01-02-2009, 03:13 PM
#81
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Gave up on the Red 'n White idea. None to be found with out ordering, 2 weeks with hefty shipping and then it was not what we had in mind. Found these at Home Depot, kinda retro looking. Need to keep moving to get it done.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
01-02-2009, 07:42 PM
#82
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
Nice subtle tile. That is more along the lines of what we would do if we were redoing another rig.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
01-03-2009, 04:54 AM
#83
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks, the pic does not really do justice to it. We thought Bright would be kinda cool, but feared the idea would get "old" and then we'd be thinking, "What did we put that down for!" I'll get a better pic to show the colors better.
www.balrgn.com
01-03-2009, 01:50 PM
#84
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Here is a better shot of the color combo.
www.balrgn.com
01-04-2009, 06:17 AM
#85
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
To save space and room we are thinking of going with a Propane Gas
TANKLESS WATER HEATER
http://stores.gonetankless.com/-strse-6/10L-LPG-Propane-Gas/Detail.bok
Looks like it ca be plumbed into a small space and meet the water needs.
www.balrgn.com
01-06-2009, 07:11 AM
#86
Usually Sleepy
East Haven
, Connecticut
WOW!!! That price has come down drastically!!! I would have used that for my trailer for sure!!
Skip
01-06-2009, 07:22 AM
#87
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
With Shipping it was a little over $250. Originally Rosie did not have a water heater, so no cut out to work with. I wanted to avoid making a large cut out, it would have broken up the rub rail. Now I need to find a home for it. If I position it right, I can use the exhaust vent for a towel warmer
www.balrgn.com
01-06-2009, 07:24 AM
#88
Usually Sleepy
East Haven
, Connecticut
Very luxurious.
Skip
01-08-2009, 03:44 PM
#89
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
New Bathroom arrived today!
We want to save as much space/weight as possible.
www.balrgn.com
01-08-2009, 03:52 PM
#90
1975 Argosy 26
1963 24' Tradewind
Seattle
Hey, like the shower/ toilet combo.... what source did you use?
I was wondering about the tankless heater... I wonder how cold the water is around here in the winter... @ 40 degrees, the outlet flow would have to be 1 gpm to warm it to 105 degrees - if I'm reading the chart right. How fast do our water pumps flow, 2gpm?
Would that work for showers in the cold? I like the unit! It seems compact and perfect for RV use otherwise.
Marc
01-08-2009, 04:22 PM
#91
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Found the shower unit at:
RV Surplus
It came in in 4 days! Only $159 + Shipping to boot!
You think your water is that cold? Typically it comes from a well around 50º - 55º, But yes the flow would be that, your pump should put out up to 2 GPM, I would imagine that the shower head would restrict it to much less than that tho.
Hot water heater should be here Monday
www.balrgn.com
01-08-2009, 04:59 PM
#92
1975 Argosy 26
1963 24' Tradewind
Seattle
I guess even 50 degrees feels cold!! You're right... the ground is an excellent heater... I forgot about the shower restrictor valve... I think I may go this route as well. Seems even easier to winterise!
Marc
01-09-2009, 01:04 PM
#93
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
99% of the floor is down. Need another pair of hands to finish. About a dozen pieces left to place, all the edges.
Placed the shower assembly inside, the Frame threw me a curve so I have to move it of cute a 3" + home through in 2 places. One is bad enought...
www.balrgn.com
01-11-2009, 04:43 AM
#94
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Update
Floor is 100% done! Frame bolts in and tightened. Whew, made it before the next big storm with the help of the wife! As mentioned, I upgraded to 5/16 - 18 Stainless. Had to use "fender washers" in a couple spots the original floor was delaminated just a touch. Now I must do something with the wheel wells to get them water tight. After that, all that skirting that was removed must be replaced. That ought to be fun..
Furnace on order. Atwood Hydro Flame 7916 16,000 BTU. (eBay) I have this in my '74 Overlander, works great!
Potty on order. (eBay) Thetford Aqua Magic V RV Trailer Toilet w/ Hand Flush.
Rebuilding one of the original vents. Glass Bead blasted the metal and painted with POR White coat.
This may actually start to look like something soon!
www.balrgn.com
01-11-2009, 07:22 AM
#95
Certifiable
Where are you really?
You're pulling our collective leg, right? You're not outside in New Hampshire doing a full monty on a '46 Spartan now. You're in Texas or San Diego, right?
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
01-11-2009, 08:22 AM
#96
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels
, Wisconsin
Holding Tank
RV Surplus
Can you tell me what the holding tank size is in gallons? Also what are you planning on using for the walls of the bath enclosure? I have to add a bath to the 54 and this just might be the way to go!
thanks
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
01-11-2009, 11:33 AM
#97
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
thanks
Just about 10 gallons. Looks like a pretty good unit. It will be a bit odd having a wet bath.. Have not had one yet!
We saw some acrylic wall board at Lowes the other day. Going to use that for the walls. Might use similar on the ceiling as well .
www.balrgn.com
01-11-2009, 11:37 AM
#98
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Originally Posted by mistral blue
You're pulling our collective leg, right? You're not outside in New Hampshire doing a full Monte on a '46 Spartan now. You're in Texas or San Diego, right?
If it was warmer I'd be camping!
8" of snow today Slowing me down. Well, not really, working on one of the original cabinets now. This morning I worked to finish the vent
www.balrgn.com
01-11-2009, 06:57 PM
#99
1978 29' Ambassador
Walnut Cove
, North Carolina
Thank you for sharing your sources and all the great ideas. We are getting ready to work on our 65 Ambassador and I was delighted to find the water heater- we are going all electric do to our needs but this company's prices are way better than anything I have seen so far. Thank you!!!!
Dannie
The Silver Queen
01-11-2009, 07:20 PM
#100
Austin
Nice work!
Any insights on products/techniques you used to clean it up? I have an old vent cover that could use similar treatment!
