Go Back   Airstream Forums > Airstream Knowledgebase > Vintage Kin
Old 06-28-2008, 09:00 AM   #1
tinbender
tinbender's Avatar
Profile:  2001 16' Bambi
1972 23' Safari
Piedmont Region , North Carolina
12 volt inline fuse stops power???
I have a teardrop trailer that I bought recently and have been doing some upgrades to it. I ran into the following problem when I wired in a small 12 volt fan. Could use some help in trying to solve how to make it functional. This trailer has only a 12 volt battery that has 2 interior lights run to it and a light on the inside of the lift up back.
The fan was spliced into the power wire that feeds the interior lights, with an inline fuse, and tied to the common ground that is connected to the frame. This setup is as per the wiring instructions that came with the fan. The lights work, the fan would not.
To see if the fan was bad, I took it out and put it straight to the battery, with the fuse attached, and it still would not work. So then I removed the inline fuse, put the wires to the battery again and it worked great.
Basically it wouldn't work in any combination except the straight wire scenario. I would feel better having the fuse in the mix but it refuses to work with it there, so is it basically safe to just run it in the "straight wire" mode? BTW, the lights have no fuses either.
TB
Name:	Camping Trip 141.jpg
tinbender is offline   Reply With Quote
Old 06-28-2008, 09:04 AM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Sounds like the fuse is bad. Did you try a new one?
Richard
Charter Member Four Corners Unit
Old 06-28-2008, 09:06 AM   #3
easyride
Profile:  1977 27' Overlander
naples , Florida
Or the fuse holder is bad
easyride is offline   Reply With Quote
Old 06-28-2008, 09:06 AM   #4
tinbender
tinbender's Avatar
1972 23' Safari
New fuse
Yeah, I did. Still no joy.
If you believe that "For Sale" sign that says "No Leaks", count the one in your head........
Old 06-28-2008, 09:10 AM   #5
azflycaster
Phoenix , Arizona
Images: 58
Is the fuse blowing? If not the holder is bad as stated above. You should be able to find the open with a multi meter.
Richard
Old 06-28-2008, 09:15 AM   #6
tinbender
tinbender's Avatar
1972 23' Safari
thanks AZ and Easyride,
No, the fuse is not blowing. Will get another holder and fuse assembly and take some readings.
TB
Old 07-09-2008, 04:37 AM   #7
tinbender
tinbender's Avatar
1972 23' Safari
follow up on fan install
To tie up the loose end, all turned out well with this project in the end. Went back to square one checked all hookups, crimps, grounds, etc. Got another new inline holder, fuse and fuse tester. Checked it all out and did a dry run hooking the new setup to the battery, this time it worked like a champ. In the final installation I decided to run a new power and ground line for the fan and not splice back into the existing wires that run the lights.
That little fan makes a big difference. Much cooler in the trailer now. Thanks all for the suggestions.
TB
Can't find the 12 volt fuse panel in my 1976 31 foot Sovereign clboyd Batteries, Univolts, Converters & Inverters 16 08-17-2008 11:06 PM
Power consumption of various 12 volt items guy99 Batteries, Univolts, Converters & Inverters 18 01-20-2008 03:04 PM
No 12-Volt Power Silver Threads Batteries, Univolts, Converters & Inverters 28 07-03-2007 08:53 PM
12 volt fuse box matilda Electrical - Systems, Generators, Batteries & Solar 2 06-27-2006 09:00 AM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
