Old 09-23-2007, 12:03 AM   #1
Streamline Imperial
SilvrSausage's Avatar
Bellflower , California
Post Seeking advice on replacing butyl tape sealant on ridged aluminum SOB
I'm restoring a SOB, 1975 Northwest "proto-toyhauler" to be exact. It is wood frame with sheet aluminum siding, the kind that is stamped to look somewhat like horizontal boards. The edge-corners are sealed with extruded aluminum angle trim with a (missing) vinyl strip that goes over the screws.
I'm wondering what is the best way to install the soft butyl sealant tape. Along the roof edges seems pretty straightforward, but on the vertical surfaces, the corrugated ridges must be sealed as well. It looks like the corrugations are just tall enough that the 3/16" thick tape (thickest I found) might not seal in the valleys when it is completely compressed/squeezed out at the ridges. Is there thicker tape out there, or should I cut 3" pieces for the valleys, and lay another continuous piece over that?
-SilverSausage
It seems I love the mountains and deserts more than my friends do. I sure miss them!
1971 Streamline Imperial project "Silver Snausage", 1985 Coleman tent trailer, 1964 Little Dipper, 1975 Northwest "Proto Toyhauler", 2004 Harbor Freight folding, still seeking my Airstream.
SilvrSausage is offline   Reply With Quote
Ideas for replacing flooring for Minuet with aluminum composite floor pattyo Repairing/Replacing Floor &/or Frame 6 06-24-2006 09:56 PM
Desperately Seeking Hipster Fulltimers/Advice! iamsusanq 2002 - 2005 International 17 12-08-2004 09:50 PM
Seeking Advice.... jtshipp On The Road... 9 05-17-2004 05:42 PM
Ridged pavement trumpwer On The Road... 11 12-12-2003 04:51 PM
replacing aluminum on exterior cherring Ribs, Skins & Rivets 2 09-25-2003 03:08 PM
