It should say ATWOOD.
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Stolen Hitch Silver Threads Hitches, Couplers & Balls 51 07-29-2011 10:32 AM
BMW X5 OEM Hitch says NO WD device - Help valmog Hitches, Couplers & Balls 8 07-12-2011 11:15 AM
Trailer Hitch for 2005 25' Safari basecamp1 Hitches, Couplers & Balls 7 03-28-2011 07:40 PM
