Old 02-24-2014, 12:21 PM   #1
ariverclown's Avatar
Longview , Texas
Please look at these "What is it pictures"
Name:	What is it 1.jpg
Name:	What is it 2.jpg
These are on the tongue of my 66 Silver Streak that I'm working on. I think it may have something to do with the breaks. One wire is cut on the unit mounted in the frame and sparks when I touch the ends together. Then theres that big round oval that is flat in the front.
Anyhow, anybody???
Ron
ariverclown is offline   Reply With Quote
Old 02-24-2014, 12:33 PM   #2
Gainesville , Florida
Breakaway switch? Jim
avionstream is online now   Reply With Quote
Old 02-24-2014, 12:42 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm pretty sure the thing centered in the 1st photo is an old breakaway switch (as Jim said) that's missing some parts.
The thing centered in the 2nd photo looks like it might be the remains of some sort of built-in level indicator, if the 2 channels cut in it once held bubble tubes. It looks a bit heavy-duty for a level, though.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 02-24-2014, 01:03 PM   #4
1974 Argosy 20
Kooskia , Idaho
Yes, old stile bubble level that was a common item in the 60's to mid 80's for the round item. Remove it and toss it and get stick on ones from today.
The wired item is the break away switch for the electric brakes. Also time for a replacement, which probably should be moved to the outside of the frame so it has a better chance to have the pull wire work right and not get tangled with other items.
Old 02-24-2014, 01:09 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Level
Try this for the level and the other item is the breakaway switch for the trailer brakes. Reese 52000 Level All Crane Level | eBay The breakaway switch apparently has a short in it (or the electric brakes were energized) and that is why the wire was cut (to unlock the trailers brakes). That is why when the wires are touched together you get sparks! As you can see the level is almost always on eBay. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-24-2014, 01:12 PM   #6
Longview , Texas
Thanks all. Great help
