Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 10-07-2016, 03:48 PM   #61
Vintage Kin
Fort Worth , Texas
Orbital Machine Works. Video. Mach 8 Fan Kit.
I'm resigned to having roof penetrations. But I greatly dislike protuberances. There are some really ugly AS style trailers out there due to this. IMO, the Mach 8 is great looking (for what it is). And I'm not bothered by some modifications.
Now, no more departures from your thread.
Old 10-08-2016, 02:03 AM   #62
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Great progress. You go girl!!!
Dingo Girl is offline   Reply With Quote
Old 10-10-2016, 06:08 AM   #63
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I am FINALLY finished stripping all the tar & silicone off the roof! Listened to 49 hours of "Gone With the Wind" while I worked. Click image for larger version
I replaced the gasket on the a/c while up there. It wasn't as bad as I thought it would be. Remove interior plastic & metal covers, unplug wiring harness, 4 bolts are all that hold it to the roof....remove exterior cover.....flip it over (I propped mine on a tupperware tub) Clean up roof & reseal, replace old gasket & set her back down. I was advised (afterward) that it should sit for 36 hours prior to starting it back up. Probably a good idea. It cut down on the vibrations inside TREMENDOUSLY!Click image for larger version
The next roof project were the vents. I replaced all of them. The rear & front ones are Maxx Fan Deluxe fans with remotes and the bathroom one is a standarad Maxx Fan that only exhausts air. They are quiet, are able to run while it rains, and fold down so they aren't so huge on the roof. I've had Fantastic Fans...still do in my Bambi II, but like the aspect of being able to have them open & not panicking if you're gone & it starts raining. The openings had to be trimmed to square, which I did with my multi-tool. Worked like a charm. I used butyl tape under the flange & Tempro around the perimeter of it as well as over the screws. I put Eternabond over the entire lip .... hopefully I'll never have any leaks!
ID:	273305   Click image for larger version
ID:	273307   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 10-10-2016, 06:27 AM   #64
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Great job, Becky B.!! You did an awesome job!Definitely worth all of the time and effort.
I'll be shocked if it ever leaks again!
I like the shots of the vent and AC openings..... shows the far superior sprayed-on foam insulation that the Avion has.
PaulnGina is offline   Reply With Quote
Old 12-07-2016, 07:42 PM   #65
Becky B.'s Avatar
1964 17' Bambi II
I've been busy working on the trailer, but behind on posts here. After finishing the roof & vent installation, I did a thorough cleaning of the exterior. I used a maroon scotchbrite pad on a random orbit polisher to remove most of the oxidation. I found out that it's a bit too aggressive on the curved portions of the trailer & they should be buffed off by hand. After everything was cleaned, I applied 2 coats of Everbrite. I waited a few days between coats & applied with a brush.
I also installed new black inserts at the beltline. I purchased it from Chuck Cayo in Watervleit, MI. I found it a lot easier to install if I warmed it with a blow-drier. And waaay easier if my DH helped me! Before I installed it, I sealed all the rivets in the beltline as well as the top of it. Actually, I resealed the entire trailer...big job!
I was waiting to have my awnings installed until of of those things were finished. I've had them waiting for months! My dear sister, Sandy, sewed all the awnings with the exception of the curbside one. I had to purchase a new one from Zip Dee since the old one was missing the roller & I really like the Zip Dee awnings. I was able to get new parts for the old ones from PPL Motorhomes in Texas. My husband and sons installed the awnings in our warehouse a couple weeks ago. I can't wait to use them! Word to the wise....READ DIRECTIONS before trying to install!!! I won't go any further with THAT story! They're on and that's the main thing!Click image for larger version
I picked up my couch & dinette cushions from the upholsterer. He did a fabulous job! The next thing was to refinish the cabinets. They were really faded...especially the uppers. The doors & drawer fronts alone numbered 47!! The first photo is the tv cabinet in the rear bedroom. You can see the original color inside the tray & the faded color to the right. Click image for larger version
ID:	276458[ATTACH]Click image for larger version
I'll have to get some pictures of the finished curtains & upholstery....time to start baking Christmas cookies & decorating!! For whatever reason, some of the pictures are turned..hummm...!
Becky
1964 Bambi II
1988 Avion 32S
Old 12-07-2016, 10:00 PM   #66
N/A , N/A
This looks great! BTW, what product did you use to refinish the wood cabinetry? Thx
rostam is offline   Reply With Quote
Old 12-07-2016, 10:08 PM   #67
Becky B.'s Avatar
1964 17' Bambi II
I use Minwax Gel Stain Cherry. After I left the coat dry, I sprayed it with Minwax Polyurathane to lock in the color. (I like to use a cloth for the poly, but when used with the gelstain, it takes the color with it, so the spray locks it in). After spraying, I sanded with an 800 grit & used wipe-on Minwax poly satin for 3 coats. It doesn't take as long as one would think!
Becky
1964 Bambi II
1988 Avion 32S
Old 12-07-2016, 10:13 PM   #68
N/A , N/A
Thx, I should bookmark this page, so I can get to this next spring.
Old 12-09-2016, 07:59 PM   #69
Vintage Kin
Fort Worth , Texas
The Everbrite looks great! Nice prep work.
