Old 03-04-2014, 06:50 PM   #1
Glendale , California
Curtis Wright and Early Silver Streak beds
Howdy all. After taking inventory of my interior trailer "stuff", I was puzzled by the bed frames that look original. I have seen these bed frames that look kind of like a coffin in other interior pictures of CWs. My frames are made of hard wood, probably pine, with plywood on the bottom and have a cushion with springs with cotton batting inside that go on top of the frames. Here are a few pictures of what I have. I have a friend with a 53 Silver streak clipper that has "tilt" beds. His are apparently original to those trailers. Did the early CWs have those tilt beds as an option? Do the bed frames that I have look original? I was planning on using them and putting plywood on top. With a cushion made from foam covered with some nice material, I'd have two beds. Any knowledge and/or pictures of your original beds would be helpful and appreciated! Chris
ID:	206808   Click image for larger version
chris hart is offline   Reply With Quote
Old 03-04-2014, 10:06 PM   #2
oh2bcarefree's Avatar
House Springs , Missouri
Images: 48
Hi Chris,
You may want to check out Melody Ranch's thread "47 Curtis Wright" - I think he has some photos in there of an original sliding bed, post #53. You may also want to check those original mattresses. In post #69 you can see what he found in his...
http://www.airforums.com/forums/f417...ght-50200.html
Good luck!
Tina
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Old 03-05-2014, 03:19 AM   #3
redondo beach , California
I have two SS clippers. One has the rare twin beds that recline and one has the style you have with aluminum wrapped around the wood.
PLVMB is offline   Reply With Quote
Old 03-05-2014, 08:24 AM   #4
Randolph , Minnesota
Tilt beds
Chris
I have a 1948 Curtis Wright Model 5, #8254 that has the tilt up beds. I would be happy to take some pictures and measurements if that would help you out. I am also wondering what you are doing regarding the pipe frame. Mine is in poor condition due to dissimilar metal corrosion.
Regards
Hoghide
Hoghide is offline   Reply With Quote
Old 03-05-2014, 09:26 PM   #5
Hi you guys. Thanks for the responses. The beds that I have are fine for the trailer. They seem so plain! They are very low to the floor. Someone said that it was a little like camping on the ground using the original beds. I'll see what thickness of foam I can buy to put on top of the wooden bed frames to bring up the height. I don't want to interfere with the ability to open the little original cabinets at the end of the beds. I would like to see what the tilt beds look like. I hear they are a little more substantial than the frames I have. As for the pipe frame, everything looks "renovatable". A little strengthening of some of the outriggers is in order, POR15 on the pipe, and I think that's all that will be needed. Screwing the plywood floor to the c channel around the sides of the trailer will be the trick, I think, in strengthening this trailer floor and sub floor. I am wondering if Thompson's water seal is a good idea to use on the plywood floors before installing them. Any thoughts on a sealant for the floors? I think I'll get some more time to work on the trailer this weekend. I've been a little under the weather this past week and haven't gotten to tinker with the trailer. Chris
Old 03-30-2014, 05:04 PM   #6
Here are the twin recliners.
ID:	208587   Click image for larger version
Old 03-31-2014, 08:41 AM   #7
Thanks for the pictures! I've heard about the recliners but have never seen them. From what I see, they seem to recline from the thinner end. They also look pretty thick. In the picture that has the bed tilted up, is that maximum tilt up for it? Thanks! Chris
Old 03-31-2014, 09:34 AM   #8
Chris, They have coil springs and padding they are thick. I think they go up farther they were buried with trailer parts. heres another version with storage underneath. I am in the south bay your welcome to come down anytime. John
Early Airstream and Curtis Wright interior paint colors chris hart Upholstery, Blinds, Walls & Interior Finishes 2 11-11-2014 11:39 PM
Curtis wright or silver streak clubs 49clipper Vintage Kin 3 04-10-2011 09:58 AM
1949 Curtis Wright Silver Streak Clipper Travel Trailer Ag&Au Airstreams on eBay 0 03-14-2011 04:37 PM
