Old 11-29-2019, 01:54 AM   #1
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Vintage Kin - Rounded, Riveted, Aluminum Trailer Brands
Hi All,
I decided to put together a list of all the travel trailer brands/models with rounded and riveted aluminum skins like those on most Airstreams (since the introduction of the 1936 Airstream Clipper). Note that some of these brands used anodized aluminum skins, but they could still be called "Airstream like".
Some of the listed brands were in business before and/or after the dates listed, but only produced rounded, riveted aluminum trailers in the listed years. Also, this list does not include travel trailers shaped like canned hams or otherwise with flat sides, even if riveted aluminum.
In approximate order of introduction of their rounded, riveted, aluminum models:
  • Bowlus: (incl. Bowlus-Teller): 1934-36
  • Airstream: 1936-current
  • Curtis Wright (Clipper only): 1947-49 (Clipper line sold to Silver Streak)
  • Silver Streak: 1949-~1997 (ending year not confirmed)
  • Airlight: 1954-55 (became El Rey for 1956)
  • El Rey: 1956-~1957 (formerly Airlight, ending year not confirmed)
  • Avion: ~1956-~1990 (some debate on exact dates)
  • Streamline: ~1956-~1974 (exact dates not confirmed)
  • Kit (Jetstream only): ~1957-~1958 (exact dates not confirmed, most Kit trailers did NOT look similar to Airstreams)
  • Avalair: ~1962-~1963 (exact dates not confirmed, all models except the Mark II)
  • Travelux: ~1966-~1978 (exact dates not confirmed, Canadian company)
  • Alumacoach: ~1969-~1972 (exact dates not confirmed, Canadian company, maybe only 30 to 40 total units built)
Also related, but not quite enough to be included in the list above:
  • Cayo: 1970-~1974 ("slide in" campers and Class C motorhomes only, separated from Avion in 1970)
  • Argosy: 1972-79 (painted trailer Airstream sub-brand)
Please help me confirm the dates and other details in this list and add any missing brands or models.
P.S. I have decided to exclude Spartan from this list because of their significantly different shape and their wood lined interiors.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 11-29-2019, 09:51 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Joe you seemed to have missed a big one. http://www.spartantrailer.com/
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-29-2019, 09:59 AM   #3
1962 22' Safari
2016 30' Classic
Images: 41
Hi Doug,
Thanks for the input. Perhaps you missed my "P.S." at the bottom. I specifically excluded Spartan because of their different shape and wood lined interior because I knew someone would bring them up. It's almost a shame to exclude them as they were an aircraft company, but I just feel that they do not look like Airstreams, though I suppose others may disagree.
Joe
WBCCI/VAC #6768
Old 11-29-2019, 10:30 AM   #4
Portland , Oregon
Boles Aero?
Ian Lomax
1966 Streamline Countess 26'
JeweloJalopy is offline   Reply With Quote
Old 11-29-2019, 01:44 PM   #5
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by JeweloJalopy View Post
Boles Aero?
The only aluminum sides Boles Aeros I have seen were flat sided, not rounded like an Airstream, but perhaps I just haven't seen the correct model. I'll add it if someone can provide a photo of one.
That said, Boles Aeros are cool and there are several similarly styled brands (e g. Barth, etc.). I am just trying to keep this list to brands and models that are most similar to the traditional, classic Airatream shape and construction technique.
Joe
WBCCI/VAC #6768
Old 11-29-2019, 11:53 PM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by 66Overlander View Post
Hi Doug,
Mine is constantly being called an airstream
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Old 11-30-2019, 12:37 AM   #7
1962 22' Safari
2016 30' Classic
Images: 41
Some people will call any unpainted aluminum trailer an Airstream. I guess that shows which brand has the most name recognition.
Joe
WBCCI/VAC #6768
Old 11-30-2019, 07:09 AM   #8
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Not sure of the accuracy in Thompson & Jameson's recently published "The Illustrated Field Guide to Travel Trailers." This book provides following information for some of the trailers listed:
  • Avion 55 - '02
  • Airlight '54 - '55
  • Alumacoach '69 - '72
  • Avalair '61 - '64
  • Bowlus '34 - '36
  • Elcar 1938 for Model 69
  • Elray '55 - Late '50s
  • Avion '55 - '76 Bought by Fleetwood '76. Streamlined aluminum trailers replaced in '91
  • M-System '35 - '60
  • Mobil-Glide mid-40s - early 80s
  • Prarie Schooner '36 - '60s
  • Silverstreak '49 - '97
  • Streamline '57 - '74
Couple on here not on-your list, addition is based on illustration in above reference. I recommend the above reference - it's available from VTS and Amazon.
Thanks for giving me a reason to have another cup of tea this morning.
