04-29-2015, 08:41 AM
#141
Silver streak
Vancouver
Model 24 Silver Streak
Building the refer cabinet and a new cabinet where the old wall heater was located. some good space there to have some fun with
04-29-2015, 10:30 PM
#142
Silver streak
Vancouver
Reading the instructions for the refer, they stated the outside vent had to be below the bottom on the refer so any gas leak would go thru this vent. As you can see my lower vent is a good ten inches above where the fridge will be. So I drilled a 3" hole in the floor that vents out below the belly pan. Bug mesh on both ends.
Also added aluminum panels behind the fridge instead of wood that has a chance of getting wet.
04-29-2015, 10:37 PM
#143
Silver streak
Vancouver
Checking fit of stove and microwave.
Install refer cabinet along with a custom cabinet next to the entry.
Tough set of cabinets to get right!!
04-30-2015, 03:50 PM
#144
1976 Argosy 26
Fair Oaks
Looks great. Following your build as I picked up a Streamline Duke project.
05-03-2015, 09:32 PM
#145
Silver streak
Vancouver
Removed the axles today . they have a 2" drop. You can only order a straight axle or a four inch drop. I believe 4" will be to low so I'm going with a straight axle hoping that the trailer will not be too high?? New axles are cheaper and easier to get parts for rather than rebuilding the old ones.
05-04-2015, 05:30 AM
#146
1965 26' Overlander
Tulsa
, Oklahoma
If it sits too high, put lowering blocks between axle & leaf.
05-04-2015, 06:06 AM
#147
Vintage Kin
Fort Worth
Or upgrade to torsion axle.
05-13-2015, 02:45 PM
#148
Silver streak
Vancouver
Setting up the new axles and brakes. I used the old springs, Replaced everything else. A little over 800.00 all in.
05-13-2015, 02:50 PM
#149
Silver streak
Vancouver
Added new air conditioner and two new fantastic fans from VTS.
Nice having a tractor to get the old AC off and the new one on.
05-13-2015, 02:54 PM
#150
Silver streak
Vancouver
Checking fit of new bath counter , sink and faucet. Sink is a stainless steel mixing bowl.
05-15-2015, 03:09 AM
#151
Missoula
, Montana
Thanks for the awesome and well documented project. Quick question, why did you put tyvek over the insulation? I haven't seen that before and when I think about a house, the tyvek is outside insulation. I honestly don't get vapor barrier stuff - so just trying to understand...
05-15-2015, 10:27 PM
#152
Silver streak
Vancouver
JJA
I had some tyvek left over from a previous project. I only put it in areas where there was wood panels. My thought process that it would help protect the wood and any additional sealing would help? No big scientific reason.
05-24-2015, 08:57 AM
#153
Silver streak
Vancouver
Plumbing and electrical complete. The amount of time spent in this small area is amazing, it really sucks up the hours. The original 12 volt wiring was one wire piggy back thru out the trailer. I must of installed a mile of new wiring? Pex plumbing is the only way to go! Just be sure to plan your crimps. the tool requires some room to use and the trailer has some very tight spaces.
05-24-2015, 09:00 AM
#154
Silver streak
Vancouver
Beds are now both in
05-24-2015, 09:09 AM
#155
Silver streak
Vancouver
Kitchen sink mock up and front cabinet installed. still need to put in the speaker holes.
05-24-2015, 09:12 AM
#156
Silver streak
Vancouver
Our SS trailers used a lot of clinch latches. I wanted chrome and was unable to find until now. VTS now stocks them. Stainless not chrome but close enough. I have 17 coming, I will let you know about the quality?
05-24-2015, 01:03 PM
#157
Vintage Kin
Fort Worth
Those are good looking. I prefer those over how things are done on my '90.
05-24-2015, 08:46 PM
#158
Silver streak
Vancouver
Not a fun day!
The belly pan is not in terrible shape. Not great but with a few patches it will be acceptable. There was a white corrosion on the belly skin as the trailer sat in tall grass. I sanded the whole pan with 60 grit and will prime and paint when the patches are complete.
05-26-2015, 10:19 PM
#159
Silver streak
Vancouver
Finished up the bath sink ,faucet and Formica. Still need the counter edging and cabinet latch and hardware. Very happy how the sink came out considering its a 5 quart mixing bowl.
05-30-2015, 09:10 PM
#160
Nowhere
You are doing a true first class restoration. The cabinets, hardware and mechanicals all look beautiful. Can't wait to see the finished product.
