Old 05-05-2018, 10:49 AM   #1
2005 19' Safari
santa barbara , California
replacing toilet in 1965 Overlander
I have the original bathroom layout, molded fiberglass, and I need to replace the original leaking toilet. Is there a replacement available that will work in that space while maintaining the original look. It would need to use a standard toilet seat and be flat under the seat so it would fit snug against the underside of the fiberglass. I don't mind doing some modifications but can't seem to find a compatible toilet. Any ideas
cmugler is offline   Reply With Quote
Old 05-05-2018, 11:07 AM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Look for low profile RV toilet then you can compare the various models to what you are looking for. There are plenty of sources to choose from.
sgschwend is offline   Reply With Quote
Old 05-05-2018, 12:03 PM   #3
1966 22' Safari
Fredericksburg , Texas
On our 66, the old porcelain original Thetford had too many rinky dink modifications to keep it. During our renovation we placed a Thetford molded unit in its place. The new one was about 3/4 short and the existing hole had to be cut a little larger. I made a short platform to support it. After a couple of years, still working great and less weight. Let me know if you need more details. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 07-16-2018, 07:32 AM   #4
The Rambler's Avatar
1964 26' Overlander
Ingleside , Texas
Hello, have you solved you're toilet issue? We have a 64 Overlander I have the original toilet which I would think is the same. We are changing over to a composting toilet. Are you interested in ours?
The Rambler is offline   Reply With Quote
Old 07-17-2018, 12:27 AM   #5
2005 19' Safari
i no longer have the overlander so I am all set thanks
Hattrick 1965 Airstream Overlander :: 1965 Airstream Overlander Seanhattrick Airstream Registry Discussions 0 09-02-2015 06:45 AM
1964 Overlander toilet repairing or replacing Rock Crazy General Repair Forum 18 10-05-2013 05:03 PM
1965 airstream travel trailor & 1965 ford p/u step side selling both drive away! eBay Watch Airstreams on eBay 0 07-29-2013 08:30 AM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 04:52 PM
1965 tow test of a 1965 Dodge Cruiser Tow Vehicles 1 04-07-2004 09:49 AM
