06-19-2015, 12:51 PM
Superior
insulation removal tips
Gurus,
Does anyone have a nifty method of removing the sprayed-in foam that I find on my Streamline? I have not decided if ALL of it needs to come out, but some sections do for sure. Last weekend I cleaned out some with putty knives, but it's SO difficult and slow. It there a nifty tool of any sort? Drill attachment? Miracle vanishing spray? Thanks!
06-19-2015, 01:10 PM
1973 21' Globetrotter
Houston
Miracle vanishing spray! Well, there might be...and this is more of an interesting bit of trivia piece of information here (rather than a recommendation), but...If you pour acetone into a shallow bowl and then set a styrofoam cup in it, it will disolve like magic. Could be it would do the same for your sprayed in insulation, but working with atomized acetone would be very dangerous.
Seriously, you might try using an oscillating tool to cut the insulation into vertical strips a few inches wide, and then you might get that stip to "peel" out more easily than just pecking away at the entire section. Those oscillating tools also have a scraper attachment that if you got it under the end of the previously mentioned strip of insulation might ease freeing the insulation from the shell.
Good luck!
06-19-2015, 09:47 PM
1979 23' Safari
Wayland
, New York
Why are you taking it out? Leak hunting?
I'll second the oscillating tool with a scraping head. Seems like the best possible solution. Other than leaving the stuff there. Keep the head at a low angle so it doesn't pound outward against the exterior skin , possibly causing stned, outward dents.
Miracle elbow grease!
I guess this is a good example of why not to use spray foam as has come up many times on the forums.
06-20-2015, 12:32 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Eric,
Wondering why is the need of the total removal? There isn't a simple miracle fast way to do it, acetona helps while the foam isn't cured yet or in big quantities but I wouldn't recommend it, not only because of the monetary factor involved but also due the hazards involved.
"Cutting and removing" small sections is your best shot, If you are trying to solve some leaks, a small area around the window should give you enough space to trace the leak and seal it from outside and the spray foam again.
The spray foam if well applied "SHOULD" help to prevent water intrusion as well.
Please keep us posted!
Still One Nation under GOD
2 chronicles 7:14
07-05-2015, 09:45 AM
Superior
I'm coming around to the idea of leaving it in. Is IS a good insulator, and, urethane foam is still considered safe 40 years later. I'll just need to vacuum up all the dead bugs.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
07-05-2015, 08:35 PM
Houston
The old saying "if it ain't broke..." comes to mind!
07-10-2015, 05:04 PM
Slympicins
2015 27' Flying Cloud
Sevierville
, Tennessee
I suppose if you decided to go the ionized acetone route, it's quite possible we will be seeing you and your AS on the news. Not a great idea if thought through. Scrape the areas which are troubling and add new foam to those areas.
