Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 05-13-2008, 12:38 PM   #1
Dana13
Profile:  Meridian , Mississippi
Question about convertors
We have purchased a 1971 Avion. I know this is airstream forums but I cant find much online about avions. When we plug the avion up to 110 outlet it will run the air and electrical outlets. My question is can you do away with the convertor and fix it where everything (lights pumps etc...) will run off of just a 110 connection? Arent the newer travel trailers like that? I know they have generators but not having one is fine with me. Everything is going to be electric except for the stove. Any help will be greatly appreciated! THanks!
Dana13 is offline   Reply With Quote
Old 05-13-2008, 12:48 PM   #2
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Welcome to the forums from a fellow Mississippian. We consider an Avion a 'cousin' and love to have ya' here.
If I understand your question corectly...The electrical system might seem a bit odd to a person looking at it for the first time, but the modern RV setup has evolved into a pretty good arrangement. The converter will take the 110 and product 12v for all of the lighting... so you sorta are already 110V. I'm not aware of a new trailer that has greatly deviated from this theme. By sticking with a 12v based system quite a few of us have avoided the generators for everything except AC (which we really do need here in MS )
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
HiHoAgRV is online now   Reply With Quote
Old 05-13-2008, 12:59 PM   #3
n2916s
Profile:  1986 31' Sovereign
Miami , Florida
Not to mention that the electronic controls for your refrigerator, water heater and furnace all require 12 volts to function. So you would have to replace them. If you remove the converter and battery you will effect the resale value of your Avion.
A handy place to learn:
Poop Sheets by phred
mike
Old 05-13-2008, 01:50 PM   #4
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Unless you are intending to Park it in one location for the rest of it's life the awnser is no.
There are 2 electrical systems in all trailer. Park models may be what you are questioning do run on 110 because they will never travel. You rig has 2 systems, the 110 to run the AC, a few 110 outlets, and the converter. While all the other electrical things, lights, refigerater, heater, fans, and tank monitors in the trailer are 12 volts running off the batteries which are charged while you are attached to 110.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 05-13-2008, 03:08 PM   #5
vinstream
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
golden , Colorado
The question I would raise to you is why?.. What are you trying to gain?
http://www.VinStream.com
"Redesigning Life & Road To Vintage Custom Trailers"
vinstream is offline   Reply With Quote
Old 05-13-2008, 06:49 PM   #6
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Even if you don't realize it, there are many systems that run on, or require 12 volt as a reference. All fans in the roof and kitchen are 12 volt, the amplifier for the tv antenna is 12 volt, the tank monitors are 12 volt, the water pump is 12 volt, the blower for the furnace is 12 volt. Most of the lights are also 12 volt. Unless you are going to completely strip the wiring in the trailer, and refit it with all 120 volt items (a huge pain, not to mention expensive), the answer is NO. I have never seen a 120 volt RV type water pump for the fresh water system, either.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-14-2008, 07:51 AM   #7
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
SILVERAVION :: Index Test
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 05-14-2008, 08:58 AM   #8
Dana13
I appreciate all the respones to my question! We arent going back orginal with the avion. We took the old fridge out and putting in an electric one. There is a outlet behind were the old one came out. As far as travel, we only really go to the beach and that is about the only place we will take it back and forth. The air runs when we just plug in to the 110 outlet. So it was just all a little confusing to me to need the convertor. Which i will probably be keeping espcially since i have found nice people like yall to answer my questions. I would love to see photos of any that have redone their rvs like we are doing. We have painted inside walls and cabinets. I will show pics when we are done. The avion cabinets werent in the best condition and it probably could have been just used for parts. Any more comments are greatly appreciated.
