01-30-2014, 07:09 AM
redondo beach
Found a 1950s SS Clipper
I have found and am on Recon as we speak. pictures soon. John Los Angeles, CA
01-31-2014, 04:10 AM
redondo beach
Just got back 520 miles round trip in that old Econoline with a 170 and three on the tree. The grapevine was brutal 30mph at the steep parts.
Here she is Serial # 2250 18 foot interior is all interacted minus heater and frig. Skin is good. We drove straight up and back sleeping in the truck with no heat.
01-31-2014, 04:55 AM
1986 32' Excella
Canton
, Georgia
Cool! Can't wait to see more photos!
01-31-2014, 05:02 AM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
I had an Econoline pick up too. 3 on the tree. Cool combo.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
01-31-2014, 06:04 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
Very cool trailer and Econline.
I had a 66 Ford Econline van with the same engine and 3 speed as a 16 year old.
Man was that van slow.
Good luck on that trailer.
Mike
01-31-2014, 09:18 AM
1964 17' Bambi II
Schererville
, Indiana
Great find! Love your combo & looking forward to more pix!
Becky
1964 Bambi II
1988 Avion 32S
02-02-2014, 07:37 AM
redondo beach
I have been disassembling the interior to get at the flooring. I need to replace the entire subfloor. I should have the interior out today. The frig and heater are the only items I notice missing or replaced.
There was another plastic tank next to the box with the red hose attached to it. What are they? I am not familiar with self contained units. I have had BIG park models that hook up.
I am curious to see how this Silver Streak is built. I had a 100 percent original clean, Excellent condition 1949 Spartan Royal mansion. I restored the interior using all the original panels. I resprayed the panels and woodwork with Shellac just like they did originally. I rewired and added a new breaker box, insulated and ran new romex. The Spartan IMO are the best constructed Trailers around. The one I owned came from michigan. It sat in 50 years of winters and did NOT leak.
02-02-2014, 08:11 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
The box in the photo is the fresh water tank.
02-02-2014, 09:27 AM
redondo beach
What would the one next to it do? I removed it already
02-04-2014, 04:31 PM
1954 18' Globetrotter
Wrexham
, Clwyd
That is one cool excellent value Clipper. The units inside are fantastic.
Damn site better option than the previous one.
Love the truck............3 on the tree???......it's a wonder it got you home so quickly.
Looking forward to seeing it when I come back for my holiday (vacation) this December
Rob
02-04-2014, 10:36 PM
redondo beach
The frame is a tube with aluminum outriggers weird. I have the subfloor out.
02-05-2014, 02:38 PM
Wrexham
, Clwyd
That's the way all the Clippers were built.
The problem with Clippers is, there is not enough diagonal bracing to the outriggers and if the trailer is subjected to snaking behind the tow vehicle, eventually the chassis fails. There were numerous instances of the tube pulling out of the outriggers and leaving the trailer totally disconnected from the tow vehicle because of this and because of galvanic corrosion between steel and aluminium. They also had a recommended top towing speed of 40mph because of the chassis construction.
If you aren't changing the chassis, you will have to look very carefully at the junctions of the aluminium outriggers and steel pipe. The aluminium will corrode as will the aluminium rivets.
Might be an idea to beef up the chassis with steel outriggers and braces.
I won't have those problems with mine because I'm doing a body-off and replacing the complete chassis in galvanised steel.
02-22-2014, 11:03 PM
redondo beach
I am looking for information on front and rear window replacement.
02-23-2014, 07:34 AM
Cerritos
We used Lexan to replace the windows. Home Depot sells them clear or tinted for $27/window. Make sure to replace the 1/4" wood insert that supports  the window frame. The pic below show 1/4" plywood treated with Thompson's water sealer.
