Old 12-11-2009, 01:56 PM   #1
Columbus , Ohio
Tie Downs for a truck camper
I have a 1961 Avion C 11 and am mounting it on a 1995 Silverado Ext Cab. 2500, with a 6.5TD. Does anyone have any advice on what kind of Tie downs to use or any secretes to success? There does not appear to be any links to this or any information on this form relating to tie downs.
ted2020 is offline   Reply With Quote
Old 12-11-2009, 02:20 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Camper securing
My dad has a camper and has one hook at the corner of each end of the rear bumper, which is used with a chain and turnbuckle to secure the rear of the camper down. At the front he has a 1 1/2 inch diameter square steel bar welded to the underside of the frame. This bar extends past the edges of the box with enough clearance so that chains and turnbuckles don't rub on the box sides. Picture is older, but may still show the concept.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 12-11-2009, 02:21 PM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
Check out Tork Lift International. They have been tying down campers for 30 years.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 12-11-2009, 03:14 PM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
"Tie downs" just sound weak for the task at hand.
I was thinking of things more like grade-5(or 8) bolts
and enough mounting steel to ensure the job was
done in such a way that it would not even wiggle!
TSC has a fair selection of Grade 5 or 8 bolts and/or
"all-thread".
kennethowens is offline   Reply With Quote
Old 12-11-2009, 03:24 PM   #5
1967 26' Overlander
1968 30' Sovereign
The unit has to be able to "give." If it didn't the truck bed would separate from the chassis.
WBCCI 17109
Old 12-11-2009, 08:20 PM   #6
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Tork Lift and Happi-Jack are the 2 major players. We use TL and are very happy with them. They bolt to the frame as opposed to HJ which bolt to the bed, and require drilling the bed. Both work well...personal preference.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 12-11-2009, 08:36 PM   #7
Campaz's Avatar
1987 23' Sovereign
Tucson , Arizona
What Bill says, I used Tork Lift and was happy with them.
Rick
WBCCI# 4652
Four Corners Unit
Campaz is offline   Reply With Quote
Old 12-11-2009, 08:53 PM   #8
BeBop's Avatar
2000 27' Safari
Berkeley , California
Tork Lift... bolt on to the chassis and go.
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 12-11-2009, 09:04 PM   #9
1983 31' International
Belle Fourche , South Dakota
stablelift.com
quick on/quick off
310astream is offline   Reply With Quote
Old 12-16-2009, 03:55 PM   #10
Columbus , Ohio
Tie Downs - Thanks for the links
I sent an email to Stablelifts (I am interested to see if they can fit a 1961 Avion). I will probably end up using the Trok lift product. They are about $265. The Stablelift is about $2,500, but it seems like a really interesting product.
Old 12-16-2009, 06:05 PM   #11
1 Rivet Short
1989 25' Excella
Ted, do what you want...but I think the SL would really detract from a very cool Vintage TC...
The TL and HJ are much more...discreet.
Bill
tie downs truck camper
Avion Truck Camper moosetags On The Road... 41 06-18-2009 05:42 AM
Truck camper with AS trailer? like to hear your ideas on this one... OhioMarty Tow Vehicles 11 05-18-2008 02:54 PM
Avion Truck Camper Refridgerator trevisgardne Refrigerators 2 03-23-2006 08:56 AM
Awning tie downs? docbluedevil Awnings 6 04-10-2004 08:56 PM