Old 01-04-2017, 05:56 PM   #70
Flint hill , Virginia
Can you tell me what you used for the new plumbing? PEX? Shark Bite?
Jascherschel is offline   Reply With Quote
Old 01-06-2017, 08:20 PM   #71
Becky B.'s Avatar
1964 17' Bambi II
Avion 32S Beast to Beauty (hopefully!)
Pex was used for the new plumbing.
Becky
1964 Bambi II
1988 Avion 32S
Old 01-28-2017, 07:37 PM   #72
Becky B.'s Avatar
1964 17' Bambi II
My husband & I took the Avion on a 3,000 mile trip down to the Florida Keys earlier this month. I'm happy to say that the trailer worked out perfectly. We boondocked at Camping World on the way down & Cracker Barrel on the way back. The trailer was such a comfortable place to stay, not to mention so much faster than a campground or hotel! (no check in, check out) We had no glitches & are so pleased with this trailer...no regrets in selling my pretty Avion 30P and I can happily say that this trailer is now a beautyClick image for larger version
Name:	Keys 2017 trip  picassa.JPG
Name:	Camping World! picassa.JPG
Name:	Bill & Trailer picassa.JPG
Name:	view picassa.JPG
Name:	bathroom picassa.JPG
Name:	bedroom picassa.JPG
Name:	kitchen dinette area picassa.JPG
Name:	Lounge area picassa.JPG
Becky
1964 Bambi II
1988 Avion 32S
Old 01-28-2017, 07:39 PM   #73
PaulnGina's Avatar
Good Ol' , USA
Looks great, Becky. Glad to hear you had such a nice trip!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Old 01-29-2017, 07:58 AM   #74
N/A , N/A
Your trailer looks great! BTW, your flooring looks very similar to mine. Did you get it from HomeDepot?
Old 01-29-2017, 02:07 PM   #75
Becky B.'s Avatar
1964 17' Bambi II
Yes. I ordered it from them. Allure snap together --I think it was rustic maple.
Becky
1964 Bambi II
1988 Avion 32S
Old 01-29-2017, 02:12 PM   #76
N/A , N/A
We have ordered the exact same flooring
Old 01-29-2017, 07:15 PM   #77
Becky B.'s Avatar
1964 17' Bambi II
It really looks lovely. The only thing that worries me is the contracting in the cold. I will have to go look again now that I quit heating the trailer. On a cold night on our way down to the Keys, one of the short ends had a pretty wide gap in it. I sure hope it expands back when it gets warm. I advised my son & daughter-in-law, who are rehabbing an Avion 30P, to use sheet linoleum. I used Allure sticky edge on my previous Avion & had shrinkage as well. I thought the click-together was the answer....now I'm not sure
Becky
1964 Bambi II
1988 Avion 32S
Old 02-01-2017, 08:32 AM   #78
Jarrod White's Avatar
1966 28' Ambassador
Mobile , Alabama
It looks great. And I'm always glad to see someone using their Avions for long road trips. I took my 1986 34W to the keys in November and had a great trip. But only 2000 miles round trip for me.
On the flooring, I used Smartcore luxury vinyl flooring that I purchased at Lowe's. It has a fiberglass base so it is more resistant to temperature swings. I have not seen any shrinkage to date. Click image for larger version
Name:	ImageUploadedByAirstream Forums1485963095.353606.jpg
I decided to keep my floor safe which was one of the features on the silver edition and cover it with a small rug.
Jarrod White is offline   Reply With Quote
Old 02-01-2017, 07:00 PM   #79
Becky B.'s Avatar
1964 17' Bambi II
Allure Snap Together Flooring
Well, I have bad news to report.....my Allure Snap Together flooring has separated in the cold weather. I can't even begin to say how disappointed I am! I looked up the company's warranty....this flooring is NOT recommended for RV's. I really don't know where I got the recommendation from, but I know people have used it & liked it. Maybe their weather doesn't get as cold as it does here in NW Indiana. I don't know. But I'm really bummed. Hopefully it will come back together when it gets warm out. I really loved this flooring & I the hours I spend installing & trimming it out with moulding was a LOT!!!:angry
Before Click image for larger version
After Click image for larger version
Name:	flooring in cold weather ....ugh!.JPG
Becky
1964 Bambi II
1988 Avion 32S
Old 02-01-2017, 07:39 PM   #80
KYAirstream's Avatar
Northeastern , Kentucky
So it looks like only the end joints are the problem? If so that's interesting that most of the contraction is at the ends and not along the length of the boards. What is this floor made of, and how long did you allow the flooring to acclimate?
KYAirstream is offline   Reply With Quote
First Timer with Avion 32S Coloflyer Vintage Kin 14 11-22-2015 05:27 PM
1989 Avion 32s gray water tank tstew42 Plumbing - Systems & Fixtures 7 09-16-2015 07:17 AM
1989 Avion 32s gray water tank tstew42 Waste Systems, Tanks & Totes 1 09-15-2015 01:53 PM
Beauty and the Hairy Beast... Ray Eklund On The Road... 36 02-27-2015 08:35 AM
Brought home Beauty--How to treat Beast? Scooter241 Member Introductions 9 07-29-2011 07:26 AM