DGJackson is online now   Reply With Quote
Old 11-30-2019, 10:46 PM   #9
1962 22' Safari
2016 30' Classic
Images: 41
Thanks DG. I was unaware of that book, but now have put it on my Christmas list.
I put my list of brands and models together mostly from memory and tried to do a little google searching to help bound the year range for each one.
Your info from the book helps firm up those dates in several cases and gives me a few more brands/models to investigate, including Elcar, M-System, and Mobil-Glide which I am unfamiliar with. I am aware of Prairie Schooner, but had not seen anything that looked similar to an Airstream from them. Time for more research.
Joe
WBCCI/VAC #6768
Old 12-01-2019, 07:17 AM   #10
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
The Tin Can Tourist web site has information on many of these trailers. The web site has a search feature but it's not always obvious how to access the search field. Some of the trailers mentioned in the previous post from DGJackson are rounded, riveted but their interiors are many times wood paneling much like a Spartan and separated into "rooms" in an attempt to be more like a home.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-01-2019, 11:00 AM   #11
1962 22' Safari
2016 30' Classic
Images: 41
Thanks. I actually looked up the brands I was researching on the Tin Can Tourists website before I started this thread, but did not have the time nor desire to randomly click on all the other brands.
That said, there sometimes were conflicts on the TCT website within their brand information write-ups and I know their Airstream and Argosy write-ups contain several errors. Maybe someday I will contact them about updating their Airstream and Argosy information.
Joe
WBCCI/VAC #6768
Old 12-01-2019, 10:54 PM   #12
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
66 This a great new thread which will contain great historical info. Thanks for sharing your knowledge.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 12-11-2019, 11:05 AM   #13
sault ste marie , Ontario
travelux data
nice list!
some Travelux info for you. according to a trademark registry is managed to download some time back, the name was in use from july 1965, approved registered nov 1966. i saw somewhere that manufacturing started in 1967. ownership of the trademark changed hands in 1977. i have a copy of a 1978 owners handbook, and read somewhere that manufacturing stopped in 1979. perhaps traveluxkid can shed some light on this if they see this post.
travelux1969 is offline   Reply With Quote
Old 12-11-2019, 11:21 AM   #14
1960 24' Tradewind
1966 30' Sovereign
Phoenix , Arizona
Great list.
I'm not sure if it is on here, but I forgot the name/manufacturer of the class C camper on a pickup that has like 13 panels and a door in the back. It is aluminum.
dsluyk is offline   Reply With Quote
Old 12-11-2019, 11:37 AM   #15
1973 Dodge Cayo Motovator
Outbackga's Avatar
Dahlonega , Georgia
The Cayo started as a pickup camper, C10 and C11, then developed into the Cayo Motovator as shown here. Another is the more rare Barth class C.
Outbackga is offline   Reply With Quote
Old 12-11-2019, 11:43 AM   #16
Half a Rivet Short
Carlisle , Pennsylvania
Hi
We pulled up next to an Avion (complete with YouTube channel logos on it ...) in a campground in Wyoming. It took me more than a couple of minutes to work out that it *was not* an Airstream ( looks a bit strange for a triple axle ....) ...... We'd been passing each other on the road for about 2 weeks at that point.
Old 12-11-2019, 12:15 PM   #17
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
These are limited production, but you can buy new ones right now.
They are beautiful.
The Bowlus Road Chief Endless Highways starts at $185,000.
The Bowlus Road Chief On The Road starts at $137,000.
https://bowlusroadchief.com/
Amsterdamer is offline   Reply With Quote
Old 12-11-2019, 03:16 PM   #18
1960 24' Tradewind
1966 30' Sovereign
Phoenix , Arizona
Thank you Outbackga.
The Motovator Cayo IS the one I was thinking of.
Looking up Cayo Motovator I see they go back to Avion.
Old 12-11-2019, 05:37 PM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
What a gorgeous camper!!!!
Old 12-11-2019, 06:46 PM   #20
2003 28' Classic
Stillwater , Oklahoma
I believe it is THE big one
ttrout is offline   Reply With Quote
1953 Hand Made Riveted Aluminum Travel Trailer Ironwood Airstream Classifieds 0 09-09-2019 08:45 PM
Featherlite All Aluminum Riveted Toyhauler Wolf Alaska Airstream Classifieds 0 10-09-2018 09:32 PM
Vinyl inserts for aluminum riveted strips in 73 Safari Lexxy General Interior Topics 15 10-31-2015 07:35 PM
Aluminum kin - Funny ad kevin242 Vintage Kin 13 10-05-2011 09:26 AM
UN-comfortable bed!! (Custom Rounded Matress) 99 bambi Our Community 3 04-16-2002 12:28 AM
