Old 03-16-2009, 03:21 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Silver Streak project
Thought I would document my renovation of our 1963 Silver Streak. Hoping the multitude of talent will chime in with ideas and criticisms since this will be a learn as I go project. Some before's
ID:	77018   Click image for larger version
ID:	77020   Click image for larger version
SilverHoot is offline   Reply With Quote
Old 03-16-2009, 03:33 PM   #2
SilverHoot's Avatar
1967 24' Tradewind
Gutting
After coming across a couple of soft spots in the sub floor have decided to completely gut the interior to insure a sound floor everywhere. Have not decided on complete floor replacement yet.
ID:	77025   Click image for larger version
ID:	77027   Click image for larger version
Old 03-16-2009, 03:43 PM   #3
1972 Travelux Princess 25
Cobourg , Ontario
Very interesting project, I am looking forward to learning about the differences between a Silver Streak and Airstream.
Have you worked on an Airstream before?
Looks like you have your work cut out. What kind of reno are you planning? Restoration, modernization, or completely new design?
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-16-2009, 03:44 PM   #4
SilverHoot's Avatar
1967 24' Tradewind
More Gutting and discovery
Just about have it completely gutted. Just have the uppers to remove. Look at this OLD electric shaver that I found waaaay behind the bathtub. It is in primo shape. Bet somebody went kinda crazy looking for it, way back when!
ID:	77029   Click image for larger version
Old 03-17-2009, 07:54 AM   #5
SilverHoot's Avatar
1967 24' Tradewind
Ganaraska,
Still deciding if I will attempt to change the layout. Hopefully some members will chime in with ideas. We would like to have a dedicated bed instead of gaucho or dinette bed as this was originally configured. Plan to add a grey tank and will modernize all appliances. I have the entire interior to use as templates for reconstruct. No, I have never worked on an Airstream before and this is our first travel trailer of any kind. One difference between the Airstream and SS that I have come across is that the channel at the floor that the interior and exterior walls attach to is aluminum on the SS and steel on the Airstreams.If you would like to know about anything in particular, just let me know. Again, suggestions WELCOME!
Old 03-17-2009, 08:10 AM   #6
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Your project looks very interesting, what are the internal dimensions of your '63? I ask it she looks about the same as an Overlander.
truckasaurus is offline   Reply With Quote
Old 03-17-2009, 08:22 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Truckasaurus,
Interior dimensions are 6' 11" x 18' 7" Probably more similar to a Safari?
Old 03-18-2009, 09:09 AM   #8
SilverHoot's Avatar
1967 24' Tradewind
Uppers are out
She's been completely gutted and figuring out what to do next. Remove belly pan or lower interior skins. Anybody know if the interior endcaps are removed in one piece as with an Airstream? There's a dent in the rear endcap exterior that I want to improve the appearance. Wish I knew how you all do those nice drawings so that I could show my proposed layout.
Old 03-18-2009, 09:55 AM   #9
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I have not worked on an SS (disclaimer). From the photos I see you do not have solid end caps. I see rivet lines. Early Airstreams (50s 40s era) end caps were made up like that. Some industrious people have stripped the end caps and polished them to a nice shine. I would like to see your layout too. Google Sketchup has been used for this. Its free!
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-18-2009, 10:04 AM   #10
SilverHoot's Avatar
1967 24' Tradewind
Lee,
Yes, the end caps are riveted but was wondering if it will come out as one piece rather than having to disassemble each wedge that makes the radius. Guess there's a sure way to find out! I had downloaded Google Sketchup a few weeks back but couldn't figure it out. Maybe I'll try some more.
Old 03-18-2009, 10:20 AM   #11
1967 22' Safari
1960 Caravel
Images: 8
Lee,
Probably stating the obvious here but, start on the end thats closest to the dent to minimize the work. Go for it.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-18-2009, 10:24 AM   #12
Spend some time with the tutorials on Sketchup and you'll get the hang of it. It's a bit tough to learn at first, but after you learn the basics, you can do some fun things with it.
I don't know if the interior endcaps were assembled as one piece on a bench like they were on Airstreams, but my guess is that they were, because it would be easier to assemble on a bench than it would be while working over one's head on the interior.
Can you tell if the rivets are pop rivets, or solid rivets? If they're solid, then chances are it was all assembled on a bench before installation.
Good luck, and keep the pictures coming. It looks like a fun renovation.
Old 03-18-2009, 10:29 AM   #13
Oh, one other thing--
Not sure if you reversed the two brands here?
My j-channel (aka c-channel or u-channel depending on the year) that bolts to the plywood subfloor and has the inner and outer skins riveted to it, is made of aluminum and not steel. Same thing for every other Airstream I've ever seen, or seen pictures of. Perhaps you meant it the other way and that the Silver Streak uses a steel channel?
Anyway, good luck!
Old 03-18-2009, 02:48 PM   #14
SilverHoot's Avatar
1967 24' Tradewind
My mistake
My mistake, I had thought I had seen that the u- channel (I'll call it 'U' for mine since that's the orientation) on some Airstream restores were all rusted and needed replacement , mine is definitely aluminum. See, that's what I need, folks to keep me in line. Something that I DO think is different ( and not happy about it) from most but maybe not all Airstreams is that SS has what I would call 'beading' detail on many of their panels. Hopefully this can be reproduced by a sheetmetal shop. Makes for a more difficult panel replacement I would think. Take a look. Thanks Utee for straightening me out.
ID:	77121   Click image for larger version
Airstream vs. Silver Streak? chapparel Vintage Kin 13 04-01-2016 08:28 AM
Silver streak Pepsi Vintage Kin 23 03-10-2008 07:49 PM
Silver Streak Ultradog Vintage Kin 3 12-31-2006 12:12 PM
