Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1970 - 1978 Globetrotter
Old 05-06-2014, 06:35 PM   #1
70CT's Avatar
1974 21' Globetrotter
2016 30' International
Houston , Texas
Proud New Papa, Meet Jalopy!!
Howdy,
Proud new owner of a 1970 Globtrotter! Bought ol' Jalopy here on a whim this weekend for what I thought was a great deal! (I have also always loved Airstreams in my short 30yrs on this rock)
I don't have any history with camper trailers or motorhomes, but I did stay at a Holiday Inn Express last night. (Never even set foot in one until I bought this one!)
To say I am a newbie would be a misrepresentation of the most serious nature. It took me 30 minutes to figure out how to plug the dang thing in when I got home to see if the lights and AC were functional. I still am afraid to hook up water to it, because I have no idea where it is going to come out! (I am open to suggestions)
As with all things brought to us by the fine folks at PO, there is lots of silicone, false promises of no leaks, and in my case what looks to be a futile attempt at making my retreat "all electric".
I will provide lots of pictures for your viewing consumption, but really because I have no earthly idea what I am talking about. Apologies up front for being "that guy" who asks a ton of ridiculous questions.
So now on to the good stuff!
Dan
Name:	ImageUploadedByAirstream Forums1399422751.412219.jpg
ID:	211367Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422770.399871.jpg
ID:	211368Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422795.976817.jpg
ID:	211369Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422819.265695.jpg
ID:	211370Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422834.589815.jpg
ID:	211371Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422857.061837.jpg
ID:	211372Click image for larger version
Name:	ImageUploadedByAirstream Forums1399422873.893151.jpg
70CT is offline   Reply With Quote
Old 05-06-2014, 06:48 PM   #2
weirdstuff's Avatar
2018 23' International
SANTA BARBARA , CA
NICE!!!! Very funny post too. I can relate!
One thing is, you might not want to call your new baby, "Jalopy." Could be bad karma, or a case of your child living up to expectations. I would pick a more optimistic name!
weirdstuff is offline   Reply With Quote
Old 05-06-2014, 06:51 PM   #3
weirdstuff's Avatar
SANTA BARBARA , CA
Just noticed the bumper sticker, "Expect A Miracle." Maybe you could call her "Miracle," or refer to her as "The Miracle." That would be a good, positive name for her!
Old 05-06-2014, 07:05 PM   #4
70CT's Avatar
Houston , Texas
Haha didn't even think about that! It's a fitting name "Miracle", because after reading some of these threads, it will be a miracle if I ever finish it!
Old 05-06-2014, 07:05 PM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
70CT,
Congrats on the adventures to come. I'm not versed in older stuff but I can relate to the caution about hooking water to the rig to find out what's what. How about compressed air instead? Ever notice new construction, the plumbers apply compressed air to the roughed in lines and see if it holds pressure for a period of time. You can make up a pressure test fitting that will attach to the fresh water connection, pressurize to maybe 30 PSI, and watch the pressure and listen for leaks etc. Air don't make a big mess like water can. You do not apply a continuous supply of compressed air, charge, seal and observe.
Good luck and you found a great spot for real help and been there, done that folks in all disciplines Airstream.
Gary
GCinSC2 is offline   Reply With Quote
Old 05-06-2014, 07:06 PM   #6
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
Congrats and welcome! When it comes to water first try some water in the fresh water tank and then turn the water pump on. Pump should come on and run for a few then stop, until you open a faucet. After running some water pump should kick on and build the pressure back up. If system holds pressure you may be good. City water pressure can blow older pipes, be sure to get a pressure regulator before you try city pressure.
Good luck and you should have a ball with that nice looking Airstream.
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 05-06-2014, 07:09 PM   #7
70CT's Avatar
Houston , Texas
More photos of PO patch work. "Doesn't leak!" he says. We knows better don't we Smeagol? Tricksy PO'ses
Name:	ImageUploadedByAirstream Forums1399424764.241432.jpg
ID:	211375Click image for larger version
Name:	ImageUploadedByAirstream Forums1399424778.461173.jpg
ID:	211376Click image for larger version
Name:	ImageUploadedByAirstream Forums1399424787.436741.jpg
Old 05-06-2014, 07:11 PM   #8
70CT's Avatar
Houston , Texas
Thank's Gary! That is a great idea.
