Old 08-10-2014, 01:26 PM   #1
Pinecone's Avatar
Edmonton , Alberta
Travelux Redux
I see it's been 8(!) years since I picked up my almost-one-of-a-kind 17' Travelux (floor plan G). I introduced it in this thread (w/ photos), and it's pretty much sat in a field ever since. Due to a lack of space, lack of tow vehicle, and unsure where to begin, I even tried to sell it once (the guy backed out, fortunately).
Well, my wife got a truck for work now, so I can tow things. Then I saw jonplayer's amazing thread and decided to, as they say in Alberta, "give 'er".
The interior panels are almost all off, and the mice condos removed. And, I got an exciting delivery from VTS!
This is gonna be fun....
Pinecone is offline   Reply With Quote
Old 08-10-2014, 09:31 PM   #2
1978 Travelux President 31' , Ontario
Hi Pinecone, please post pictures of your stripped interior and your frame. C-channel detail etc. I am in very initial stages of a restore and need all picture encouragement I can get
LuckyLux is offline   Reply With Quote
Old 08-11-2014, 08:09 PM   #3
Evalu8r's Avatar
London , Ontario
Very Nice! looking forward to watching this one come back to life and be loved again.
1979 Travelux 21' Snowbird
1974 Silver Streak Continental Supreme Luxury liner 31'
1970 Gypsy Queen 18'
1962 Glendale Glendette 14'
1975 Argosy 20 mh
Evalu8r is offline   Reply With Quote
Old 08-26-2014, 11:46 AM   #4
Pinecone's Avatar
Edmonton , Alberta
Yesterday, I tore out the plywood and the insulation from the floor. The belly pan is toast, the outriggers are rusted, and there is probably only one screw somewhere holding the shell down...
I think the trailer was happy to get all that crap out of her:
Frame is 2x5 box on the two outside and a third from the tongue, and the centre sections are 1.75x5 c-channel. Pretty robust for a small trailer.
Old 08-26-2014, 08:28 PM   #5
Evalu8r's Avatar
London , Ontario
The dirty work is done. Give her a good powerwash now and she'll smell better too! If you dont plan on taking the shell off to do the floor, wet sand blasting works well. That's how I did mine and I was pleased with the outcome.
1975 Argosy 20 mh
Old 05-15-2015, 09:08 PM   #6
Pinecone's Avatar
Edmonton , Alberta
Finally warm enough to do something useful.
Oliver is curious:
I pulled all the U-channel from the front. It needs replacement, so I'm thinking of using the pre-painted stuff for corrosion protection. On the left is my experiment piece, and the right is the original. Unfortunately, I'm not sure if the white piece is 3003 or 5052. Metal Supermarkets really doesn't know their aluminum.
Old 05-18-2015, 09:23 AM   #7
ericpeltier's Avatar
Superior , Colorado
OK, that is a damn cute trailer.
ericpeltier is offline   Reply With Quote
Old 05-22-2015, 10:27 AM   #8
Pinecone's Avatar
Edmonton , Alberta
Lift Off!
The shell is so very light. To get the 2x4s under it, I picked the shell up by hand, and my wife slid the lunber underneath.
Next steps: pull out frame, replace rusted outriggers/crossmembers, paint with Rust Bullet. Replace sprung axle with Flexiride axle.
Old 05-24-2015, 10:02 AM   #9
Pinecone's Avatar
Edmonton , Alberta
Frame is free.
Body is quite flexible. It's a good thing, because it fell off the jackstands at one point, but went right back into shape when I picked it up again.
Old 06-12-2015, 12:35 PM   #10
Pinecone's Avatar
Edmonton , Alberta
First Expensive Piece has arrived:
Old 06-12-2015, 12:49 PM   #11
Pinecone's Avatar
Edmonton , Alberta
I guess I should provide details...
It's a 3500lb Flexiride, 6 x 5.5. Maybe a bit overkill for this, but what the hell. Hopefully, I get a good lift in ride height without needing a spacer. Next up is wheels & tires, maybe T02's or AWC 870s and LT tires. I may need to go online, since nobody around here carries trailer wheels that aren't white steelies.
Old 06-12-2015, 01:00 PM   #12
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
We put a 3500# dexter under our 17' Caravel, haven't regretted the choice yet.
Excited to watch your progress on this project!
Stephanie
Old 06-12-2015, 05:47 PM   #13
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Hey there, I'm at a similar is point on the Sovereign, getting the axles or in my case axle-less axles on is a check in the progress box. Glad to see you stuck with the project. William
truckasaurus is offline   Reply With Quote
Old 06-12-2015, 08:42 PM   #14
Pinecone's Avatar
Edmonton , Alberta
Thanks Truck, your all-in dedication to your trailers is still an inspiration.
I hoisted the axle into position with straps to get an idea of the ride height. For comparison, I positioned the old axle next to it:
That's a ~4.5" rise in height. That's pretty good, but I'm thinking of adding an additional 2" spacer to make it a roughly 6" raise from stock.
With the stock 4" drop axle, there is only a few inches of ground clearance, and the wheel intrudes pretty far into the cabin.
Sovereign Redux Zeppelinium 1974 - 1979 Sovereign 138 01-23-2013 08:19 AM
Ambassador Awesomeness - 1972 Redux (picture heavy) BrockLives 1970 -1973 Ambassador 30 07-15-2010 11:25 AM
NWS : Rally Redux, Trout Lake 2006 Janet H Forum Rallies & Meet Ups 99 07-22-2006 06:39 PM
