Old 08-27-2011, 06:32 PM   #1
TikiPatrick's Avatar
Glendale , California
Electrical Question
I'm getting ready to wire a permanent hook up for my 1972 Streamline Imperial.
It has 4 20 amp breakers and of course one giant plug.
If anyone could point me in the right direction that would be much appreciated!!
TikiPatrick is offline   Reply With Quote
Old 08-27-2011, 06:39 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
What is it that you seek, grasshopper?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 08-27-2011, 06:53 PM   #3
Well, I guess it's a basic question of how do I wire 80 amps in to one outlet? Is there an 80 amp breaker that I can put in put into the breaker box? What gauge romex to run? 2 wire or 3 wire? (I know this is real elementary stuff, but I gotta start some where!).
I read somewhere that the AC needs 30 amps, so what's up with that?
Old 08-27-2011, 07:17 PM   #4
DanielB's Avatar
Someone else helped me with mine, but I'll give it a stab. Just verify what I say and don't take it for the gospel.
The breaker box is important. Is it proprietary or will it hold the generic SquareD breakers?
If it will hold the squareD then here is an 80 amp squareD breaker as an example. Something like this would probably work:
Circuit Breaker 80a - Circuit Breakers - Distribution - 2DN05 : Grainger Industrial Supply
I think my ac is on a 30 amp breaker. It sucks a lot of juice on startup.
- Andrew Carnegie
Old 08-27-2011, 07:25 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Electrical Question
Greetings TikiPatrick!
I think that some clarification might be needed to get a clear answer to your question. First of all, if you are planning to travel with your coach, there are two general choices when it comes to shorepower electrical boxes 30-AMP (the industry standard before rigs with two roof air conditioners became common) or 50-AMP. Unless everything in your coach is 120-volt AC electric, it should be possible to wire to the 50-AMP standard. If your plan is to setup your coach as a semi-permanent cabin, you could look into a 100-AMP mobile home service as that would include the 100-AMP main breaker and room for your breakers totalling 80-AMPs.
Basically, on our Vintage coaches, the roof-mounted air conditioners were wired to a dedicated 20-AMP circuit as the compressor requires 20-AMP on startup. Then there would usually be two additional circuits . . . one serving the 120-volt outlets and another serving the Univolt and the 120-volt outlet for the refrigerator AC heating element. These circuits would be in a 30-AMP RV service box. When a second air conditioner or a large microwave was added the service on a modern RV often went to 50-AMP boxes to allow for the additional electrical draw from the increased number of electrical appliances.
The most important question is whether your coach is going to continue to be mobile . . . . or if it is going to become a permanent fixture on a lot.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 08-27-2011, 07:36 PM   #6
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Just because you camper has 4 20amp breakers does not mean you need a total of 80amps on the supply. Each circuit is protected to 20amps or the breaker will trip. You may have a circuit of lights drawing only 1 or 2 amps total.
If you have an RV plug on your camper the easiest thing to do is get the complementary RV plug in box available from Home Depot or Lowes or any other electrical supply store. Add that to you main breaker box (or if unsure have your electrician do it) as you would any other outlet - 30amp or 50amp. Short runs you could use 10/2 wire sold in bulk or purchased by length. Longer runs use a little bigger.
What outlet in a campground would you use if you had it on the road - 30 or 50amp? That would be the box you would need to buy. Use your existing power cord to just plug into your new RV box.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-27-2011, 08:04 PM   #7
All you need is a well wired 30 amp outlet at 120 volts AC.
Old 08-27-2011, 08:48 PM   #8
Outstanding info everyone, Thank you very much!!
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
1960 Electrical 110V & 12V question Lothlorian Electrical - Systems, Generators, Batteries & Solar 19 05-08-2011 11:58 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
