Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 07-30-2015, 04:35 PM   #1
Portland , Oregon
Silver Streak Clipper Lock Set Question
My trailer, 1952, s/n 2412, came with no lock set. Also, cut hinges, but that is another story.
So I do have pictures.
First is an exterior shot, including a faint tracing of the original handle plate.
Next is the interior skin, it has been removed. This also has a plate outline. I am guessing the mechanism.
Then a shot of the interior ribs with a plate.
Last is the same as above showing the rib side. Funny thing is, no latch bolt hole.
Definitely not a Bargman L 77.. Am trying VTS., and web searches. Click image for larger version
ID:	244278Click image for larger version
ID:	244279Click image for larger version
ID:	244280Click image for larger version
Any clues as to what I need?
I am off to see if the door frame has some screw holes for some sort of removed latch plate.
Robert
Bikeukeguy
bikeukeguy is offline   Reply With Quote
Old 03-21-2016, 04:02 PM   #2
GlamperGirl
Hi bikeukeguy, Did you wind up using Silver Bullet for your work? I can't find anyone as a reference to use them. I am in Seattle- Dena
thumbelinadj is offline   Reply With Quote
Old 03-22-2016, 08:35 PM   #3
Bluestar99's Avatar
Bartlett , Illinois
I have a 51 Clipper. Do you want pictures of the lock set that is on it?
Bluestar99 is offline   Reply With Quote
Old 03-23-2016, 03:06 AM   #4
Portland , Oregon
Pictures would be wonderful. Do you have a dead bolt lock set on yours or does this appear as an option installed later?
Old 03-23-2016, 03:08 AM   #5
Portland , Oregon
No work done yet. There is a small shop in Forrest Grove, OP...Sunset RV that works on Vintage Airstreams.
Old 03-23-2016, 05:52 PM   #6
Bluestar99's Avatar
Bartlett , Illinois
Mine had no deadbolt. Here is what mine looks like.
Old 03-23-2016, 07:03 PM   #7
Portland , Oregon
Thanks. I see a plate I did not know about. VTS has the lock set.
1950 Silver Streak Clipper - Pipe Frame robandzoe 1947 - 1953 Clipper 12 04-10-2019 10:42 PM
1952(?) Silver Streak Clipper Window Question bikeukeguy Windows, Doors, Locks & Vents 2 03-31-2014 10:38 PM
silver streak clipper door lock clipperguy Vintage Kin 1 05-01-2011 05:17 PM