Old 05-06-2014, 07:16 PM   #9
70CT's Avatar
Houston , Texas
Thank you kmaggard! What happens to the water once it runs down the drain? From what I read, there is no gray tank in this model "yet", so does it go straight to the black water tank? Or is there some way I can run it off city water and not fill up my black tank?
Also where does one find the fresh water tank? Haha man I'm screwed
Old 05-06-2014, 07:31 PM   #10
kmaggard's Avatar
1994 21' Sovereign
go here if you have not seen this...
Airstream, Inc :: 1970's
Sounds like you only have one holding tank the will take used kit sink, shower and toilet water. May be a bypass way to drain sink and shower water out on the ground but it would be model specific.
There should be a water fill door and/or cap somewhere on the outside that maybe someone that has a model closer to yours can tell where to find.
In general there are two places to put water in. One to fill up a fresh water tank and one to hook a hose to for city water.
WBCCI# 2520
AIR# 77458
Old 05-06-2014, 07:33 PM   #11
kmaggard's Avatar
1994 21' Sovereign
BTW, I lived in a 1956 Airstream when I was in college with the same floor plan.
WBCCI# 2520
AIR# 77458
Old 05-06-2014, 08:37 PM   #12
70CT's Avatar
Houston , Texas
Very helpful that makes all of the pieces fit! Thanks!
Must have been fun!
Old 05-06-2014, 09:18 PM   #13
enived2's Avatar
1967 20' Globetrotter
Englewood , Colorado
Images: 12
I am loving the rock guard . Good luck! I love Globetrotters! You will be fine. Take your time and enjoy the ride
Www.projectmidge.wordpress.com
enived2 is offline   Reply With Quote
Old 05-06-2014, 09:24 PM   #14
aluminitus's Avatar
1962 24' Tradewind
Tucson , Arizona
Images: 14
HAHA a wood rock guard...fixin' on the cheap! Can't wait to see what you do with your jalopy!
aluminitus is offline   Reply With Quote
Old 05-06-2014, 09:48 PM   #15
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Okay I am taking it that your globetrotter (the caravel) needs a few tweakes? You should be able to do it with no problem. So have you looked under her yet? Maybe find the drain access and peek at the frame to see how it looks. so far with the exceptions of the patches on the floor and the redneck rock guard she looks pretty good and must have been a real good price or why did you buy her?
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-06-2014, 10:44 PM   #16
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Older Airstream gray water lines
The gray water lines should run to a fitting that T's into the main sewer line downstream of the black tank's dump valve. Back in the day, it was OK to allow gray water to drain onto the ground. Now we use portable tanks on wheels to collect gray water when we don't have full hookups.
Old 05-07-2014, 07:08 AM   #17
70CT's Avatar
Houston , Texas
That makes sense, I took a look at it again this morning before heading out to work. Thank you, I will need to try it out tonight and see how it all works!
Old 05-07-2014, 07:37 AM   #18
70CT's Avatar
Houston , Texas
Cliff
Thanks! I take it you noticed that I created a handle before I really figured out what kind of trailer I had.
Old 05-07-2014, 07:50 AM   #19
70CT's Avatar
Houston , Texas
This weekend, Jalopy (aka "Miracle") will make the trip from our home in Houston to my parent's home up in Waco. I am not terribly excited about this because it means I will only be able to work on her on the weekends, but they do have a massive barn that I will keep her out of the elements which is a huge plus.
Here is the list of planned re-works on the inside:
  • Increase the size of the bathroom. My 6' frame and our 100lb Goldendoodle will really appreciate this.
  • Move the fridge and microwave in with the rest of the kitchen on the street side.
  • Remove the front goucho and find a way to add in a foldable queen sized bed.
  • Redo all electrical, and add solar
  • Redo all plumbing, add a gray tank
  • Figure out what I want to do about propane. I like the Idea of all electric.
Outside needs a lot of help as well; shell work, LED lights, sealing, new gaskets.....
Ordered new window and door gaskets from inlandrv (very helpful) so off we go!
Old 05-07-2014, 09:07 AM   #20
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Congratulations on your purchase. Let the fun begin!
Don't forget your running gear: axle, wheel bearings, brakes and tires.
Poppy
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
proud new parents cloud55 Member Introductions 16 04-08-2007 12:26 PM
proud new owner of a '76 Airstream... gitnmybelly General Repair Forum 3 06-08-2005 09:03 AM
My daughter and I are the proud new owners of a '72 Tradewind Airstream lulu 1970-79 Tradewind 11 05-03-2004 01:16 AM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
