Something to keep in mind if you are doing home renovations (or trailer renovations)
10 AC outlets is not too many. If you add them during construction they cost $5 apiece. If you need to add one after the job is finished they cost at least $100 apiece. So if you are in doubt put a few in. From an old home renovator/electrician.
I hear ya, I put one everywhere I thought I'd plug something in.
Love the new power panel, has plenty of spots for breakers. I'll have 6 breakers, I think when I'm done. There are at least a dozen DC fuse's in there too, that will be the next phase.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC www.balrgn.com www.balrgn.com/Airstream.htm
Got a jump start with the warm weather! Restored Roof Vent installed! Works like new now! Plugged a bunch of holes with Olympic rivets. All the shiny insulation is installed, thanks to Susan!
Also, work has started on the Cabinetry
Between that refer and stove, I have kitchen appliance envy. Very nice.
Here is a pic with them side by side. That is not the stand, only a temporary one to get a feel for the height and work on prepping for paint.
Outstanding work as usual. Do you plan to camp in Rosie this season?
I recently spotted a very large Spartan, looking lonely in a field, a couple of towns away from me. I might have to have a look see. Just for grins.
Our goal is to have it camp-able by the Vintage Trailer Jam. Fingers crossed!!!
Last nights rain located a couple leaks. It sure is good to have this weather. I am close to final insulating and then walls. Need to be absolutely certain I get all the holes plugged! Hard to leak check when water instantly freezes
Laminate floor 80% down. Have stopped by the door for the winter season.
The windows in the front have been a set back, I will be making frames, the lexan I had made WILL NOT go into the gaskets. After hours and hours of attemps with help form some ole time window repair guys I threw in the towel. I have a plan tho!
