Old 10-19-2007, 08:34 PM   #113
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Ooops...sorry, we missed the action! Looks good though ~
Shari
Old 10-19-2007, 10:32 PM   #114
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Same here. I can't believe I missed this thread, Kip. It's looking great!
www.nesa.org
Air No. 6427
Old 10-19-2007, 10:40 PM   #115
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
i missed this too, great work kip. guess the name change really helped.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 11-10-2007, 08:21 PM   #116
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Another busy day
Started early today on the street side lower skin. First Pic is a before picture, notice the 6061-T6 skin splice done by a PO. On the second picture I am plugging all the 3/16th holes that the skin repair was originally installed with and re drilling them to 1/8th for now The third pic is of a frame section that was bent (and with 3/16th holes) that I straightened and then attached to the "C" channel and out rigger. The forth pic is of a frame work change on the two frames that stopped short of the wheel tub. I fabricated a new longer stringer out of .063 2024-T3. The old way left the area above the wheel well tube flimsy. I still need to make two new stub frames to go on each side of the tub up to the new stringer. The last pics show the new skin being drilled up. I still have another good day of work before it will be ready to be shot on.
ID:	49133   Click image for larger version
ID:	49135   Click image for larger version
Old 11-10-2007, 08:23 PM   #117
Aerowood's Avatar
Arvada , Colorado
Last two pics
Last two pics that didn't load
ID:	49137   Click image for larger version
Old 11-17-2007, 07:27 PM   #118
Aerowood's Avatar
Arvada , Colorado
ran out of daylight
Continued with the street side lwr skin replacement. I got most of it drilled up and the bulk of the trimming done. I still have to trim the forward lower section to ED. I would like to get the banana wrap made too but I think that it might have to wait until spring. I plan on shooting on everything except the lower row over the holiday weekend. I also have to fabricate the two sub frames that will go on the forward and aft sides of the wheel well tub.
Kip
ID:	49448   Click image for larger version
Old 11-17-2007, 09:09 PM   #119
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Darn, you got home and got photos up before I could!
Name:	IMG_8215 kip thru door-s.jpg
ID:	49455Click image for larger version
Name:	IMG_8217 kip and project-s.jpg
Kip, always a fountain of aluminum expertise, gave me some pointers today that give me confidence I can get the floor fixed ASAP in my '77 Safari. Thanks, Aerowood!
Zep
Old 12-16-2007, 02:58 PM   #120
Aerowood's Avatar
Arvada , Colorado
Well I pushed the envolope, and it now looks like it will be awhile before I can finish shooting on the skin.
Kip
Old 12-16-2007, 10:41 PM   #121
Central , Mississippi
Kip
come on Kip,
Rivit guns work in winter...
Don't let us lessers of the art suffer...
Keep the progress moving forward and posted
as I sit I my recliner on WIFI
OK, I'm not that bad, I did wax the front segments today in 40 degree weather.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-17-2007, 07:40 AM   #122
Aerowood's Avatar
Arvada , Colorado
Its not a question of riveting on the skin when it's cold outside, but the temp at which the sealent is applied. It would be better if it was above freezing, better yet if above 50.
Old 12-17-2007, 10:57 AM   #123
1975 31' Sovereign
1977 23' Safari
Kip, I've got a tent that's big enough for your Airstream. If you want we can set it up and use my propane bazillion-BTU construction heater to keep things warm. Hate to see you slow down.
I'm going to "skirt" my Safari for the same reason--need to POR-15 before springtime.
Zep
Old 12-17-2007, 11:04 AM   #124
Aerowood's Avatar
Arvada , Colorado
Thanks for the offer, I may take you up on that. I have more hardwood floors to install in the house first. Her projects always trump mine.
Old 12-18-2007, 09:19 AM   #125
1975 31' Sovereign
1977 23' Safari
The tent is 10'x16' by 10' high. It can easily be 10'x20'. The blue tarps from Costco fit perfectly and are cheap (I have many). We can take a used one and cut an Airstream-shaped "hangar door" in one end to fit tight (or tape it on temporarily) and drape the sides to the ground. The joints are pretty stable and the 1-1/4" pipes are stiff. It does fine in a wind if you guy it. Each foot has its own stakable plate.
Name:	IMG_7503 tent roof-s.jpg
It might even be possible, and desirable, to use half as a lean-to, but I've been thinking that configuration may be difficult to heat.
Should work...
You get to pay for the propane.
Zep
Old 01-26-2008, 05:05 PM   #126
Aerowood's Avatar
Arvada , Colorado
good weather day
I talked my brother into coming over to help me shoot on the street side skin. It only cost me a 6 pack of Bluemoon. I had to trim the bottom edge of the panel done to ED (edge distance) before We could install it. I used a skin knife to score the aluminum and then a pair of duck bill vise grips to brake it off. A quick sand of the edge followed up with a vixen file and we we ready to shoot. A skin knife is the best way to make a long straight cut if you don't have a shear Handy. 2 hours later the skin was on. I still have to make the lower wrap before I can shoot on the bottom row. I'm installing the wrap behind the side skins
ID:	53200   Click image for larger version
ID:	53202   Click image for larger version
Full Monte or not? I get what I deserve! Chlyman General Repair Forum 12 10-04-2011 08:48 PM
Full Time living in an Airstreaam bmccomb On The Road... 0 08-28-2011 02:59 PM
Switching over to full tank problems melbel LP Gas, Piping, Tanks & Regulators 11 05-29-2011 07:25 PM
Full timing in the great white north hankyknot Full-Timing 8 05-06-2011 11:59 AM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 04:42 PM
