Old 10-13-2013, 08:52 PM   #1
fairmont , West Virginia
Argosy Minuet 6 meter
My plan is to buy and restore a 77 minuet. Does anyone know if you can install a double bed in the front of the camper, with out blocking the entrance? Also, how much room is there from the edge of the door to the front of the interior wall of the minuet?
thanks
anthonyk is offline   Reply With Quote
Old 10-13-2013, 09:07 PM   #2
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Originally Posted by anthonyk View Post
My plan is to buy and restore a 77 minuet. Does anyone know if you can install a double bed in the front of the camper, with out blocking the entrance? Also, how much room is there from the edge of the door to the front of the interior wall of the minuet? thanks
I have a 1980 airstream Caravelle 20' and everything I have seen indicates that it is identical to the Minuet in the layout and dimensions. At the height of a typical bed, the distance from the front to the door opening is about 56". A double bed is 54" wide so there is room for a double bed. The curvature makes it smaller than a double bed in some ways, but the interior of the trailer is 7' wide so the curve doesn't wipe out too much of the usable space in the bed. In the normal layout, the dinette table folds,down to make the double bed with the cushions. If you want to make it permanent, you can just unify the top surface and have a single mattress instead of a bunch of cushions that fit together. Best of luck in your plan.
Tim
timzog is offline   Reply With Quote
Old 10-14-2013, 09:10 AM   #3
reply
Thanks for the reply!
Fun Vintage Diner 1978 Argosy Airstream Minuet 6.7 Meter, 22, Sleeps 4 eBay Watch Airstreams on eBay 0 12-15-2011 12:20 PM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 09:30 AM
1977 Argosy Minuet 6 meter zimbop Trailer Values 18 08-29-2010 06:17 PM
Value of a 6 meter Argosy? Ultradog All Argosy Trailers 9 06-27-2006 10:24 AM
7.3 Meter Minuet on Ebay hotLAVA All Argosy Trailers 0 05-20-2003 09:48 AM
