Originally Posted by ticki2
Dennis , you may be right , it could be a custom , the rear door appears different also with the lower fixed glass. I saw one on ebay this last year and it was refered to as an Ultra which looked like it had an extended cab over. Might have been the same one , it even had the red strip on the side.
Is yours a Cayo or Avion?
Mine is an Avion.
I came across some pics at the Avion Yahoo group of a 72 Cayo which looks to have the same layout except for the deeper holding tank area under the overhang........
Not sure if you can make out the Cayo badge on the front.
Also notice the formed aluminum piece at the front corners instead of the curved panel on the Avion.
On a side note I finally finished my windows, all new plexi, seals and gaskets
Dennis
