Old 09-13-2012, 12:22 PM   #1
Calgary , Alberta
Vintage TT ball receiver
We have recently bought a 1950 24ft Spartan. It looks great pulled by our '57 Chevy Suburban!
Anyway, I have a question about the A-frame ball receiver. I do not really know how to call this part, it is the one into which the ball from the TV hitch goes.
That ball receiver on the Spartan looks very "open" on the front, it looks like modern receivers enclose the ball more and I wonder if this is an issue.
Should I change to a new piece?
If I knew how, I would put up a picture, but I do not!...
wave1957 is offline   Reply With Quote
Old 09-13-2012, 12:48 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Does the front of the coupler swing open to go around the ball?
Might be a Bulldog hitch.
Bulldog Collar-Lok Coupler w/ High-Profile Latch - 2" Ball - A-Frame - 7,000 lbs Bulldog Trailer Coupler BD028386
You can upload pics from your PC by using the "Manage Attachments" button.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-13-2012, 01:02 PM   #3
Calgary , Alberta
No, it is not a Bulldog hitch, it looks a lot like an original piece.
And now that I know how, I am going to put a couple of pictures:
Old 09-13-2012, 01:44 PM   #4
SteveH's Avatar
Common Sense , Texas
I would have that thing replaced with a new, late model version this afternoon. It looks original, and also like it's been repaired on the front.
Old 09-13-2012, 02:12 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You can check the lip of the locking portion,,look at it from the underside. I use those and never have had a problem in about fifteen years on several different Airstreams.
Old 09-13-2012, 02:18 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
It's called a coupler. Is that a surge brake mechanism or a tongue jack, or something else on top of it?
Old 09-13-2012, 02:19 PM   #7
1974 Argosy 20
Kooskia , Idaho
The good news it that it is bolted on, not welded on. I believe that Atwood makes a bolt on hitch receiver still. Check out their web site.
Old 09-13-2012, 02:27 PM   #8
Calgary , Alberta
On top of the coupler (thanks!) is the original tongue jack.
Old 09-13-2012, 02:30 PM   #9
Calgary , Alberta
It is good news since I do not weld. I have found some bolt-on couplers locally, they are not even expensive($25)!
Old 09-13-2012, 02:38 PM   #10
Calgary , Alberta
So, why the different design? Is one kind better/easier than the other? Also, is one design better with a weight distribution hitch? I have not bought one yet but will soon.
The lip of the locking portion looks in good shape, a nice curve, without dings or cuts.
Melody Ranch, thanks, I like your answer, especially since you own a few oldies yourself!
Any other input from anyone?
Old 09-13-2012, 03:59 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would replace it. If it was the "hot setup" they would still be on new trailers.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 09-13-2012, 04:58 PM   #12
pbearsailor's Avatar
Port Hadlock , Washington
I've still got one on my '57 and it works just fine.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 09-13-2012, 09:13 PM   #13
Phoenix , Arizona
The real question is, how worn is it? If it is seriously worn, you need to replace it.
M2HB is offline   Reply With Quote
Old 09-18-2012, 02:34 PM   #14
Pillow's Avatar
Warrenton , Virginia
I have used the same style coupler on my old 49 Manor and current 48 Mansion without issue.
Be sure to add tow chains to keep "up to code".
bottom FWIW:
restored:
I replaced all the old bolts with new. Probably documented on my Mansion Blog in Vintage Kin here if you want details.
The coupler is super beefy, look at the thickness of the metal. The tongue weight of 300-500 pouinds is nothing for this coupler.
Trailer: 1948 Spartan Mansion 30'
Tow Rig 1: Hers 2010 Cadillac Escalade ESV
Tow Rig 2: His 2010 Porsche Cayenne S
Others: 1971 Chevy C-10 with 5.3 LS and T5 conversion, 1983 Jeep Cherokee Pioneer (FSJ) with 5.3 LS and SM465 conversion, 1979 Porsche 911SC
Pillow is offline   Reply With Quote
