Old 10-22-2012, 08:39 PM   #1
TinCanCookie's Avatar
Santa Clarita , California
What is this thing?
I was cleaning out a cupboard where the PO had stashed some odds and ends and came across this... thingy. It says "perfection" and seems like it might be cast aluminum. It appears to be a handle and has a square hole inside a round hole in the bottom, but we can't figure out what we're supposed to turn with it.
Name:	Photo on 2012-10-22 at 19.36 #2.jpg
ID:	171155   Click image for larger version
Name:	Photo on 2012-10-22 at 19.35 #2.jpg
Name:	Photo on 2012-10-22 at 19.36.jpg
TinCanCookie is offline   Reply With Quote
Old 10-22-2012, 08:54 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It is an insert for a coil spring. These were used in pairs as either boosters or to correct a sagging car or truck suspension. You stick the flat end between the couls, then twist it in with a half inch drive breaker bar and extension.
Old 10-22-2012, 08:55 PM   #3
dznf0g's Avatar
Oswego , Illinois
That appears to me to be a device used to spread the coils in a truck/MOHO coil spring used to attempt to raise ride height. If that is what I think it is, it is a band aide fix to a more serious load/suspension issue which should be addressed otherwise. Not sure I am seeing it right though.
-Rich-
Old 10-22-2012, 09:07 PM   #4
So, in that case I can toss it? It sounds like it would have only been for the TV and not the trailer?
Old 10-22-2012, 09:08 PM   #5
Kevin245's Avatar
Ditto the coil spring spacer comments.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 10-22-2012, 09:10 PM   #6
dznf0g's Avatar
Oswego , Illinois
Yes, or sell it along with it's mate to someone who doesn't understand the proper way to correct suspension issues.
-Rich-
Old 10-22-2012, 09:28 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, recycle it with your aluminum cans.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-22-2012, 11:07 PM   #8
Perfect! I hate throwing anything out and I didn't find it's mate.
Thanks everyone
Old 10-22-2012, 11:31 PM   #9
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
it'd make a cool paperweight.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
