Old 10-07-2012, 12:15 PM   #1
Santa Clarita , California
Silver Streak waste valve repair
Hi,
I had to replace the Thetford Blade Valve on my 1969 Silver Stream Rocket Deluxe waste tank. The Thetford valve had been glued in to the ABS waste sanitary Y so I had to cut that out and need to replace the entire ABS fitting as well as the blade valve. Trouble is, I can't find the same style anywhere (picture attached). It's a 3"x3"x2" double sanitary "T" fitting. Does anyone have advice where I can find this? Or have you done the same kind of repair and have another solution?
Thank you,
Chris Dunne
Name:	SS DblSanitaryT.jpg
mrcjdunne is offline   Reply With Quote
Old 10-07-2012, 01:23 PM   #2
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Hi Chris.
I saw them in a local mobile home parts store in our area, I'm pretty sure that if can't find them online we can get you one.
Keep us posted.
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 10-07-2012, 01:26 PM   #3
1973 31' Sovereign
2007 20' Safari SE
ABS Pipe Fittings - Fittings - Grainger Industrial Supply
2 chronicles 7:14
Old 10-07-2012, 02:02 PM   #4
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Elbow 90 Deg 3x3x1-1/2...
Hi Chris,
Wow, that connector is something strange. You should see if you can save it.
The closest thing that I can see you getting would be a 3x3x1-1/2 elbow under Grainger's Part Number 3GUP4. However, it looks like you will need to adapt another 90 degree 1-1/2 fitting to match.
The 3GUP1 looks like a 3x3x3 (female x male x male).
Good Luck!
Chris
newsgauger is offline   Reply With Quote
Old 10-07-2012, 03:02 PM   #5
Thanks. It is an odd fitting. I think I'll probably need to get the 3x3x3 Grainger 3GUP1 and a 3" to 2" reducing coupler. Unless somewhere out there is a 3x3x2. I will call Fergusons tomorrow. I couldn't see their online catalog because I'm don't have an account with them.
Chris
Old 10-07-2012, 05:44 PM   #6
1973 31' Sovereign
2007 20' Safari SE
chris this seems like it should work
GRAINGER APPROVED VENDOR Tee Wye, 3 x 3 x 2 In, ABS, Hub Connection - ABS Pipe Fittings - 1WHW8|1WHW8 - Grainger Industrial Supply
and this can be used with a coupler.
GRAINGER APPROVED VENDOR Reducing Sanitary Tee, 3 x 3 x 2 In - ABS Pipe Fittings - 1WHU4|1WHU4 - Grainger Industrial Supply
hope it helps
2 chronicles 7:14
Old 10-07-2012, 07:14 PM   #7
Phoenix , Arizona
I had an odd fitting that I needed for my 1969 Avion C-11. We ended up making it. Ticki2 found a place that had odd fittings. I'll see if I can find it.
M2HB is offline   Reply With Quote
Old 10-07-2012, 07:19 PM   #8
Phoenix , Arizona
Here is a link to ticki2's info on an odd fitting from Genova pipe.
http://www.airforums.com/forums/f417...1-90779-4.html
Genova may have what you are looking for. Good luck.
Old 10-08-2012, 06:26 AM   #9
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
3x3x2...
Good Morning Chris,
Grainger also carry the Elbow 90 Deg 3x3x2, PN 3GUR3. This is similar to the one I posted earlier. But, still will need another fitting to make that 90 degree 2" bend.
Good Luck!
Chris
Old 10-08-2012, 09:05 AM   #10
Originally Posted by newsgauger View Post
Good Morning Chris,
Good Luck!
Chris
That one is very close. But it's not sanitary. When black waste comes out of the 3" side it can flow into the 2" gray lines. If I were to flip this one 90 degrees CW so the black waste came down the bend, the 2" waste line would be vertical rather than in a horizontal orientation that I need.
I'm beginning to think this piece was either custom cast for SS or is just not made anymore.
Chris
Old 10-08-2012, 09:56 AM   #11
SSSabre's Avatar
Collinsville , Oklahoma
We had the same "Y" or "T" in our unit. A previous owner cut off the 1.5" portion and sealed with a flat piece of PDC. The gray drain was then diverted down, no longer sharing the outlet with the black tank. A link to our as-delivered installation is below.
Old installation
It might be easier to MacGyver a new drain than try to find and equivalent "T".
Paul
1970 Silver Streak Sabre Model 20
See our project at www.silverstreaksabre.com
SSSabre is offline   Reply With Quote
Old 10-08-2012, 10:05 AM   #12
nmbosa's Avatar
Nowhere , Washington
Chris
Chris, I think that 3x3x3 double sanitary tee from Grainger with a 2" reducer on the gray water side should work fine. That will be very close to original and allow you to fit everything in the same place. Making the pipe bigger on the downstream side is not going to cause any flow restrictions for the gray water. It would only be a problem if you were going from the 2" gray line to a smaller tee fitting.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 10-08-2012, 10:55 AM   #13
Old installation
Paul,
I was going to go through your blog today actually. I knew you would have a similar setup. Turns out you have a Frankenstein fitting! I am going to MacGyver it in. Already spent to much fruitless effort trying to match it.
Chris
Old 10-08-2012, 10:56 AM   #14
Norm
Norm,
I am going to go with the 3x3x3 with a reducer. It is by far the easiest solution.
Chris
