Old 05-09-2014, 08:57 AM   #29
Cardinal283's Avatar
Dallas , Texas
Too bad you're not in Dallas anymore. We could compare notes.
Cardinal283 is offline   Reply With Quote
Old 05-09-2014, 09:07 AM   #30
70CT's Avatar
1974 21' Globetrotter
2016 30' International
Houston , Texas
Originally Posted by m.hony View Post
The rock guard looks like a picnic table top...
That looks like for real granite counter and back splash in that bad boy-
Looks to me like it might be "ready to camp".
The sink next to the bed is somewhat odd...
Thanks for the complement on the rock guard, but I can't take credit for it's beauty.
Aye, it is a real granite counter and back splash! Don't know if I will keep it though, is it too heavy?
And yes, strange spot for a sink, but I will fix that.
70CT is offline   Reply With Quote
Old 05-09-2014, 09:56 AM   #31
1972 27' Overlander
Denver , North Carolina
I have a 72 Overlander. You have one tank for black water only! So not run your gray drains into it!! You need a blue boy, portable tank for gray water. It's no biggie to hook up and use.Do not use black tank for gray water.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 05-09-2014, 10:11 AM   #32
70CT's Avatar
Houston , Texas
Good to know, thanks mccrosti! I think that I am going to install a gray water tank while I have everything pulled up. Also toying with the idea of using the gray water to flush the "potty", but I still need to wrap my mind around that one...
Old 05-09-2014, 12:32 PM   #33
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I wouldn't think a piece of granite that small would weigh enough to matter, but there is some reason you never see it, not even in $100,00-$250,000 trailers and motor homes- must be because of the weight-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-10-2014, 04:35 PM   #34
1972 27' Overlander
So of course it's rained cats and dogs all day.. Did get the chance to make a pattern and prepare the black tank - install the valve etc for its new home.
Old 05-10-2014, 04:36 PM   #35
1972 27' Overlander
Sorry guys fat fingered the keyboard..
Old 05-10-2014, 06:56 PM   #36
70CT's Avatar
Houston , Texas
Guess who needs to buy a new black water tank? This guy!
Name:	ImageUploadedByAirstream Forums1399769569.172304.jpg
ID:	211625Click image for larger version
Name:	ImageUploadedByAirstream Forums1399769579.505839.jpg
ID:	211626Click image for larger version
Name:	ImageUploadedByAirstream Forums1399769588.957623.jpg
Also here is an update to what work was done today.
Love the open concept bathroom!
Name:	ImageUploadedByAirstream Forums1399769731.309475.jpg
Removed the remainder of the interior
Name:	ImageUploadedByAirstream Forums1399769767.359417.jpg
Old 05-29-2014, 10:45 AM   #37
70CT's Avatar
Houston , Texas
So, the verdict is in. I hate Fiberglass insulation. It is the absolute worst.
The wife and I pulled out all of the interior panels, insulation and wiring.
I had no idea that the front and rear domes were fiberglass. Learn something new everyday. We are going to put in some beefier wiring since we are going to use an induction cooktop.
Do you think 12 gauge will be able to handle the power draw?
The next step is to take the shell off so I can work on the frame. The question here is, do I need to remove the buck rivets around the outside shell or should I be able to remove all those rusted out bolts from the c channel inside and have the shell come off?
Also the on the pieces of the shell that wrap around the frame, I have seen people say they rest the shell on the ground. Wouldn't that deform those pieces unless you removed them?
Name:	ImageUploadedByAirstream Forums1401381810.435977.jpg
ID:	213121Click image for larger version
Name:	ImageUploadedByAirstream Forums1401381842.374246.jpg
Old 05-29-2014, 10:02 PM   #38
1970 27' Overlander
1970 21' Globetrotter
Hamilton , Montana
I will watch this one as I too have a 1970 globetrotter and am a newbe. As for the promises I think we bought from the same guy!
gdod25 is offline   Reply With Quote
proud new parents cloud55 Member Introductions 16 04-08-2007 12:26 PM
proud new owner of a '76 Airstream... gitnmybelly General Repair Forum 3 06-08-2005 09:03 AM
My daughter and I are the proud new owners of a '72 Tradewind Airstream lulu 1970-79 Tradewind 11 05-03-2004 01:16 AM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
